bduke
CAMERA_0_UNICAM_PORT definition
Sat Dec 09, 2017 4:09 am
I'd like to confirm my understanding about the camera pinout and device tree setup. Please note that I am using a CM3 with a custom IMX219 sensor, not the standard Pi camera PCB. The instructions posted here: https://www.raspberrypi.org/documentati ... -camera.md are great. My application has some hardware differences, however, and I want to make sure my pinmux is correct.
I have the camera sensor data/clock lines connected to the CAM0 pins on the SOC. I have a GPIO (CAMERA_0_SHUTDOWN) going to the camera reset line. I also have CAMERA_0_UNICAM_PORT set to zero.
I am assuming that CAMERA_0_UNICAM_PORT indicates which data/clock pins should be used for this camera. So, if I set UNICAM_PORT to zero, the driver will use CAM0_DN0/CAM0_CP/CAM0_CN/CAM0_DP1/CAM0_DN1 for this camera. Is this correct?
(Example pinmux, note I've been forcing the reset pin "on" to keep the camera out of reset for testing)
   pins_cm3 {
      pin_config {
        // Omitted defaults for brevity...
        [email protected]  { function = "input";  termination = "pull_up";    }; // CAMERA 0 I2C0 SDA
        [email protected]  { function = "input";  termination = "pull_up";    }; // CAMERA 0 I2C0 SCL
        [email protected]  { function = "output"; termination = "no_pulling"; }; // CAMERA 0 LED
        [email protected]  { function = "output"; termination = "no_pulling"; polarity = "active_high"; startup_state = "active";}; // CAMERA 0 SHUTDOWN
        //other omitted for brevity
              }; // pin_config
      pin_defines {
        //Omitted for brevity...
        [email protected]_CAMERAS {
          type = "internal";
          number = <1>;
        [email protected]_0_LED {
          type = "internal";
          number = <5>;
        [email protected]_0_SHUTDOWN {
          type = "internal";
          number = <13>;
        [email protected]_0_UNICAM_PORT {
          type = "internal";
          number = <0>;
        [email protected]_0_I2C_PORT {
          type = "internal";
          number = <0>;
        [email protected]_0_SDA_PIN {
          type = "internal";
          number = <0>;
        [email protected]_0_SCL_PIN {
          type = "internal";
          number = <1>;
      }; // pin_defines
    }; // pins_cm3
6by9
Re: CAMERA_0_UNICAM_PORT definition
Sat Dec 09, 2017 7:44 am
Yes, camera_N_unicam_port sets up which set of clock and data pins are used for the csi data.
It is a little quirky that the default defines CAM1 socket as camera 0, but that's due to a copy/paste from the standard Pis where they only have one camera connector and it is unicam 1.
bduke
Mon Dec 11, 2017 5:13 am
Thanks for answering the question. It's helping my troubleshooting efforts. I understand the CAMERA0,CAMERA1 confusion, but your answer helps to clarify it. The UNIPORT setting is really the key to making sure you're using the correct pins.
Return to “Camera board”
