Tue Feb 07, 2017 8:54 pm
Been experimenting with a remote utility meter reading application for a while, using:
Pi Zero
Pi camera V1.3
Blinkt LED module from Pimoroni
motionEysOS configured to take a still image every hour
crontab configured to run python scripts to switch on Blinkt illumination just before exposure, and off again afterwards
The attached images were taken with cameras modified by unscrewing the lens mount, after carefully releasing the three blobs of adhesive holding the lens mount. The square moulding into which the lens mount screws is very lightly attached to the camera board, and to avoid accidentally detaching it, it's advisable to hold it with pliers while unscrewing the lens.
The camera to utility meter focussing distance is approximately 110mm.
Focussing was done by trial and error.
The main difficulty is positioning the Blinkt LED module relative to the utility meter and camera to avoid reflections from the plastic window on the utility meter..
Also tried using some cheap add-on lenses for an iPhone, however when using the 0.67X wide lens paired with a macro lens this made the focussing distance far too short, with consequent difficulty in illuminating the target.
Following further optimisation of the image quality hoping to experiment with automatic number recognition, so that the 100k or so of jpg image can be reduced to a few bytes of meter reading data.
- gas meter
- Camera1_gas_19-00-00.jpg (43.34 KiB) Viewed 3887 times
- electricity meter
- Camera1_elec_19-00-00.jpg (44.79 KiB) Viewed 3887 times
