HermannSW
Re: Hardware camera sync pulses
Fri Dec 06, 2019 3:30 pm
6by9 wrote:
Tue Nov 14, 2017 5:48 pm
Start with https://github.com/raspberrypi/firmware ... t-blob.dts which is the source for the blob that is built in to the firmware.
There is a section for Pi4B, but since CAMERA_0_LED is not existent on Pi4B it states:
            [email protected]_0_LED {
               type = "absent";
Does Pi4B allow for hardware camera sync pulses as well?
If so, just according the instructions in this thread, or differently?
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/github_repo_i420toh264
https://github.com/Hermann-SW/fork-raspiraw
https://twitter.com/HermannSW
6by9
Fri Dec 06, 2019 4:07 pm
               type = "absent";
It's the same code, you just can't use it on the default as there is no LED line. The same was true on the Pi3 as the camera LED GPIO is on the GPIO expander, and the hw sync pulse GPIO MUST be an internal one.
Define it to the GPIO you want and it should work.
HermannSW
Fri Dec 06, 2019 5:59 pm
Thanks, I will try with the Pi4B.
In the meantime I switched to Pi2B and used that.
The sync pulses triggered an Arduino Uno to display "millis()" for few milliseconds on 8-digit 7-segment tube display after frame start (it acts on frame end, then waits for frame start).
That allowed to take 90fps global external shutter video with v1 camera (animation plays with 1fps):
https://forum.arduino.cc/index.php?topi ... msg4396851
HermannSW
Mon Dec 16, 2019 11:20 pm
Until today I thought that I had killed all my Pi4B GPIOs -- luckily they all do work fine:
https://www.raspberrypi.org/forums/view ... 0#p1581680
So I did get dt-blob.dts from:
https://raw.githubusercontent.com/raspb ... t-blob.dts
Then I copied into dt-blob.18.dts (attached as well) and applied the changes for Pi4B:
[email protected]:~ $ diff dt-blob.dts dt-blob.18.dts
2124a2125
>             [email protected] { function = "output"; termination = "no_pulling"; }; // Camera LED (for hwsync)
2159c2160,2161
<                type = "absent";
>                type = "external";
>                number = <18>;
Then I did compile using the command you provided previously in this thread:
[email protected]:~ $ sudo dtc -q -I dts -O dtb -o /boot/dt-blob.bin dt-blob.18.dts
Then I appended this line:
[email protected]:~ $ tail -1 /boot/config.txt
disable_camera_led=3
After reboot of the Pi4B I started raspivid
[email protected]:~ $ raspivid -md 7 -w 640 -h 480 -t 0 -p 22,50,640,480 -o tst.h264
and captured GPIO18 with logic analyzer.
Unfortunately I do not see hardware camera sync pulses on logic analyzer (same procedure worked for Pi 2B/3B/3B+/3A).
What do I need to do differently to get hwsync pulses show up on GPIO18 for Pi4B?
dt-blob.18.dts.zip
contains dt-blob.18.dts
(3.12 KiB) Downloaded 7 times
6by9
Tue Dec 17, 2019 7:35 am
2124a2125
2159c2160,2161
<                type = "absent";
>                type = "external";
>                number = <18>;
Invalid GPIO defined.
The GPIO expander ("external") only has 8 lines, and is invalid for camera hardware sync pulses.
Please define it to a valid GPIO on the SoC (ie "internal").
HermannSW
Tue Dec 17, 2019 3:14 pm
Thank you!
This is the diff that made hardware camera sync pulses work on Pi4B GPIO18 (in addition to the steps in previous posting):
[email protected]:~ $ !dif
2124a2125
2159c2160,2161
<                type = "absent";
>                type = "internal";
>                number = <18>;
The attached logic analyzer screenshot shows 90.14Hz average frequency for "raspivid -md 7 ... -fps 90 ..." command.
Return to “Camera board”
