Page 2 of 2
Re: Cheap RC airplane with "outboard" Pi Zero and camera
Posted: Wed Jun 27, 2018 3:27 pm
by HermannSW
I made many more search flights with drone, found airplane on three videos.
Today I copied out the parts of those videos that showed the airplane, did crop top left 700x360 from 1280x720 frames, slowed down framerate of 30 fps to 6 fps, concatenated the videos (all with ffmpeg) and converted to animated .gif (with gifenc.sh).
First airplane enters scene from top right to middle right hidden by leaves, then plane enters frame from middle top and leaves top left, and finally plane enters from middle top and leaves middle top:
Unfortunately Iost the camera drone today as well, it flew very high, I lost sight, then it fell down and I had no idea where to search (I did hear drone hitting some tree, but had no idea of direction). I went into the wood, then smaller wood and finally near horse stable, always turning drone motors on and off. After 10 minutes I did hear the drone in trees near horse stable. I walked around the trees to ensure acoustically that drone really is somewhere in those trees and not somewhere on the ground. The small 5m diameter circle is where the airplane is in tree 20m above ground, the 10m diameter circle is where drone is in trees:
Regarding my plans wrt Pi controlling drone flight I made progress in flying drone without lipo yesterday. Finally (with thick cables) I was able to fly drone tethered with 4.19V and 8.5A, allowing for unlimited indoor flight time (after I have been told repeatedly in that thread that this is not possible). I hope these are not the last pictures of my drone:
https://forum.arduino.cc/index.php?topi ... msg3786115
Now I have to wait for FPV drone I did order 9 days ago during banggood super-sale for 20$ with free shipping to arrive.
The E52 will definitely allow for search of lost drone, and hopefully even allow to rescue RC airplane in tree 20m above ground:
https://twitter.com/HermannSW/status/10 ... 2218242049
Posted: Wed Jun 27, 2018 4:41 pm
by scotty101
You are going to buy another drone, to find a drone that was lost while finding an RC aircraft.. Perhaps you need to stop flying near trees? :lol:
I do sympathize. I lost my first RC aircraft after <5 minutes of flight time as it got caught in a sudden gust of wind.
Posted: Wed Jun 27, 2018 8:22 pm
by DougieLawson
If the trees are deciduous then it's just a case of waiting for Autumn.
Posted: Wed Jul 11, 2018 9:11 am
by HermannSW
Two days ago I did more excercise flights, with now 6 lipos much more flight time. I lost E52 drone two times in distant high grass, found it via drone AP Wifi signal strength shown in Android smartphone, details:
https://forum.arduino.cc/index.php?topi ... msg3800878
Yesterday I lost drone again in deep grass, with installed app Wifi Analyzer and enabled sound finding drone was easy (beep interval gets smaller while getting nearer to drone).
Finally I was able to loose drone in a tree :-(
This is frame of video taken from drone after hanging 6m above ground in tree:
Luckily that location was in tree with raised blind below!
I was able to sit 3m above ground on raised blind, and with arm length and a 4m stick I was able to rescue drone:
Today in the morning I did first search flights with E52 drone at group of trees with the other lost drone.
Unfortunately the E52 camera did not work well in the beginning, and finally (after more than 3*4min flight time with 3 lipos) the Android app did not even show a E52 camera video image at all :-(
Hopefully there is a simple way to fix the camera, like pressing on Raspberry v1 camera module Sunny connector ...
Posted: Thu Jul 12, 2018 7:27 am
by HermannSW
I had problems in uploading Eachine E52 .mp4 videos to youtube, youtube refused to take them.
Although .mp4 is a supported video format, youtube complained that I should use a supported format?!?!?
Yesterday I found the reason (there is an audio channel in E52 .mp4 videos) that does confuse youtube.
Since there is no microphone in E52 drone, I found easy solution in just disabling audio with ffmpeg's "-an" option.
This was first video uploaded yesterday, "Eachine E52 FPV drone free fall from more than 40m height into grass":
https://www.youtube.com/watch?v=ibJafdBGmcQ
I was able to upload the video where E52 drone ended in tree after 46 seconds using this ffmpeg command:
ffmpeg -i 20180710191321.mp4 -vcodec copy -an tree_hang.mp4
https://www.youtube.com/watch?v=NMmqbc5U3Z8
At the start of the video the tree with raised blind can be seen in detail, I did not know that drone would end up there at that point in time ... I should have let speed at 30% in Android EACHINE_UFO app and not have tried 100%.
