raspivid -sg option does not work
Posted: Sun Oct 16, 2016 4:20 pm
by olaffit
Hi Guys,
trying to use the -sg segment option, but it does not seem to work. Always creates a file without a segment number at the end and then obviously the following file creates fail.
If I issue
raspivid --nopreview -v --segment 5000 --start 1 -t 10000 -o test.mpg
I get
Connecting camera video port to encoder input port
Opening output file "test.mpg"
Enabling encoder output port
Starting video capture
Failed to open new file "(null)"
Finished capture
Closing down
I have also tried to use the --split option in addition. Looking at the source code of raspivid I do not understand why it does not work.
if (pState->segmentSize || pState->splitWait)
      // Create a new filename string
      asprintf(&tempname, filename, pState->segmentNumber);
      filename = tempname;
it seems to not enter in this If clause.
Any help would be appreciated. I guess I am doing something stupidly wrong.
Cheers
Olaf
Re: raspivid -sg option does not work
Posted: Sun Oct 16, 2016 8:20 pm
by ethanol100
You need to provider a filename containing %d which will then be replaced by a number. I.e. test%d.h264 will create test1.h264, test2.h264,...
If you want a Fixed length with leading zeros you can write %04d which will be replaced by 0001,0002,...
Posted: Mon Oct 17, 2016 8:38 am
by olaffit
Great, that works :D . THANKS ethanol100 for the quick help... priceless this forum!!
Just one observation, raspivid still prints out errors, even though the files are created ok.
But who cares, important thing is it works :)
Starting component connection stage
Opening output file "test1.mpg"
Opening output file "test2.mpg"
Opening output file "test3.mpg"
Opening output file "test4.mpg"
Finished capture
Closing down
Close down completed, all components disconnected, disabled and destroyed
Posted: Mon Oct 17, 2016 10:17 am
by 6by9
olaffit wrote:Just one observation, raspivid still prints out errors, even though the files are created ok.
Finished capture
Closing down
Someone's forgotten to check that inline motion vectors are wanted before trying to open a new segment file for them
https://github.com/raspberrypi/userland ... id.c#L1196
https://github.com/raspberrypi/userland/issues/346 raised, and one of us will fix it when we get a chance. Thanks for the report.
