pirquessa
Fail to activate flash
Sun Jan 29, 2017 7:09 pm
I'm trying to take picture with flash with my Raspberry Pi 3 rev 1.2 & Camera V2 with Raspbian.
I'v followed the procedure described here:
I use the file from: https://github.com/raspberrypi/firmware ... t-blob.dts, after modifications, diff is:
pi $ diff dt-blob.dts{.original,}
1162a1163
>             pin@p17 { function = "output";  termination = "pull_down"; }; // Camera flash
1226,1227c1227,1229
<             pin_define@FLASH_0_ENABLE {
<                type = "absent";
>             pin-define@FLASH_0_ENABLE {
>                type = "internal";
>                number = <17>;
Then compile & copy: sudo dtc -I dts -O dtb -o /boot/dt-blob.bin dt-blob.dts, then reboot sudo reboot.
Then test with:
with picamera.PiCamera() as camera:
    camera.flash_mode = 'torch'
    time.sleep(1)
    camera.flash_mode = 'off'
But my led refuse to light up. (When plugged directly on PIN1 instead of PIN11 it light up).
I would really appreciate some help. I'm really out of idea... :(
Thank you !!! :)
philkingmagpi
Re: Fail to activate flash
Fri Feb 03, 2017 9:01 pm
The torch mode isn't working for me either. All the other flash modes work fine when you then take a still with camera.capture.
6by9
Mon Feb 18, 2019 12:32 pm
Go back to the actual announcement thread at https://www.raspberrypi.org/forums/view ... 43&t=83484 and you'll notice a description of adding two lines to dt-blob.dts for each flash:
                     type = "absent";
                  pin_define@FLASH_0_INDICATOR {
                     type = "absent";
Torch mode uses the indicator line. Flash uses the enable line. Setting them both to the same GPIO will cause weird behaviour.
Return to “Camera board”