P.S:
I did order a backup E52 yesterday, for some reason it was cheaper than even during super sale last time (20$):
https://twitter.com/HermannSW/status/10 ... 0398379008
Unfortunately today it is at 29$ again.
Posted: Thu Jul 12, 2018 6:55 pm
by HermannSW
I did this experiment as 2nd backup plan in case I cannot fix E52 drone camera.
I wanted to test whether Pi ZeroW+v1 camera+cable can replace E52 FPV camera board.
As easy test I just added it without removing existing FPV camera and board:
86.3g E52 drone
14.0g PiZeroW+v1 camera+cable
   0.6g rubber band
100.9g in total
And it really worked!
This is first time I did fly a drone in my (small) Motor Test Station (MTS).
I knew that drone is loud outdoor, indoor it feels much louder (hear into Android camera youtube video)!
This drone can carry even more easily ...
https://www.youtube.com/watch?v=7ohbj72 ... e=youtu.be
P.S:
It seems that there will be another thread 'Cheap FPV drone with "outboard" Pi Zero and camera' later ;-)
P.P.S:
Automatic E52 drone liftoff with Pi backpack, played slowed down by factor of 2:
Posted: Sat Jul 14, 2018 9:32 am
by HermannSW
I did some more small space flights in MTS and drone blades nearly killed the border Raspberry v1 camera cable (I lost a 1m v2 camera cable by an uncontrolled indoor drone flight before). So I taped and secured both camera cables in MTS flat to the borders:
Yesterday I opened the E52 drone to have a look for the camera (problems). Only 5 little screws hold everything together:
There was a small section of plastic avoiding E52 FPV camera to record downwards. Dremmel grinding disk made it go away. Now drone can record vertically downwards as well (good for lost in trees RC airplane/drone search):
Today I skipped the step of finding airplane first and did try to rescue duplicate of RC airplane (airplane pulling). 24.9g+0.7g(cable)+0.6g(rubber band)=26.2g additional load was too much, drone could not lift airplane significantly above meadow:
https://www.youtube.com/watch?v=LJIlSS9 ... e=youtu.be
From previous posting we know that E52 can lift with 14.6g backpack easily, from today we know it cannot lift with more than 25g additional load.
Perhaps a 14g wrecking ball might help rescue airplane from tree ...
P.S:
Camera seems to work better now, The FPV camera antenna was directly near the three cable connector of FPV board -- I moved it away before closing the drone again, hopefully that will have eliminated the camera problems.
P.P.S:
At least a drone with (13.1g) "wrecking ball" hanging at cable is difficult to fly, ended in hedge:
https://www.youtube.com/watch?v=biWrUJk ... e=youtu.be
P.P.P.S:
No-flight time for few weeks, details here:
https://www.youtube.com/watch?v=54bKzFrvFTQ
Posted: Mon Jul 16, 2018 8:21 pm
by HermannSW
As said in last posting P.P.P.S there is No-flight time until ordered blades will have arrived.
I did connect my Android to the E52 on weekend and found drone AP IP address to be 172.16.10.1.
I did "nmap 172.16.10.1" and found port 8888 open.
Today I googled for "eachine 172.16.10.1" and found this wonderful hackaday.io project:
"Controlling a JJRC H37 Elfie quad from a PC by adriajunyent-ferre"
https://hackaday.io/project/19680-contr ... -from-a-pc
All reverse engineering is done, pull_video.py and watch_video.py play quad video on PC using gstreamer, send_joystick.py controls quad from PC USB gamepad !
I will try whether E52 drone can be controlled the same way when back home on weekend, maybe a different magicword is needed in pull_video.py.
IF this works, then the Pi ZeroW I added as backpack to the E52 could
  • connect to E52 AP
  • control the drone
  • receive the .h264 video stream, and use gstreamer not to play video stream but to analyze and control drone based on video ...
    (Pi ZeroW as onboard drone pilot -- wireless, no soldering needed besides powering the ZeroW)
P.S:
"Logging into an Eachine E50S drone" is interesting as well:
http://yesuserserviceableparts.blogspot ... drone.html
Posted: Mon Jul 16, 2018 10:35 pm
by rodizio
You may want to have a look at this before you start re-inventing everything ;)
https://github.com/bortek/EZ-WifiBroadcast/wiki
https://www.rcgroups.com/forums/showthr ... de-easy%21
https://www.youtube.com/watch?v=bfz9F9lOMm8
https://vimeo.com/user47095683/review/2 ... b621cbaf55
Monitor mode works much better than Wifi in AP/Station mode. It uses Ralink and Atheros USB Wifi cards in monitor mode.
