openspace3d error
Posted: Wed Feb 07, 2018 9:29 pm
I am trying to run an augmented reality app made in Openspace3d on my raspberry pi 3 with camera v2 and an 5inch lcd.
camera works, I have tested it with raspistill
I am running Raspbian Stretch
So when I run the app it shows Openspace3d logo on the screen and goes black
Here is all the info from Terminal:
It looks like there are multiple problems
Can someone please help?
pi@raspberrypi:~ $ simulacrum2
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
Unable to query physical screen size, defaulting to 100 dpi.
To override, set QT_QPA_EGLFS_PHYSICAL_WIDTH and QT_QPA_EGLFS_PHYSICAL_HEIGHT (in millimeters).
Creating resource group General
Creating resource group Internal
Creating resource group Autodetect
SceneManagerFactory for type 'DefaultSceneManager' registered.
Registering ResourceManager for type Material
Registering ResourceManager for type Mesh
Registering ResourceManager for type Skeleton
MovableObjectFactory for type 'ParticleSystem' registered.
ArchiveFactory for archive type FileSystem registered.
ArchiveFactory for archive type Zip registered.
ArchiveFactory for archive type EmbeddedZip registered.
DDS codec registering
PVRTC codec registering
ETC codec registering
stb_image - v2.15 - public domain JPEG/PNG reader
Supported formats: jpeg,jpg,png,bmp,psd,tga,gif,pic,ppm,pgm,hdr
ASTC codec registering
Registering ResourceManager for type HighLevelGpuProgram
Registering ResourceManager for type Compositor
MovableObjectFactory for type 'Entity' registered.
MovableObjectFactory for type 'Light' registered.
MovableObjectFactory for type 'BillboardSet' registered.
MovableObjectFactory for type 'ManualObject' registered.
MovableObjectFactory for type 'BillboardChain' registered.
MovableObjectFactory for type 'RibbonTrail' registered.
*-*-* OGRE Initialising
*-*-* Version 1.10.11 (Xalafu)
Creating resource group SO3/Internal/Widgets/BitmapWidget
Installing plugin: OpenGL ES 2.0 RenderSystem
OpenGL ES 2.x Rendering Subsystem created.
Plugin successfully installed
Installing plugin: ParticleFX
Particle Emitter Type 'Point' registered
Particle Emitter Type 'Box' registered
Particle Emitter Type 'Ellipsoid' registered
Particle Emitter Type 'Cylinder' registered
Particle Emitter Type 'Ring' registered
Particle Emitter Type 'HollowEllipsoid' registered
Particle Affector Type 'LinearForce' registered
Particle Affector Type 'ColourFader' registered
Particle Affector Type 'ColourFader2' registered
Particle Affector Type 'ColourImage' registered
Particle Affector Type 'ColourInterpolator' registered
Particle Affector Type 'Scaler' registered
Particle Affector Type 'Rotator' registered
Particle Affector Type 'DirectionRandomiser' registered
Particle Affector Type 'DeflectorPlane' registered
Installing plugin: Octree Scene Manager
ArchiveFactory for archive type ScolFileSystem registered.
ArchiveFactory for archive type ScolURL registered.
CPU Identifier & Features
* CPU ID:
* VFP: no
* NEON: yes
*** Starting EGL Subsystem ***
EGL_VERSION = 1.4
EGL_EXTENSIONS = EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_vg_parent_image EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_lock_surface
Registering ResourceManager for type Texture
OverlayElementFactory for type Panel registered.
OverlayElementFactory for type BorderPanel registered.
OverlayElementFactory for type TextArea registered.
