rodizio
Artifacts, "blocky" video stream
Tue Apr 11, 2017 2:11 pm
I found something where I'm not sure if this is correct behavior of the camera (or the h264 encoder). When walking through the woods, sometimes parts of the images are heavily "blocky".
At first, I attributed this to the complex light conditions in a forest and the fact that in wintertime there is not that much light there because it seems to happen more in dark areas of the image. And of course also the fact that all the leaves and "stuff" in a forest doesn't compress very well compared to a uniform blue sky or whatever less complex objects.
However, today I did some more tests in an area with lots of trees, leaves, bushes etc, but on a bright day. Same issue. Sometimes the image gets really blocky. I have checked the resulting h264 file with VLC, it shows around 6mbit bitrate throughout the video, I'd assume 6mbit is enough to not have "blockiness"?
Raspivid commandline used was:
 raspivid -w 1280 -h 720 -fps 48 -b 6000000 -g 5 -t 0 -cd H264 -n -fl -ih -pf high -hf -vf -ex sports -mm matrix -awb horizon -o -
Edit: Just realized the forum resized the pic. Here are two pictures in original size:
http://imgur.com/a/dVJKU
More pics from the above area:
http://imgur.com/a/nZ1nr
More pics from another (more dark) forest, where the problem is more apparent:
http://imgur.com/a/fO4ST
Here is a sample on how it looks:
blocky image
topguy
Re: Artifacts, "blocky" video stream
Tue Apr 11, 2017 2:26 pm
You are either hitting the limit on the bitrate or on the processing power. I believe that walking through a forest probably is the h264-codecs worst nightmare. Lots of smaller details, lots of (shaky possible) movement and in very large areas of the picture. Something gotta give...
Tue Apr 11, 2017 2:28 pm
Bitrate is too low I suspect. Try 8 to 10Mbits/s.
6by9
Tue Apr 11, 2017 2:35 pm
Normally 6Mbit/s would be reasonable for 720P30. However you're running at 48fps, and -g 5 is forcing it to return an I-frame every 5th frame (the default is 60 IIRC).
6Mbit/s = 750kbytes/s = 15kB/frame if equally encoded. How good a 1280x720 JPEG can you get in 15kB? That is what you are forcing with every I-frame (not quite true as I-frames are assigned more bits than P-frames, but the worse an I-frame is the bigger the residuals in the next P-frame).
There is the alternate acronym for MPEG - Motion Pictures Except Grass.
Lots of moving stuff is very bad for motion based compression, so waving grass and running water do very badly. Waving tree branches will have the same effect.
rodizio
Tue Apr 11, 2017 3:04 pm
LOL. Yeah, I know similar effects from watching DVB-T (mpeg-2 I think) around new years eve, when it shows fireworks, it gets really blocky, seems to be something the codec cannot deal with very good. I just wouldn't have thought it's that bad with h264 and 6mbit, but after thinking about it, 15kbyte per image is really not much.
Thanks, I'll play with the settings some more. Thing is, I can't go lower on the FPS or use higher "-g" values, because I use it for flying model planes and copters, high frame-rate and fast glitch-recovery is crucial. Higher bitrate would be possible, but the problem is, that I have to use about 50% more wifi-bitrate than the camera produces because sometimes the datarate of the cam goes a lot higher than set.
6by9
Tue Apr 11, 2017 3:33 pm
rodizio wrote:Thanks, I'll play with the settings some more. Thing is, I can't go lower on the FPS or use higher "-g" values, because I use it for flying model planes and copters, high frame-rate and fast glitch-recovery is crucial. Higher bitrate would be possible, but the problem is, that I have to use about 50% more wifi-bitrate than the camera produces because sometimes the datarate of the cam goes a lot higher than set.
Even an increase up to -g 10 would be a significant saving in bitrate and still be a key frame every 208ms.
The sad reality is that something has to give - compression can't work total magic and be artifact free under all conditions in zero bitrate. Although I do have a nice video of a black cat on a dark night that compresses pretty well ;)
Wed Apr 12, 2017 9:32 am
The codec can deal with it fine, if it is given enough bits to do it in. Which given the cost of TV transmission bandwidth, is usually not enough. It's a tradeoff between bitrate and quality, and always will be.
Return to “Camera board”
