Raspistill doesn't work but Rpi_Cam_Web_Interface does ?
Posted: Sun Aug 27, 2017 10:25 pm
by rjhazeld
I updated a pi3 with a v2 noir camera board from Jessie to stretch and afterwards raspistill resulted in:
mmal: mmal_vc_component_enable: failed to enable component: ENOSPC
mmal: camera component couldn't be enabled
mmal: main: Failed to create camera component
mmal: Failed to run camera app. Please check for firmware updates
The camera is definitely enabled. By accident I opened the Rpi_Cam_Web_Interface web page and was surprised to see the image load. I had previously run apt-get update, dist-upgrade and rpi-update.
Curious I did clean installs from Noobs on a zeroW and a 2b with the same results when I had got the Rpi_Cam_Web_Interface installed correctly (the nginx install needs rpicam amending for the php-fpm socket location used by php 7.0) .
I thought that previously I was able to use raspistill even when the Rpi_Cam_Web_Interface was running.
Is there another update I need to get raspistill working?
Re: Raspistill doesn't work but Rpi_Cam_Web_Interface does ?
Posted: Mon Aug 28, 2017 6:12 am
by 6by9
You appear to have rpi cam Web interface running. The camera only supports a single application at a time. Stop rpi cam Web interface and raspistill should work.
Posted: Mon Aug 28, 2017 3:29 pm
by rjhazeld
Doh! you are quite right stopping the Rpi_Cam_Web_Interface does allow raspistill to run properly. I guess the problem getting nginx and php working masked the fact that the underlying code was running.