Somebody also made some code for the ESP32 connected via SPI to the Pi, but not sure how good that works:
https://github.com/jeanleflambeur/esp32 ... _broadcast
Posted: Tue Jul 17, 2018 1:55 pm
by HermannSW
Thanks for the links, but they are on Wifi broadcast.
For "Pi ZeroW as E52 drone pilot" wifi broadcast is not needed (in the first place).
I think these are the first three simple Pi Pilot projects.
For all Pi ZeroW connects to E52 AP after some triggering, then:
  1. "Hello World": trigger "lift off" of drone (will leave drone in 1m above ground), wait X seconds and then trigger "landing"
  2. more advanced: trigger "lift off" of drone, fly forward X seconds, fly right X seconds, fly back X seconds, fly left X seconds, trigger "landing"
  3. consume E52 FPV camera .h264 video stream, split frames with help of gstreamer pipeline, analyze frames and let ZeroW make drone fly eg. along a footpath over meadow
For 2) and 3) it is important that emergency landing by triggering that through RTC (One-key down) is always possible since fully autonomous drone flight without emergency stop option is forbidden (at least in Germany).
Posted: Mon Aug 20, 2018 3:20 pm
by HermannSW
P.S:
The ordered E52 drone arrived in Germany during my vacation, but not at home. Instead it was held in customs office in Heidelberg and I got mail that I had to show printed invoice to get it (17.06€ or 19.51$ is quite less than the price I would have to pay tax). I knew the procedure as last year a cheap caterpillar robot was held there as well:
https://forum.arduino.cc/index.php?topic=462107.0
Besides the time and money for 40km travel to Heidelberg, going there was OK. Over the years I received >300 packets from China (aliexpress and banggood), and only two packets ended up in customs office.
What I learned today is that I only got complete drone because CE marking was not only on drone box, but on drone and RTC as well.
I did test flight with new drone in house without problems. I did try to capture drone camera video from Raspberry as described here:
https://www.raspberrypi.org/forums/view ... 3#p1352563
That did not work because the drone AP IP address is not 172.16.10.1 as with the previous E52 I have, but now it is 192.168.0.1. I did change the IP addresses in pull_video.c, but that did not work either. I will have to use ettercap tool to capture traffic between new E52 drone and Android to get working pull_video.c for the new drone.
Finally I found the reason why they did hold drone at customs office -- quadcopter for 6.50$ seems declared wrong even to me:
Interesting, the packet went from China to Estonia first, and then inside EU to Germany.
Posted: Thu Aug 23, 2018 3:24 pm
by HermannSW
Besides 2nd E52 drone with 4 spare blades, 4 packets with 4 spare blades each arrived during vacation time. Will prevent no-flight time for quite some time.
Yesterday evening I did another test flight over small tree, this time more than 4 minutes without issues. Because the nearby horses did not even care on the drone I did a short (6m high) flight over the horses in that video to be able to prove that horses don't care about drones:
https://www.youtube.com/watch?v=JAtV4Ps ... e=youtu.be
After successful flight over 5m test tree I did a real search flight for the lost drone over high group of trees. It seems that E52 drone recording directed to ground found the lost white drone on top of 10m high tree. The white drone can be seen 4 times in the video, see youtube text for details. The animated .gif shows the 3rd part from 1:26-1:28min. White drone enters top view from right and leaves on left. E52 video is [email protected], but makeagif.com scales down to 320x256 only:
https://www.youtube.com/watch?v=axOSIz5 ... e=youtu.be
For doing this kind of search videos E52 altitude hold mode is really advantageous.
Next step is the rescue part of search&rescue, but we just now get change in weather pattern and it started to rain (after being always sunny with >30°C).
Posted: Sun Sep 02, 2018 8:24 pm
by ab1jx
Neat, it's easier/cheaper to read about somebody else's adventures than try it myself. I have a small drone, too small to carry a camera. It got stuck in some trees and didn't come down until spring, by then the electronics were ruined. I crash flight simulators, I wouldn't try a plane I'd spent money on.
I wonder if you could bind 2 panes together vertically and make a sort of biplane to get more lifting capability. I'm not sure how controlling them would work, maybe one could be without engines and radio, just a glider. Or scrap conventional design completely and have it emulate solar or human powered planes with long wings and small engines. I know you can buy Styrofoam in aerosol cans as building insulation, maybe you can spray it into greased molds and let it cure. Or use Balsa wood. Make a B-52 model. Flying wing? There are surveillance drones: https://en.wikipedia.org/wiki/Unmanned_aerial_vehicle
Drone technology: lightweight motors, propellers, batteries, controllers could be even more interesting if you mount those parts on a glider so lift comes from wing design instead of sheer motor power. Just looking at my dead drone here.