Registering ResourceManager for type Font
GLES2RenderSystem::_createRenderWindow "SCOL_buffer_1", 800x480 windowed miscParams: externalWindowHandle=90396416
GL_VERSION = 2.0.0.0
GL_VENDOR = Broadcom
GL_RENDERER = VideoCore IV HW
GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
*** OpenGL ES 2.x Renderer Started ***
Shading language version: OpenGL ES GLSL ES 1.00
Registering ResourceManager for type GpuProgram
GL ES 2: Using FBOs for rendering to textures
FBO PF_R5G6B5 depth/stencil support: D0S0 D0S8 D16S0 D24S0 D24S8 D32S0 D32S8
FBO PF_B8G8R8 depth/stencil support: D0S0 D0S8 D16S0 D24S0 D24S8 D32S0 D32S8
FBO PF_A8B8G8R8 depth/stencil support: D0S0 D0S8 D16S0 D24S0 D24S8 D32S0 D32S8
FBO PF_X8B8G8R8 depth/stencil support: D0S0 D0S8 D16S0 D24S0 D24S8 D32S0 D32S8
glGetError 0x500
[GLES2] : Valid FBO targets PF_R5G6B5 PF_B8G8R8 PF_A8B8G8R8 PF_X8B8G8R8
RenderSystem capabilities
RenderSystem Name: OpenGL ES 2.x Rendering Subsystem
GPU Vendor: unknown
Device Name: VideoCore IV HW
Driver Version: 2.0.0.0
* Fixed function pipeline: no
* Anisotropic texture filtering: no
* Cube mapping: yes
* Hardware stencil buffer: yes
- Stencil depth: 8
- Two sided stencil support: yes
- Wrap stencil values: yes
* 32-bit index buffers: no
* Vertex programs: yes
* Number of floating-point constants for vertex programs: 136
* Number of integer constants for vertex programs: 136
* Number of boolean constants for vertex programs: 136
* Fragment programs: yes
* Number of floating-point constants for fragment programs: 136
* Number of integer constants for fragment programs: 136
* Number of boolean constants for fragment programs: 136
* Geometry programs: no
* Number of floating-point constants for geometry programs: 24423
* Number of integer constants for geometry programs: 24941
* Number of boolean constants for geometry programs: 27506
* Tessellation Hull programs: no
* Number of floating-point constants for tessellation hull programs: 58092
* Number of integer constants for tessellation hull programs: 57115
* Number of boolean constants for tessellation hull programs: 24170
* Tessellation Domain programs: no
* Number of floating-point constants for tessellation domain programs: 62878
* Number of integer constants for tessellation domain programs: 20750
* Number of boolean constants for tessellation domain programs: 48322
* Compute programs: no
* Number of floating-point constants for compute programs: 24021
* Number of integer constants for compute programs: 29986
* Number of boolean constants for compute programs: 4757
* Supported Shader Profiles: glsles
* Texture Compression: yes
- DXT: no
- VTC: no
- PVRTC: no
- ATC: no
- ETC1: yes
- ETC2: no
- BC4/BC5: no
- BC6H/BC7: no
- ASTC: no
- Mipmaps for compressed formats: no
* Hardware Occlusion Query: no
* User clip planes: no
* VET_UBYTE4 vertex element type: yes
* Infinite far plane projection: yes
* Hardware render-to-texture: yes
* Floating point textures: no
* Non-power-of-two textures: yes
* 1d textures: yes
* Volume textures: no
* Multiple Render Targets: 1
- With different bit depths: no
* Point Sprites: yes
* Hardware Gamma: no
* Extended point parameters: yes
* Max Point Size: 0
* Vertex texture fetch: no
* Number of texture units: 8
* Number of vertex attributes: 8
* Stencil buffer depth: 8
* Number of vertex blend matrices: 0
* Render to Vertex Buffer : no
* Hardware Atomic Counters: no
* PBuffer support: no
* Vertex Array Objects: no
* Separate shader objects: no
* GLSL SSO redeclare interface block: no
* Debugging/ profiling events: no
* Map buffer storage: no
* Quad Buffer: no
DefaultWorkQueue('Root') initialising on thread 71cff3d0.
DefaultWorkQueue('Root')::WorkerFunc - thread 6cea63d0 starting.
DefaultWorkQueue('Root')::WorkerFunc - thread 6b2ff3d0 starting.
DefaultWorkQueue('Root')::WorkerFunc - thread 6c6a63d0 starting.
DefaultWorkQueue('Root')::WorkerFunc - thread 6bcff3d0 starting.
Particle Renderer Type 'billboard' registered
SceneManagerFactory for type 'OctreeSceneManager' registered.
