RDS
Size of Preview Picture
Tue Mar 14, 2017 11:35 pm
I am using VNC and I have some (Python 3) code that includes the following lines.
camera.start_preview()
time.sleep(20)
camera.capture
camera.stop_preview()
The preview image covers the entire VNC screen and is therefore really poor quality, however, the actual picture that is saved to file, when viewed, is a lot smaller and looks perfect.
Is there any way I can prevent the 'preview' image being so large. Ideally, I would like it to be the same size as the picture that is saved to file.
6by9
Re: Size of Preview Picture
Wed Mar 15, 2017 12:15 pm
start_preview takes parameters to pass into the PiPreviewRenderer
https://picamera.readthedocs.io/en/late ... pirenderer
class picamera.PiRenderer(parent, layer=0, alpha=255, fullscreen=True, window=None, crop=None, rotation=0, vflip=False, hflip=False)
so
start_preview(fullscreen=False,window=(100,200,300,400))
should put it at (100,200) with width/height 300x400. Amend numbers to suit.
RDS
Wed Mar 15, 2017 1:34 pm
@6by9
Thank you very much. That is just what I needed.
(I found that another close bracket was needed at the end of the start_preview line of code, just in case anyone else requires the same solution)
6by9
Wed Mar 15, 2017 2:02 pm
RDS wrote:@6by9
Documentation is a wonderful thing, and waveform80 has done a very good job on it.
RDS wrote:(I found that another close bracket was needed at the end of the start_preview line of code, just in case anyone else requires the same solution)
Edited.
RDS
Wed Mar 15, 2017 11:43 pm
@6by9
This is so powerful.
I have taken it a step further now on another Pi I have that controls a NOIR camera inside the lid of my Solar Panel Meter.
It takes pictures of the meter from a cron job and until now, the picture it took was always a large picture with the actual meter shown in the middle. I have now added the 'crop' parameter so the picture now just shows the actual figures.
Thanks again.
Return to “Camera board”
