paulhothersall
camera v2 high FPS / short clip option??
Tue Apr 26, 2016 12:45 am
If the MPEG4 encoder block can "only" take 50% of the 960x540x240 rate .... then could the GPU be assigned enough memory for burst captures for a buffer?
if thats 150MB/sec uncompressed at the 10bit setting, have say a 512MB buffer, and thats towards 6 seconds of capture if the encoder is emptying from the front of the queue at full rate. Its no different than the mechanism used for the first few secs on a DLSR taking stills for example
I can think of many many things where that would be a great feature.
Note this could also work for the other readout rates.
Gavinmc42
Re: camera v2 high FPS / short clip option??
Fri May 06, 2016 1:31 pm
According to the data sheet with a 4 lane MIPI, V2 should do max 240fps at VGA.
But Pi, cable and pcb is only 2 lane, so 120fps?
V1 was 90fps VGA?
Anyone tried to get 120fps from a V2?
I'm dancing on Rainbows.
amuxie
Wed May 18, 2016 7:30 am
Gavinmc42 wrote:According to the data sheet with a 4 lane MIPI, V2 should do max 240fps at VGA.
V1 was 90fps VGA?
I have tried, but failed, only 90fps VGA on pi3, sony imx219 sensor.
how about you?
thanks in advance!
Return to “Camera board”