Creating resource group SO3/Internal/DynResource
Creating resource group SO3/Internal/GlobalPool
Creating resource group Hydrax
Creating resource group SkyX
Creating resource group SO3/Internal/EntitySelector
Added resource location 'ogre_redist/hydrax.zip' of type 'Zip' to resource group 'Hydrax' with recursive option
Added resource location 'ogre_redist/skyx.zip' of type 'Zip' to resource group 'SkyX' with recursive option
Added resource location 'ogre_redist/so3selectionbuffer.zip' of type 'Zip' to resource group 'SO3/Internal/EntitySelector' with recursive option
Added resource location 'ogre_redist/ogrecore.zip' of type 'Zip' to resource group 'SO3/Internal' with recursive option
Added resource location 'ogre_redist/fonts.zip' of type 'Zip' to resource group 'SO3/Internal' with recursive option
Added resource location 'ogre_redist/rtshaderlib.zip' of type 'Zip' to resource group 'SO3/Internal' with recursive option
Parsing scripts for resource group Autodetect
Finished parsing scripts for resource group Autodetect
Creating resources for group Autodetect
All done
Parsing scripts for resource group General
Finished parsing scripts for resource group General
Creating resources for group General
All done
Parsing scripts for resource group Hydrax
Finished parsing scripts for resource group Hydrax
Creating resources for group Hydrax
All done
Parsing scripts for resource group Internal
Finished parsing scripts for resource group Internal
Creating resources for group Internal
All done
Parsing scripts for resource group SO3/Internal
Parsing script pssm.program
Parsing script StdQuad_vp.program
Parsing script ShadowReceiver.program
Parsing script ShadowCaster.program
Parsing script overlay.program
Parsing script linecolor.program
Parsing script SecurityCam.program
Parsing script linecustomcolor.program
Parsing script pssm.material
Parsing script oculus.material
Parsing script oculus2.material
Parsing script OgreCore.material
Parsing script OgreProfiler.material
Parsing script Stereoscopy.material
Parsing script hdr.material
High-level program 'Ogre/Compositor/HDR/finalLuminence_FP_GLSLES' is not supported: Failed to preprocess shader Ogre/Compositor/HDR/finalLuminence_FP_GLSLES
Compiler error: invalid parameters in hdr/hdr.material(282): Named constants have not been initialised, perhaps a compile error.
Parsing script LigthShafts.material
Parsing script ShadowReceiver.material
Parsing script default.material
Parsing script ASCII.material
Parsing script BlackAndWhite.material
Parsing script Bloom.material
Parsing script Bloom2.material
Parsing script DOF.material
Parsing script Embossed.material
Parsing script glass.material
Parsing script HeatVision.material
Parsing script Invert.material
Parsing script Laplace.material
Parsing script NightVision.material
Parsing script OldMovie.material
Parsing script OldTV.material
Parsing script Posterize.material
Parsing script RadialBlur.material
Parsing script securitycam.material
Parsing script SharpenEdges.material
Parsing script Swizzle.material
Parsing script Tiling.material
Parsing script DualQuaternionSkinning_Shadow.material
Parsing script HardwareSkinningShadow.material
Parsing script RTShaderSystem.material
Parsing script TriplanarTexturing.material
Parsing script oculus.compositor
Parsing script Examples.compositor
Parsing script securitycam.compositor
Finished parsing scripts for resource group SO3/Internal
Creating resources for group SO3/Internal
All done
Parsing scripts for resource group SO3/Internal/DynResource
Finished parsing scripts for resource group SO3/Internal/DynResource
Creating resources for group SO3/Internal/DynResource
All done
Parsing scripts for resource group SO3/Internal/EntitySelector
Parsing script entitySelectorColor.program
Parsing script entitySelectorColor.material
Finished parsing scripts for resource group SO3/Internal/EntitySelector
Creating resources for group SO3/Internal/EntitySelector
All done
Parsing scripts for resource group SO3/Internal/GlobalPool
Finished parsing scripts for resource group SO3/Internal/GlobalPool
Creating resources for group SO3/Internal/GlobalPool
All done
Parsing scripts for resource group SO3/Internal/Widgets/BitmapWidget
Finished parsing scripts for resource group SO3/Internal/Widgets/BitmapWidget
Creating resources for group SO3/Internal/Widgets/BitmapWidget
All done
Parsing scripts for resource group SkyX
Parsing script SkyX.material
Finished parsing scripts for resource group SkyX
Creating resources for group SkyX
All done
Creating resource group SO3/Internal/EntitySelector/SCOL_buffer_1
Creating resource group 0.mainGeneral
Added resource location '/usr/share/simulacrum2/partition/' of type 'ScolFileSystem' to resource group '0.mainGeneral'
Creating resource group 0.mainV3DdefaultResources
Added resource location '/usr/share/simulacrum2/partition/' of type 'ScolFileSystem' to resource group '0.mainV3DdefaultResources'
Texture: blackpix.jpg: Loading 1 faces(PF_B8G8R8,1x1x1) Internal format is PF_B8G8R8,1x1x1.