Oh, and you can make animated gifs with gifsicle in the Raspbian debs.
Posted: Wed Sep 05, 2018 2:09 pm
by HermannSW
... I crash flight simulators, I wouldn't try a plane I'd spent money on.
I was lucky on last Sunday recce flight with drone, drone should not be above trees when lipo is drained. After 5 long seconds of drone fall through 10m high tree it ended up on ground without any issues:
I thought of similar, connecting my two planes horizontally. Have not tried yet.
Currently I figured out that my drone is capable of carrying 18.5g of backpack load.
I did a mod to replace 12.6g upper drone shell with two small wooden bars getting another 6g of backpack weight:
https://github.com/Hermann-SW/wireless- ... e#e52-mods
I need that backpack weight
  • for Pi ZeroW as onboard drone with lipo and VL53l0x laser range sensor for "constant altitude above ground mode"
  • for (1.5g) ESP-01 with servo bomb drop mechanism (>=12g in total) to increase drop weight for freeing drone from 10m high tree
Btw, today is last day you can order the E52 drone super cheap (17.59$ with free shipping, CN/0.3MP/RTC option).
I did buy a 3rd one on weekend [as backup for my backup drone ;-)]
https://www.banggood.com/Eachine-E52-Wi ... rehouse=CN
I know, and even better with ffmpeg.
I use makeagif.com when I have youtube video, it allows to super simply cut out what I am interested and get animated .gif
I did much with gifsicle in the past.
Here you can challenge your browser with 30 animated .gifs in a single page (Shortest construction tasks map):
http://stamm-wilbrandt.de/chess/en/sct_map.html
Posted: Wed Sep 05, 2018 5:04 pm
by ab1jx
No, it needs to be vertically, at least for what I'm thinking of. Not even another plane but another wing. https://en.wikipedia.org/wiki/Lift_(force) My father used to make boomerangs by cutting them out of plywood and sanding the leading and trailing edges by eye. I've made windmill blades (which have a lift pointing downwind) by using a spreadsheet.
You could go to a building supply store and get a piece of styrofoam insulation a little thicker than your airplane wings, then mount that probably above the original wing like a biplane. I don't know the best way to shape it, a very sharp knife like an xacto or razor blade maybe, or a hot knife like on a soldering iron. It's going to tend to crumble, you want a smooth surface so the air will flow over it. The leading edge should be blunt, the trailing edge comes to a point in the back. Molding it yourself might give you more control but then you need to build molds and get the wing out afterward. A Dremel tool with its high speed might help.
There might be a better material, seems like hobby shops sell a kind of lightweight plastic foam that's easier to shape. Never got into that stuff. But if you can get more lift you can carry more stuff. And the motors and controller can stay the same. Windmillls: http://www.scoraigwind.com/
Posted: Wed Sep 05, 2018 6:30 pm
by HermannSW
Thanks for all that information, I will try after drone bromb dropped (hopefully) lost drone in 10m height and lost airplane in 20m height, and having Pi ZeroW autonomous fly the E52 drone as onboard pilot ...
What I meant by horizontally was joining my two airplanes at the wings, and fly both airplanes concurrently. In theory this should double backpack capacity (the small RC airplane weight is 23g, and it did lift and fly with 40g incl. Pi Zero and camera).
Interestingly Stratolaunch seems to follow a similar concept, they have the worlds widest airplane (117m) now:
Posted: Wed Sep 05, 2018 7:34 pm
by ab1jx
Yeah, maybe. The Solar Impulse 2 only had 1 wing too. https://www.smithsonianmag.com/innovati ... 180968000/
Posted: Sat Oct 13, 2018 8:08 pm
by HermannSW
Updates on drone/airplane rescue activities.
I made good progress in adding ESP01s powered (because that microcontroller has Wifi and weight 1.5g only) payload servo drop mechanism (SG17 servo weight is 1.7g only!) to 2nd of my three Eachine E52 drones. So yesterday I took the third E52 and made surveillance flight just to confirm white drone (lost while searching for lost yellow RC airplance) is still at top of tree where I found it. I did not do a safe flight and the drone went into the tree. I was not that lucky as the last time that happened, where drone took 5 long seconds to completely fall through tree and end at ground. This time it did fall some time, but then remained in tree :-(
Here is the updated "lost" image, colored dots are locations of yellow RC plane, white drone and red E52 drone:
Today a friend helped me, we took my 7m ladder and his 4m stick with hook at the and and went to the trees. He made ladder stay secure, I did climb up 6m, adding 2.30m of me with stretched out right arm, and 4m stick I did shake out all tree arches I could reach in the area of the tree where I had seen movement yesterday when powering up transmitter, doing calibration and then autostart. So not found or rescued, and what we know its location is higher than 12m from ground in the tree.
