Candyjet
Raspistill parameter Question
Sun Jan 21, 2018 4:31 pm
I am trying to turn off the AWB for my camera, using the raspistill command.
I have tried all possibilities of brackets, off, etc.
eg.
What it the correct syntax for the command?
thanks
CJ
B.Goode
Re: Raspistill parameter Question
Sun Jan 21, 2018 5:05 pm
Raspberry Pi Foundation documentation is here: https://www.raspberrypi.org/documentati ... /camera.md
I think each option needs to be paired with its setting.
So I would try:
raspistill --output cam.jpg --awb off
(But I don't have a camera connected to check: that's just based on reading the docs... )
ethanol100
Sun Jan 21, 2018 5:38 pm
You need to specify the awb gains if you want to use -awb off:
You can take a picture with raspistill and look at the jpeg to get which values for the gains the camera would chose for the white balance:
strings test.jpg | grep gain
this will return for example:
ev=-1 mlux=-1 exp=62979 ag=542 focus=255 gain_r=0.777 gain_b=1.218  ...
in this case -awbg 0.777,1.218 would be a good starting value.
Candyjet
Sun Jan 21, 2018 8:20 pm
Thanks for the replies.
I am now not sure where to go from here.
I am trying to use a NoIR camera and IR light as a motion sensing camera. I have the camera and light all set up and the program running. IR photos are working fine.
The program takes pictures and compares the results. If a number of pixels have changed, it is interpreted as motion, and a copy of the photo is stored.
The problem I have is that the hue of the photos appears to keep changing. This is interpreted as changes in pixels, and therefore motion, when in fact no motion has occurred.
I therefore thought that using the awb command would solve the problem.
Am I on the right track, or barking up the wrong tree completely?
Thanks,
CJ
Mon Jan 22, 2018 10:25 am
You could try just using the luminance channel of a YUV image (ie Y). Luminance is less likely to change like this.
IIRC, motion detection usually uses just the Y channel. For example, in H264 encoding, it uses the Y channel to work out similar blocks.
See raspistillyuv for details.
Return to “Camera board”