Material scheme switch from Default to ShaderGeneratorDefaultScheme on material : SO3/Internal/Widgets/BitmapWidget/Overlays/Panels/Materials/Loading
Material scheme switch from ShaderGeneratorDefaultScheme to ShaderGeneratorDefaultScheme on material : SO3/Internal/Widgets/BitmapWidget/Overlays/Panels/Materials/Loading
GLSL ES compiled: SO3/VS/OVERLAY_GLSLES
Compiled
GLSL ES compiled: SO3/FP/OVERLAY_GLSLES
Compiled
Unhandled Pixel format: 0x8d48
Creating resource group 0.mainScene
Added resource location '/usr/share/simulacrum2/partition/' of type 'ScolFileSystem' to resource group '0.mainScene'
SO3 EXCEPTION(SExceptionInvalidParameters): SSAO technique, not supported by the graphic card! in SSsaoHandler::SeTechniqueParameterValue at /home/pi/Documents/scol-svn/trunk/scol/plugins/so3engine/src/SO3Renderer/SO3SsaoHandler.cpp (line 2654)
Mesh: Loading /usr/share/simulacrum2/partition/assets/models/converted/balls3/meshes/balls3_a17.mesh.
Texture: assets/models/converted/balls3/textures/8.JPG: Loading 1 faces(PF_B8G8R8,8704x4352x1) with 13 hardware generated mipmaps from Image. Internal format is PF_B8G8R8,8704x4352x1.
Mesh: Loading /usr/share/simulacrum2/partition/assets/models/converted/balls3/meshes/balls3_b21.mesh.
Texture: assets/models/converted/balls3/textures/4.JPG: Loading 1 faces(PF_B8G8R8,8704x4352x1) with 13 hardware generated mipmaps from Image. Internal format is PF_B8G8R8,8704x4352x1.
Mesh: Loading /usr/share/simulacrum2/partition/assets/models/converted/balls3/meshes/balls3_c25.mesh.
Texture: assets/models/converted/balls3/textures/9.jpeg: Loading 1 faces(PF_B8G8R8,4608x2304x1) with 12 hardware generated mipmaps from Image. Internal format is PF_B8G8R8,4608x2304x1.
Mesh: Loading /usr/share/simulacrum2/partition/assets/models/converted/balls3/meshes/balls3_d29.mesh.
Texture: assets/models/converted/balls3/textures/2.JPG: Loading 1 faces(PF_B8G8R8,8704x4352x1) with 13 hardware generated mipmaps from Image. Internal format is PF_B8G8R8,8704x4352x1.
Mesh: Loading /usr/share/simulacrum2/partition/assets/models/converted/balls3/meshes/balls3_e33.mesh.
Texture: assets/models/converted/balls3/textures/11.jpeg: Loading 1 faces(PF_B8G8R8,4608x2304x1) with 12 hardware generated mipmaps from Image. Internal format is PF_B8G8R8,4608x2304x1.
Mesh: Loading /usr/share/simulacrum2/partition/assets/models/converted/balls3/meshes/balls3_f37.mesh.
