schoolpost
Re: Pi Camera V2 raw bayer data
Fri Apr 14, 2017 6:06 am
Bryan I'm a little lost as to what you are aiming for.
You want to use the RAW information. You've mentioned DNG aswell. ( what camera version do you have? )
I very recently created a pretty simple to use python script to do this:
https://github.com/schoolpost/pydng
I believe it creates a pretty decent output in terms of color/quality and with the addition
of standard lossless DNG compression you can half the file size at no cost. Really cant get better than that.
The mentioned C tool will pack the RAW into a 16bit DNG. It works with both V1 and V2.
But lacks the correct color matrix and doesn't do any RAW calibration prior to packing it ( lens shading, hot pixel removal )
If you want to use the RAW data, do some debayering and then output into a more standard format you could possibly explore OpenCV debayer aswell.
Not to "inflate" or "hype" myself here, but in this situation I believe my aforementioned script above
will give you the best result if DNG is what you are after. Go ahead and tweak it as you see fit.
I realize too its not the most intuitive to work with, but should be quite workable.
I'm really trying to get the process done right, so feedback is very welcome.
-Csaba Nagy
perrociego
Fri Apr 14, 2017 6:10 am
Hi Brian:
I tried the second code. It`s outputs is a .ppm without header. You may open it with Photoshop. 8 bits per color.
And I just tryng to understand the first one. Look quite good. It´s clear 16 bits.
8 bit´s vs 16 bit´s. Images wont look the same.
Photoshop options
Screen Shot 2017-01-28 at 19.44.19 copy.jpg (50.31 KiB) Viewed 2730 times
perrociego
Fri Apr 14, 2017 6:21 am
Hi schoolpost:
Do you know how long does it take to your code to process an image?
Thanks for sharing
Marcelo
schoolpost
Fri Apr 14, 2017 7:52 am
perrociego wrote:Hi schoolpost:
Thanks for sharing
Marcelo
If you want to do a straight 16-bit DNG output it will take a 3-5 seconds.
( there's some processing going on with lens shading, hot pixel mapping. )
Its certainly not C level of speed / efficiency but good enough I would imagine for most applications.
I also have a 10-bit DNG output, that takes considerably longer as my method packing is a very crude, around 23 seconds.
It packs the 10-bit data like this:
AAAAAAAA AABBBBBB BBBBCCCC CCCCCCDD DDDDDDDD
This is needed for the pixel data to be read properly. ( kind of wish the RAW was originally packed this way :? )
This however once run through lossless compression will yield nearly half the uncompressed raw size.
16-bit will not achieve the same compression for obvious reasons.
If anyone knows how this packing could be improved its more than welcome. ( where rowData is a numpy rowslice of the bayer data )
                count = 0
                rowPacked = []
                for i in range(0, len(rowData) + 1, 4):
                    if i != 0:
                        temp = ''
                        for k in rowData[count:i]:
                            temp += '{0:010b}'.format(k)
                        mask = 0
                        for j in range(0, 40 + 1, 8):
                            if j != 0:
                                rowPacked.append(int(temp[mask:j], 2))
                                mask = j
                        count = i
                self.wf.write(struct.pack('B' * len(rowPacked), *rowPacked))
-Csaba Nagy
Bryan See
Fri Apr 14, 2017 10:21 am
schoolpost wrote:Bryan I'm a little lost as to what you are aiming for.
I'm using camera version 2.1. IMX219.
Fri Apr 14, 2017 2:29 pm
I get this
(cheese:8868): Gtk-WARNING **: Calling Inhibit failed: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.gnome.SessionManager was not provided by any .service files
(cheese:8868): dconf-CRITICAL **: unable to create directory '/run/user/0/dconf': Permission denied.  dconf will not work properly.
Failed to create secure directory (/run/user/0/pulse): Permission denied
AL lib: (WW) alc_initconfig: Failed to initialize backend "pulse"
AL lib: (EE) alsa_open_capture: Could not open capture device 'default': No such file or directory
(cheese:8868): cheese-WARNING **: Could not open device.: gstopenalsrc.c(506): gst_openal_src_prepare (): /GstCameraBin:camerabin/GstAutoAudioSrc:audiosrc/GstOpenalSrc:audiosrc-actual-src-opena:
ALC error: Invalid Value
(cheese:8868): cheese-WARNING **: Internal data flow error.: gstbasesrc.c(2933): gst_base_src_loop (): /GstCameraBin:camerabin/GstAutoAudioSrc:audiosrc/GstOpenalSrc:audiosrc-actual-src-opena:
streaming task paused, reason not-negotiated (-4)
which looks to me like a bug in the Cheese programs.
thatneat
Tue Dec 04, 2018 7:46 pm
This is a pretty old thread, but I thought folks reading it might be interested to know - in Python, my team just released a fork of picamera which pulls out the raw data from a raw+jpeg file into a more consumable, numpy format. It includes only the most basic demosaicing. Check out https://github.com/OsmoSystems/picamraw/
Return to “Camera board”
