bomba5
RTSP Streaming audio/video
Thu Feb 18, 2016 5:59 pm
I'd like to produce an RTSP stream of mixed audio and video coming from a raspberry pi to my computer.
Currently I'm achieving the task producing two separate tcpserversink, like this:
# SERVER
raspivid -t 0 -rot 180 -w 640 -h 480 -fps 20 -b 256000 -o - | gst-launch-1.0 -v \
fdsrc ! \
h264parse ! \
rtph264pay ! \
gdppay ! \
tcpserversink host=0.0.0.0 port=5000 \
alsasrc device=plughw:0 ! \
audioconvert ! \
audioresample ! \
opusenc ! \
rtpopuspay ! \
gdppay ! \
tcpserversink host=0.0.0.0 port=5001
# CLIENT
gst-launch-1.0 -v tcpclientsrc host=${TARGET_IP} port=5000 ! \
gdpdepay ! \
rtph264depay ! \
avdec_h264 ! \
autovideosink sync=false \
tcpclientsrc host=${TARGET_IP} port=5001 ! \
gdpdepay ! \
rtpopusdepay ! \
opusdec ! \
alsasink sync=false
Any clues?
J
bomba
RpiName
Re: RTSP Streaming audio/video
Thu Feb 18, 2016 7:00 pm
bomba5 wrote:I'd like to produce an RTSP stream of mixed audio and video coming from a raspberry pi to my computer.
although not rtsp, you may want to try webrtc with UV4L instead to get an audio + full hd video stream from the rpi2 to the browser:
http://linux-projects.org
bomba5
Thu Feb 18, 2016 7:30 pm
I'd like to stick to gstreamer for this simple task without adding other components to the system. Can you point me to an example anyways?
bomba
RpiName
Thu Feb 18, 2016 7:41 pm
bomba5 wrote:I'd like to stick to gstreamer for this simple task without adding other components to the system. Can you point me to an example anyways?
example of what exactly? install the uv4l packages according the instructions below, open firefox and access the webrtc page at the rpi address, click on 'start' to get the stream. there's really nothing to configure apart from an initial setup if you want use an usb sound card for the audio input (again, see the instructions). that's it.
instructions:
http://www.linux-projects.org/modules/s ... e&artid=14
demos:
https://www.youtube.com/playlist?list=P ... oQwvCcUOph
anmar
Mon Feb 29, 2016 4:36 pm
The fastest way to do RTSP with gstreamer is with gst-rtsp-server/examples/test-launch, but it's not in raspbian repos.
You can also try something I built for that purpose: https://github.com/anmar/rpirtspd
It' basically uses rpicamsrc and alsasrc as sources and creates a rtsp server with 3 streams (test, video only, video+audio)
gatherer
Sat Mar 05, 2016 6:29 pm
anmar wrote:The fastest way to do RTSP with gstreamer is with gst-rtsp-server/examples/test-launch, but it's not in raspbian repos.
Sounds interesting, can you supply more information how to install and use it?
bomba5
Fri Mar 25, 2016 2:10 pm
Very good project Anmar. I've been writing my RTSP server using rpicamsrc and alsasrc, implementing the same argument parsing as raspivid.
One quick suggestion for yours: dig https://cgit.freedesktop.org/cgit/?url= ... netclock.c
it would be useful to have timestampings on the RTSP streams.
http://gstreamer-devel.966125.n4.nabble ... 76219.html
Do you experience the same behaviour I describe here?
bomba
Return to “Camera board”