Texture: assets/models/converted/balls3/textures/6.JPG: Loading 1 faces(PF_B8G8R8,8704x4352x1) with 13 hardware generated mipmaps from Image. Internal format is PF_B8G8R8,8704x4352x1.
Mesh: Loading /usr/share/simulacrum2/partition/assets/models/converted/balls3/meshes/balls3_g41.mesh.
Texture: assets/models/converted/balls3/textures/16.jpeg: Loading 1 faces(PF_B8G8R8,4608x2304x1) with 12 hardware generated mipmaps from Image. Internal format is PF_B8G8R8,4608x2304x1.
Mesh: Loading /usr/share/simulacrum2/partition/assets/models/converted/balls3/meshes/balls3_h45.mesh.
Texture: assets/models/converted/balls3/textures/13.jpeg: Loading 1 faces(PF_B8G8R8,4608x2304x1) with 12 hardware generated mipmaps from Image. Internal format is PF_B8G8R8,4608x2304x1.
Mesh: Loading /usr/share/simulacrum2/partition/assets/models/converted/balls3/meshes/balls3_i49.mesh.
Texture: assets/models/converted/balls3/textures/12.jpeg: Loading 1 faces(PF_B8G8R8,4608x2304x1) with 12 hardware generated mipmaps from Image. Internal format is PF_B8G8R8,4608x2304x1.
Mesh: Loading /usr/share/simulacrum2/partition/assets/models/converted/balls3/meshes/balls3_j53.mesh.
Texture: assets/models/converted/balls3/textures/7.JPG: Loading 1 faces(PF_B8G8R8,8704x4352x1) with 13 hardware generated mipmaps from Image. Internal format is PF_B8G8R8,8704x4352x1.
Mesh: Loading /usr/share/simulacrum2/partition/assets/models/converted/balls3/meshes/balls3_k57.mesh.
Texture: assets/models/converted/balls3/textures/15.jpeg: Loading 1 faces(PF_B8G8R8,4608x2304x1) with 12 hardware generated mipmaps from Image. Internal format is PF_B8G8R8,4608x2304x1.
Mesh: Loading /usr/share/simulacrum2/partition/assets/models/converted/balls3/meshes/balls3_l61.mesh.
Texture: assets/models/converted/balls3/textures/14.jpeg: Loading 1 faces(PF_B8G8R8,4608x2304x1) with 12 hardware generated mipmaps from Image. Internal format is PF_B8G8R8,4608x2304x1.
Mesh: Loading /usr/share/simulacrum2/partition/assets/models/converted/balls3/meshes/balls3_m65.mesh.
Texture: assets/models/converted/balls3/textures/10.jpeg: Loading 1 faces(PF_B8G8R8,4608x2304x1) with 12 hardware generated mipmaps from Image. Internal format is PF_B8G8R8,4608x2304x1.
Mesh: Loading /usr/share/simulacrum2/partition/assets/models/converted/balls3/meshes/balls3_n69.mesh.
Mesh: Loading /usr/share/simulacrum2/partition/assets/models/converted/balls3/meshes/balls3_o73.mesh.
Texture: assets/models/converted/balls3/textures/1.JPG: Loading 1 faces(PF_B8G8R8,8704x4352x1) with 13 hardware generated mipmaps from Image. Internal format is PF_B8G8R8,8704x4352x1.
Mesh: Loading /usr/share/simulacrum2/partition/assets/models/converted/balls3/meshes/balls3_p77.mesh.
Texture: assets/models/converted/balls3/textures/3.JPG: Loading 1 faces(PF_B8G8R8,8704x4352x1) with 13 hardware generated mipmaps from Image. Internal format is PF_B8G8R8,8704x4352x1.
Mesh: Loading /usr/share/simulacrum2/partition/assets/models/converted/balls4/meshes/balls4_a17.mesh.
Texture: assets/models/converted/balls4/textures/8.JPG: Loading 1 faces(PF_B8G8R8,8704x4352x1) with 13 hardware generated mipmaps from Image. Internal format is PF_B8G8R8,8704x4352x1.
Mesh: Loading /usr/share/simulacrum2/partition/assets/models/converted/balls4/meshes/balls4_b21.mesh.
