camera not working
Posted: Mon Dec 04, 2017 7:08 am
by MinecraftTom16
I was just making a laptop, with the camera module as a webcam, yesterday it still worked, but today I typed the normal $ sudo raspi config and this came up:
mmal: mmal_vc_component_enable: failed to enable component: ENOSPC
mmal: camera component couldn't be enabled
mmal: main: Failed to create camera component
mmal: Failed to run camera app. Please check for firmware updates
I updated it with
$ sudo rpi-update
just now, but no luck.
please can you tell me what I'm missing?
I'm hoping for a fast answer, but do what you can, please help
Re: camera not working
Posted: Mon Dec 04, 2017 7:48 am
by DougieLawson
Have you added
gpu_mem=128
start_x=1
in /boot/config.txt?
Posted: Tue Dec 05, 2017 1:35 am
by MinecraftTom16
no, but can you explain how, because I never edit those files; I never need to. Please can you tell me how?
Posted: Tue Dec 05, 2017 6:47 am
by 6by9
Easier to use raspi-config as stated in the https://www.raspberrypi.org/documentati ... /camera.md
Enabling the camera in there makes the changes in config.txt for you.
Posted: Tue Dec 12, 2017 8:16 am
by MinecraftTom16
I did just that: in terminal I typed
$ sudo raspi-config
and enabled the camera from interfacing options, and rebooted, but it still didn´t work.
Posted: Tue Dec 12, 2017 12:31 pm
by MinecraftTom16
also the gpu memory split right now is set to 128.
Posted: Tue Dec 12, 2017 12:35 pm
by SkyRise
If it was working before, it may be that the ribbon cable has come loose (at either end)
Posted: Tue Dec 12, 2017 12:36 pm
by MinecraftTom16
and i just checked the config.txt file, and those 2 lines you mentioned are there(not commented) and exactly the same.
Posted: Tue Dec 12, 2017 12:37 pm
by MinecraftTom16
oh ive checked the ribbon cable and its not that
Posted: Tue Dec 12, 2017 1:37 pm
by 6by9
vcgencmd get_camera
It'll reply with something like
supported=1 detected=1
If supported=0 then you haven't enabled it, or it is otherwise disabled in software.
If detected=0 then the Pi can't talk to the camera. Check the ribbon cable again, and that the little connector between the camera and the PCB is fully home. (*)
If detected=1 but you're still getting errors from raspistill/vid, then something funny is going on in the software.
(*) As a secondary test you could add "dtparam=i2c_vc=on" to /boot/config.txt, "raspi-gpio set 41 dh", and then run "sudo i2cdetect -y 0" to see if the I2C device is responding. The V2 camera should respond on 0x10 and 0x64, V1 responds on 0x36. The raspi-gpio command is based on a B+ or Pi2. Pi3 needs alternate settings.
Posted: Wed Dec 13, 2017 12:21 pm
by MinecraftTom16
I got
, so i dont know whats happening. the raspistill/vid is still not working.
does somebody know by any chance how to reinstall the software?
or a better solution if there is. thx
Posted: Wed Dec 13, 2017 2:21 pm
by 6by9
Add "start_debug=1" to the end of /boot/config.txt and reboot.
Run raspistill or raspivid
Run "sudo vcdbg log assert". If it includes
049839.200: assert( 0 ) failed; ../../../../../vcfw/drivers/device/camera/imx219.c::imx219_open line 431 rev 89a5328
vcdbg_ctx_get_dump_stack: dump_stack failed
then I'm afraid you probably have a faulty module.
There haven't been any changes around that area of the camera stack that I'm aware of recently.
Resetting to the standard Raspbian firmware would be a sensible step ("sudo apt-get update" "sudo apt-get install --reinstall raspberrypi-bootloader"). rpi-update is only recommended for those really wanting the cutting edge firmware/kernel, and that they accept there may be regressions.
Posted: Sat Dec 29, 2018 9:40 pm
by jamesdinsmore
I had a funny issue that relates to this. I had 2 surveillance Pi camera that were working until I purchased acrylic camera cases for them. The case itself pushed on the camera element's micro-connector so the camera was not being detected. Then a reboot was needed to make the system work as before. Maybe this will help somebody.
Posted: Wed Feb 27, 2019 9:16 pm
by pulkit2328
I am getting supported=1 detected=0
I have triple checked both ends of the cable and SUNNY too.
Camera was working yesterday but today it is showing NOT ENABLED and OUT OF MEMORY.
Posted: Thu Mar 07, 2019 5:14 pm
by cyborg07
Same was the issue with me today. I doubt it is the broken flex cable.I am moving to USB cam now.
anything new on your side?
Posted: Thu Mar 07, 2019 5:36 pm
by pulkit2328
I have ordered a ribbon cable lets see if this problem goes away with a new cable.
My application requires a smaller camera so cant use a USB one.
Posted: Fri Mar 29, 2019 1:06 pm
by pulkit2328
Camera is working fine with the new cable.
Posted: Tue Jan 21, 2020 4:37 pm
by battal51280
i have a really weird situation, vcgencmd shows detected=1 while camera is not connected and camera name is toshh2c
again camera not connected, csi port is empty, rebooted after disconnecting camera.
same thing happens when camera connected, maybe csi port on raspberry could be broken but i can't see any defect on port
~# raspistill -v -f
"raspistill" Camera App (commit a14ee020d361 Tainted)
Camera Name toshh2c
Width 1920, Height 1080, filename (null)
Using camera 0, sensor mode 0
GPS output Disabled
Quality 85, Raw no
Thumbnail enabled Yes, width 64, height 48, quality 35
Time delay 5000, Timelapse 0
Link to latest frame enabled no
Full resolution preview No
Capture method : Single capture
Preview Yes, Full screen Yes
Preview window 0,0,1024,768
Opacity 255
Sharpness 0, Contrast 0, Brightness 50
Saturation 0, ISO 0, Video Stabilisation No, Exposure compensation 0
Exposure Mode 'auto', AWB Mode 'auto', Image Effect 'none'
Flicker Avoid Mode 'off'
Metering Mode 'average', Colour Effect Enabled No with U = 128, V = 128
Rotation 0, hflip No, vflip No
ROI x 0.000000, y 0.000000, w 1.000000 h 1.000000
Posted: Tue Jan 21, 2020 5:52 pm
by jamesh
~# raspistill -v -f
Camera Name toshh2c
GPS output Disabled
Quality 85, Raw no
Opacity 255
Please start a new thread for a new problem.
Posted: Mon Feb 03, 2020 8:41 pm
by vaden_arth
My camera had the smaller lens board connected the other way round.
i.e the lens board was hanging outside the camera board , rather than on the board , like how it is supposed to be
Do check that too, I was stuck with this issue for a long time now , this is my first time using rasp pi
