sammysideupp
QR Code Scanner compatible for RPi 3
Fri Mar 24, 2017 11:40 am
Can you recommend compa QR code scanners compatible for RPi 3 Model B?
Re: QR Code Scanner compatible for RPi 3
Fri Mar 24, 2017 11:41 am
I've been using the Pi camera and some QR software to read QR codes. Cannot comment on 'compa' - not sure what that is.
sammysideupp
Fri Mar 24, 2017 4:06 pm
jamesh wrote:I've been using the Pi camera and some QR software to read QR codes. Cannot comment on 'compa' - not sure what that is.
Sorry for the typo. What I actually mean is "Can you recommend QR code scanners compatible for RPi 3 Model B?"
What is the QR software that you are using? Thanks for your help.
Fri Mar 24, 2017 4:37 pm
I've been using zbar-tools and qrencode for decode and encode respectively, and the standard camera apps with the raspi camera.
sammysideupp
Fri Mar 24, 2017 4:43 pm
jamesh wrote:I've been using zbar-tools and qrencode for decode and encode respectively, and the standard camera apps with the raspi camera.
Where can I download the zbar-tools and qrencode? Is it compatible with RPi 3?
Fri Mar 24, 2017 9:02 pm
You should be able to install it with apt.
sudo apt install zbar-tools python-zbar python-qrtools python-qrcode qrencode
sammysideupp
Mon Mar 27, 2017 12:35 pm
DougieLawson wrote:You should be able to install it with apt.
Do you have available codes for this?
Mon Mar 27, 2017 12:36 pm
No, sorry. I've not tried doing QR codes with my old RPi1B and V1 camera.
topguy
Mon Mar 27, 2017 1:35 pm
sammysideupp wrote:Can you recommend compa QR code scanners compatible for RPi 3 Model B?
Most USB barcode scanners should work quite well with Raspberry Pi. There are usually two types, those who emulate a keyboard and those you appear as a serial port. Those who appear as a serial port is somewhat simpler to work with.
mikerr
Sat Jun 10, 2017 6:09 pm
If you want the quick route with no python:
sudo apt-get install zbar-tools
then point the camera at the barcode:
I pointed the camera at the screen showing the page https://en.wikipedia.org/wiki/QR_code
QR-Code:http://en.m.wikipedia.org
scanned 1 barcode symbols from 1 images in 8.1 seconds
that was an original pi B , pi3 would be faster
eireboy
Tue Jul 11, 2017 11:17 pm
HI Guys,
Anybody got complete code to enable qr code reading on V2 camera and rasp model 3...
ive tried what has been suggested with zbar tools but no success...
Thanks in advance...
topguy
Wed Jul 12, 2017 10:43 am
Its probably easier to get help on fixing you problem if you describe what you have tried and where it failed.
Also hijacking an old thread with a misleading subject is also not a good idea.
eireboy
Wed Jul 12, 2017 8:09 pm
Thanks for the reply topguy...
is this thread not about qr code scanner on raspberry pi??? how is my comment misleading???
i know the thread is old but i did not want to start a new one when there was one already started about the very subject i was trying to get an answer to...
Anywho, i have tried using the code that mikekerr has posted above and i get the camera to come on but it wont scan the qr code???
rpiMike
Thu Jul 13, 2017 12:01 pm
What does 'zbarimg image.jpg' report ?
scotty101
Thu Jul 13, 2017 12:20 pm
rpiMike wrote:What does 'zbarimg image.jpg' report ?
It reports the 'text' of what ever the QR code inside the image says.
See mikerr's post above, he has posted the output of the command he ran.
rpiMike
Thu Jul 13, 2017 12:30 pm
Sorry, I was trying to as eireboy what his output is reporting.
I've used this in the past and its worked well.
Thu Jul 13, 2017 1:39 pm
eireboy wrote:HI Guys,
More information needed. I know this combination works, so what is actually going wrong in your case?
cpunk
Thu Jul 13, 2017 10:03 pm
I have used the zbar library in an Android environment (from Java), and I would also recommend it, but sadly I don't have samples. I haven't done any barcode work with a Pi until now.
But one thing: don't use a too big frame size, otherwise zbar will slow to a crawl. Most barcodes can be decoded nicely with a frame that's about 720 pixels wide.
terry_chia
Fri Jul 14, 2017 12:17 pm
I am getting this error message from the command. any idea how to solve this? thanks
#command
#error
http://mirrordirector.raspbian.org/rasp ... _armhf.deb Hash Sum mismatch
cpunk
Sat Jul 15, 2017 2:37 pm
I personally cannot recreate it... zbar-tools installs correctly here.
RaTTuS
Contact: Twitter YouTube
Tue Nov 07, 2017 3:22 pm
sudo apt-get update && sudo apt-get install zbar-tools
Covfefe
SynGreis
Sun Dec 03, 2017 4:00 pm
can this be configured to autosnap when a qr code is in frame?
Return to “Camera board”