Texture: assets/models/converted/balls4/textures/4.JPG: Loading 1 faces(PF_B8G8R8,8704x4352x1) with 13 hardware generated mipmaps from Image. Internal format is PF_B8G8R8,8704x4352x1.
Mesh: Loading /usr/share/simulacrum2/partition/assets/models/converted/balls4/meshes/balls4_c25.mesh.
Texture: assets/models/converted/balls4/textures/9.jpeg: Loading 1 faces(PF_B8G8R8,4608x2304x1) with 12 hardware generated mipmaps from Image. Internal format is PF_B8G8R8,4608x2304x1.
Mesh: Loading /usr/share/simulacrum2/partition/assets/models/converted/balls4/meshes/balls4_d29.mesh.
Texture: assets/models/converted/balls4/textures/2.JPG: Loading 1 faces(PF_B8G8R8,8704x4352x1) with 13 hardware generated mipmaps from Image. Internal format is PF_B8G8R8,8704x4352x1.
Mesh: Loading /usr/share/simulacrum2/partition/assets/models/converted/balls4/meshes/balls4_e33.mesh.
Texture: assets/models/converted/balls4/textures/11.jpeg: Loading 1 faces(PF_B8G8R8,4608x2304x1) with 12 hardware generated mipmaps from Image. Internal format is PF_B8G8R8,4608x2304x1.
Mesh: Loading /usr/share/simulacrum2/partition/assets/models/converted/balls4/meshes/balls4_f37.mesh.
Texture: assets/models/converted/balls4/textures/6.JPG: Loading 1 faces(PF_B8G8R8,8704x4352x1) with 13 hardware generated mipmaps from Image. Internal format is PF_B8G8R8,8704x4352x1.
Mesh: Loading /usr/share/simulacrum2/partition/assets/models/converted/balls4/meshes/balls4_g41.mesh.
Texture: assets/models/converted/balls4/textures/16.jpeg: Loading 1 faces(PF_B8G8R8,4608x2304x1) with 12 hardware generated mipmaps from Image. Internal format is PF_B8G8R8,4608x2304x1.
Mesh: Loading /usr/share/simulacrum2/partition/assets/models/converted/balls4/meshes/balls4_h45.mesh.
Texture: assets/models/converted/balls4/textures/13.jpeg: Loading 1 faces(PF_B8G8R8,4608x2304x1) with 12 hardware generated mipmaps from Image. Internal format is PF_B8G8R8,4608x2304x1.
Mesh: Loading /usr/share/simulacrum2/partition/assets/models/converted/balls4/meshes/balls4_i49.mesh.
Texture: assets/models/converted/balls4/textures/12.jpeg: Loading 1 faces(PF_B8G8R8,4608x2304x1) with 12 hardware generated mipmaps from Image. Internal format is PF_B8G8R8,4608x2304x1.
Mesh: Loading /usr/share/simulacrum2/partition/assets/models/converted/balls4/meshes/balls4_j53.mesh.
Texture: assets/models/converted/balls4/textures/7.JPG: Loading 1 faces(PF_B8G8R8,8704x4352x1) with 13 hardware generated mipmaps from Image. Internal format is PF_B8G8R8,8704x4352x1.
Mesh: Loading /usr/share/simulacrum2/partition/assets/models/converted/balls4/meshes/balls4_k57.mesh.
Texture: assets/models/converted/balls4/textures/15.jpeg: Loading 1 faces(PF_B8G8R8,4608x2304x1) with 12 hardware generated mipmaps from Image. Internal format is PF_B8G8R8,4608x2304x1.
Mesh: Loading /usr/share/simulacrum2/partition/assets/models/converted/balls4/meshes/balls4_l61.mesh.
Texture: assets/models/converted/balls4/textures/14.jpeg: Loading 1 faces(PF_B8G8R8,4608x2304x1) with 12 hardware generated mipmaps from Image. Internal format is PF_B8G8R8,4608x2304x1.
Mesh: Loading /usr/share/simulacrum2/partition/assets/models/converted/balls4/meshes/balls4_m65.mesh.
