Has anyone tried and implemented successfully UV4L and Jitsi Meet extension? I am trying to do the same and am not able to join the room.
PFA the screenshot of the settings I am using. The port number seems to off. Any other reason why this could be happening? Basically after I open the room URL in my browser and then pressing the JOIN button from the UV4L Jitsi extension, I can see no error from this side, but the raspberry pi isn't joining the room at the URL https://meet.jit.si/testroom12334
I know that the UV4L installation was successful because the webrtc extension seems to be working fine.
UV4L : Jitsi Meet rooms : Unable to join room
- Attachments
- Jitsi Settings
- Capture.PNG (23.58 KiB) Viewed 1877 times
- Webrtc Extension
- Capture1 copy.jpg (88.23 KiB) Viewed 1877 times
Re: UV4L : Jitsi Meet rooms : Unable to join room
I have been fighting this with the exact same results as you. The WebRTC app renders properly from the USB camera on the Raspberry Pi, but no-go with the Jitsi Meet server I run on another server in the same network.
I switched the RPI to Stretch and UV4L with same results.
I have been facing the same issue.
Did you solve it since?
Thanks.
Thanks.
2*3B at home for the kids
7*3B+ at work for serious business (gitlab-runner, broadcasting conference, openSTF server...)
Hoping to get a few hats in the following weeks
