galaxyrider
Time lapse project
Sun Jan 10, 2016 8:41 pm
Hello
I'm trying to do this time lapse project on the Raspberry Pi website
https://www.raspberrypi.org/learning/ti ... rksheet.md
When I go to test it at the end of section two I get this error message-
bash: ./camera.sh: Permission denied
I have been over and over it to make sure I've typed it in properly and followed all the instructions about going to the right directory for the Camera folder etc.
I hope someone can help.
Thanks.
rzusman
Re: Time lapse project
Sun Jan 10, 2016 9:39 pm
Try it as root, or preface with ‘sudo'
galaxyrider
Mon Jan 11, 2016 9:10 am
Thanks for replying. Yes I did try sudo. Should I remove the . / before camera.sh? I don't know how to run in root.
AndyD
Mon Jan 11, 2016 9:14 am
Can you post the output of
ls -l camera.sh
galaxyrider
Mon Jan 11, 2016 10:23 am
Ok but it'll have to be this evening. Thanks.
galaxyrider
Mon Jan 11, 2016 7:48 pm
Hello. This is what came up when I typed that into the terminal and pressed return.
-rw-r--r-- 1 pi pi 113 Jan 10 20:25 camera.sh
I hope I did it right.
danjperron
Mon Jan 11, 2016 7:50 pm
your script is not executable
just type
chmod +x camera.sh
and then it should work
galaxyrider
Mon Jan 11, 2016 8:18 pm
Thanks for all your help. I've found that the problem was a stupid newbie error of missing out the i in raspistill. I checked it several times but saw it straight away when I opened the code just now. :oops:
Return to “Camera board”
