BigJinge
Pi Zero long camera cable bond?
Fri Aug 05, 2016 12:21 am
I've got a project where I need a long RP Zero camera cable, at least 40cms long. I have yet to see any and I need to get this project done.
What I need is the 50cms RP Zero version of this cable.
https://shop.pimoroni.com/products/rasp ... mera-cable
That said, is there any way I can bond a RP Zero camera cable to a standard RP camera cable?
BigJinge
aBUGSworstnightmare
Re: Pi Zero long camera cable bond?
Fri Aug 05, 2016 5:35 am
Might be a bit pricey but should do the job fast: http://uk.farnell.com/raspberry-pi/rpi- ... dp/2433318
That's the adapter set for the Compute Module.
BigJinge
Fri Aug 05, 2016 9:29 am
Interesting. Yes, it is expensive. That would work as long as I could get the adaptor to fit in the confined space of the project housing.
I'll add it as an option. Would still like to see if it's possible to bond the cables together.
BigJinge
burtyb
Fri Aug 05, 2016 9:46 am
I had the same problem and made a small adapter board (http://www.ebay.co.uk/itm/201638994940) to join camera cables.
aBUGSworstnightmare
Fri Aug 05, 2016 10:41 am
BigJinge wrote:I'll add it as an option. Would still like to see if it's possible to bond the cables together.
Soldering the FPC (Felxible printed circuit = Zero camera cable) to the standard 15-pin FFC is possible as long you know how to do it. Make sure you use the right type of FFC for this; if not you will end up with a cable that has the contacts on the wrong side...
BigJinge
Fri Aug 12, 2016 1:08 am
burtyb wrote:I had the same problem and made a small adapter board (http://www.ebay.co.uk/itm/201638994940) to join camera cables.
Just ordered one. Let's see how it works out... :)
maddogdave
Sat Oct 01, 2016 11:37 am
You can buy the connector to link two cables together from Pimoroni now for the same price.
https://shop.pimoroni.com/products/came ... spberry-pi
Dave
BigJinge
Sat Oct 01, 2016 1:38 pm
maddogdave wrote:You can buy the connector to link two cables together from Pimoroni now for the same price.
Hi, yes I saw they had these yesterday. I'd been in contact with a number of Pi suppliers about longer Zero cables and they said they were looking at them. It appears the converter solution has come to the fore instead.
I have one of these converters in use at the moment and it works great.
InsertTitle
Sun Jun 17, 2018 7:51 pm
Sorry to resurrect a dead thread, but if you're still looking for a solution then it might be worth you time looking on Aliexpress.
I found the 22-pin 0.5mm pitch ribbon cables that are required to connect to the RPI Zero camera connector.
If you make yourself a custom PCB and use this 22 pin connector (https://goo.gl/jvYe3p) and place one on either side of the board.
Then buy yourself either a same side or reverse direction ribbon cable from the links below and that should sort out your extension problem.
Same Side: https://goo.gl/ap8kNg
Reverse Side: https://goo.gl/ejVjge
For your exact problem you wanted 40cm or 400mm for conversion purposes.
So here is a link to a 40cm cable: https://goo.gl/gA9ASM
If you want different sizes then you can go here: https://goo.gl/wUHYXc
However this is only for same sided cables as there are limited options for reverse side.
Return to “Camera board”