After I was safely on ground again, my friend did move away some meters, took a photo of the tree (that I thought to be not much higher than 10m high) and used Timber Tree Height Estimator. That proved my tree height guesses to be totally wrong, he measured 22m :-(
So red E52 drone sits in tree in height 12-18m, white drone on top at 20-22m, and yellow airplane tree is even higher, so it seems to sit in 25-30m height from ground ...
I have videos from all three E52 drones that I bought at different low price times with free shipping on banggood.com:
June 17.34€
July 17.06€
Sep 16.09€ (17.99$)
I did know that 1st E52 has 0.4MP camera and does [email protected] videos (https://github.com/Hermann-SW/wireless- ... ideo-facts).
I used "ffmpeg -i ... -hide_banner" to find out video information for the others from videos taken by them.
2nd E52 has 0.3MP camera and takes [email protected] videos.
3rd (lost yesterday) has 2.0MP camera and takes [email protected] videos.
I lost drone yesterday because I did fly way too low. Camera was directed to ground, there would have been a much easier and safer way to do surveillance flight: start on meadow, climb much higher than the trees, move over tree until seeing white drone live on Android screen and then slowly move drone downwards making sure not to get too near to the tree.
Last night I made big progress with 2nd drone and completely mounted payload drop system.
Details in this posting (and the thread postings before):
https://www.esp8266.com/viewtopic.php?f ... 604#p78604
This is first drone camera video showing remote payload drop onto target 17.5cm below:
Image Image
As some people pointed out, autumn definitely will help in getting clear view on red E52 drone lost yesterday, and the yellow airplane only seen in 3 videos from > 50 videos.
P.S:
photo used for tree height estimation; red E52 drone somewhere in top half left of main arch from here:
Posted: Sat Nov 24, 2018 9:12 pm
by HermannSW
HermannSW wrote:
Thu May 24, 2018 5:41 pm
So here after 3 frames the "same" scene appears again. I wanted to be sure and used 640x150_s tool that records every other line/column only and therefore captures with 1007fps as well. Because of the different "capturing position/time after framestart" pair this video is much better to see that indeed the propeller moves 1/3rd of a round per frame (coarser in both directions, but the 640x150 frame shown correctly represents the 640x150 from camera fov covered):
So now we can do the math and see more than 20,000rpm for the propeller:
$ bc -ql
1007/3
335.66666666666666666666
1007/3*60
20139.99999999999999999960
P.S:
Just in case my interpretation is wrong and the propeller does not 1/3rd of a round per frame, but 4/3rd, then propeller rpm would be 80,000
I did buy a digital laser photo tachometer for less than 8$, and it did travel from China to Germany in 19 days only:
https://www.aliexpress.com/item/Digital ... 90838.html
I was able to determine propeller RPM immediatly after I put a small part of reflective mark onto one side of one propeller. After I fully loaded the airplane lipo I began to record a video, too few hands but finally it worked after some tries:
https://www.youtube.com/watch?v=vYNjfm1 ... e=youtu.be
Maximal reading was 18233 rpm and constantly dropping slightly. I looked the 1fps animated .gif again and saw that after 3 frames the white marker was not exactly on same place. 3 frames do a little less than 1 complete propeller turn, so the propeller speed shown is less than the 20140 computed above. Most importantly now it is answered that indeed a single frame of 1007fps video captures roughly 1/3rd of a round and not 4/3rd (the digital tachometer measurement range is 2.5-99999 rpm).
Posted: Sat Nov 24, 2018 9:33 pm
by ab1jx
Ion propulsion, that's what you need. Measure KV instead of RPM. :)
https://news.mit.edu/2018/first-ionic-w ... parts-1121 and
http://news.mit.edu/2013/ionic-thrusters-0403
Posted: Tue Aug 13, 2019 8:29 am
by HermannSW
People have stretched this concept to the limit !
"Flex 9 is an airplane made out of 9 smaller airplanes connected at wings"
https://www.youtube.com/watch?v=mrJgoQz ... =hootsuite