Texture: assets/models/converted/balls4/textures/10.jpeg: Loading 1 faces(PF_B8G8R8,4608x2304x1) with 12 hardware generated mipmaps from Image. Internal format is PF_B8G8R8,4608x2304x1.
Mesh: Loading /usr/share/simulacrum2/partition/assets/models/converted/balls4/meshes/balls4_n69.mesh.
Mesh: Loading /usr/share/simulacrum2/partition/assets/models/converted/balls4/meshes/balls4_o73.mesh.
Texture: assets/models/converted/balls4/textures/1.JPG: Loading 1 faces(PF_B8G8R8,8704x4352x1) with 13 hardware generated mipmaps from Image. Internal format is PF_B8G8R8,8704x4352x1.
Mesh: Loading /usr/share/simulacrum2/partition/assets/models/converted/balls4/meshes/balls4_p77.mesh.
Texture: assets/models/converted/balls4/textures/3.JPG: Loading 1 faces(PF_B8G8R8,8704x4352x1) with 13 hardware generated mipmaps from Image. Internal format is PF_B8G8R8,8704x4352x1.
mmal: mmal_vc_port_enable: failed to enable port vc.ril.camera:out:1(BGR3): ENOMEM
mmal: mmal_port_enable: failed to enable port vc.ril.camera:out:1(BGR3)(0x69a7b780) (ENOMEM)
camera video callback2 erroropen Failed to create camera component/home/pi/Documents/scol-svn/trunk/scol/plugins/bitmapToolkit/src/raspicam/private_impl.cpp 102
mmal: mmal_port_enable: failed to enable port vc.ril.camera:out:1(BGR3)(0x69a7b380) (ENOMEM)
mmal: mmal_port_enable: failed to enable port vc.ril.camera:out:1(BGR3)(0x69a7af80) (ENOMEM)
mmal: mmal_port_enable: failed to enable port vc.ril.camera:out:1(BGR3)(0x69a7adf0) (ENOMEM)
mmal: mmal_port_enable: failed to enable port vc.ril.camera:out:1(BGR3)(0x69a7aae0) (ENOMEM)
mmal: mmal_port_enable: failed to enable port vc.ril.camera:out:1(BGR3)(0x69a7b1b0) (ENOMEM)
mmal: mmal_port_enable: failed to enable port vc.ril.camera:out:1(BGR3)(0x69a7b6f0) (ENOMEM)
AL lib: (EE) ALCplaybackAlsa_mixerProc: Wait timeout... buffer size too low?
Destroying resource group 0.mainGeneral
Unloading resource group 0.mainGeneral
Finished unloading resource group 0.mainGeneral
Unloading resource group SO3/Internal/EntitySelector/SCOL_buffer_1
Finished unloading resource group SO3/Internal/EntitySelector/SCOL_buffer_1
Clearing resource group SO3/Internal/EntitySelector/SCOL_buffer_1
Finished clearing resource group SO3/Internal/EntitySelector/SCOL_buffer_1
Destroying resource group SO3/Internal/EntitySelector/SCOL_buffer_1
Unregistering ResourceManager for type Font
Destroying resource group SO3/Internal/Widgets/BitmapWidget
Unloading resource group SO3/Internal/Widgets/BitmapWidget
Finished unloading resource group SO3/Internal/Widgets/BitmapWidget
DefaultWorkQueue('Root') shutting down on thread 71cff3d0.
DefaultWorkQueue('Root')::WorkerFunc - thread 6cea63d0 stopped.
DefaultWorkQueue('Root')::WorkerFunc - thread 6b2ff3d0 stopped.
DefaultWorkQueue('Root')::WorkerFunc - thread 6c6a63d0 stopped.
DefaultWorkQueue('Root')::WorkerFunc - thread 6bcff3d0 stopped.
*-*-* OGRE Shutdown
Unregistering ResourceManager for type Compositor
Unregistering ResourceManager for type Skeleton
Unregistering ResourceManager for type Mesh
Unregistering ResourceManager for type HighLevelGpuProgram
Unregistering ResourceManager for type GpuProgram
Unregistering ResourceManager for type Texture
Unregistering ResourceManager for type Material
AL lib: (EE) alc_cleanup: 1 device not closed
