raspicam motion error
Posted: Fri Feb 26, 2016 8:18 pm
by skatedan
h guys
when i try to shot a Pic my pi cam return this error message
mmal: mmal_vc_component_enable: failed to enable component: ENOSPC
mmal: camera component couldn't be enabled
mmal: main: Failed to create camera component
mmal: Failed to run camera app. Please check for firmware updates
how i can solve this problem? And why return this error?
The camera is alredy enabled.
I tried to instal another OS on another SD card but nothing, return equeals issue, should be a cable of raspicam?
Re: raspicam motion error
Posted: Sat Feb 27, 2016 9:52 am
by DougieLawson
What comes out from a vcgencmd get_camera command?
If all is well with the software / hardware then you should get
pi@odyssey:~$ vcgencmd get_camera
supported=1 detected=1
pi@odyssey:~$
Have you checked wiring including the little SUNNY connector on the camera board? Does the board LED come on?
Posted: Mon Feb 29, 2016 12:16 am
by skatedan
So, thanks for the reply,
raspberry return me
then all work fine, Now i saw that before don t worked because in background worked motion, But I try to Kill motion And shoot Pic, Red led turn on And turn off But i don' t find a Photo
Posted: Mon Feb 29, 2016 12:26 am
by DougieLawson
Try using raspistill
cd /tmp
ls -la photo*
Posted: Mon Feb 29, 2016 7:22 am
by skatedan
I have tried, return me this error
mmal: No data received from sensor. Check all connections, including the Sunny one on the camera board
Posted: Mon Feb 29, 2016 11:43 am
by DougieLawson
Check the ribbon cable (both ends), check the SUNNY connector on the camera board.
Posted: Mon Feb 29, 2016 11:49 am
by skatedan
all ends of ribbon Cable are connected also the SUNNY connector
Posted: Mon Feb 29, 2016 12:20 pm
by DougieLawson
skatedan wrote:all ends of ribbon Cable are connected also the SUNNY connector
Then your camera board may be dead. Try it on another RPi.
Posted: Mon Feb 29, 2016 12:33 pm
by skatedan
Ou :( But red led turn on off
Posted: Mon Feb 29, 2016 5:02 pm
by DougieLawson
skatedan wrote:Ou :( But red led turn on off
That shows your ribbon cable is probably OK. If it's not the SUNNY connector on the front of the camera that's not fully connected then your camera is dead. Try the thumb & forefinger job where you press (quite hard) on the SUNNY connector until you get a faint but audible click.
