I am transmitting SSDV (Slow Scan Digital Video) with a Raspberry Pi. Usually the Pi grabs an image from the USB webcam or the PiCam but at home I have not that nice view as I have from an IP camera @ 52 meter heigh.
So, I did look to fake the /dev/video0 with jpg images.
I did install v4l2loopback, had to build kernal header files or something like that to succeed, tried a lot of options how to send images to the fake /dev/video0 which was made after running sudo modprobe v4l2loopback and finally ended up with a very simple
sudo copy snap.jpg /dev/video0 solution.
Made a script with the grab of snap.jpg and the file copy and had it run for more as 24 hours with no problem.
Then I did have to Sudo Halt the Pi to add the GPS board so the software could transmit my actual GPS position.
After powering up the Pi again there still is a /dev/video0 (which is removed after modprobe -r v4l2loopback and then made again with the modprobe command) but I cannot copy to /dev/video0 anymore.
I am rewarded with an error message:
I assume that in my experimental stage I did run a command which made it actually possible to copy jpg to /dev/video0 but I have no clue which of the many commands I tried whould be the right one.cp: error writing ‘/dev/video0’: Invalid argument
cp: failed to extend ‘/dev/video0’: Invalid argument
Anyone who can help me ?
Thanks,
Ben
