bobbydriver
Pi Noir Camera Module image interference
Fri Nov 13, 2015 11:00 am
I have a Pi Noir camera module and it all seems to work OK except for constant interference on the picture in the form of horizontal flashes
This makes it useless for motion detection, as the interference triggers the frame change
It's not a uniform thing, it seems random and the best I can liken it to is a bad TV reception.
An example of the output attached (apologies it is a still not a moving image - but you should get an idea what I mean)
I'm thinking i may just have a faulty camera board
gordon77
Re: Pi Noir Camera Module image interference
Fri Nov 13, 2015 11:02 am
Poor power supply ?
bobbydriver
Fri Nov 13, 2015 11:06 am
The power supply is a branded white RPi one from the RPi shop, so I'd hope not
Raspberry Pi Model B+ OFFICIAL 5V 2A Multi National Power adapter
Fri Nov 13, 2015 12:16 pm
In that case you should assume your NoIR camera is faulty and ask your reseller for a replacement.
fruit-uk
Fri Nov 13, 2015 12:49 pm
PSUs don't last for ever so could be failing. Also worth checking for cables faults and loose connections in case they are the cause
bobbydriver
Fri Nov 13, 2015 1:04 pm
Fair points - I have a second Pi so I'll swap the PSUs over
If that makes no odds then I will also reseat the camera cable and see how I get on
Cheers all
koma77
Fri Mar 25, 2016 11:20 am
I've got the exact same problem with my camera module.
Did you ever resolve your issue?
bobbydriver
Fri Mar 25, 2016 1:15 pm
No - I gave up in the end. This was on my Pi 1
Although I just got a Pi 3 so when my Pi 2 becomes redundant I may try again. Pretty sure it's a faulty camera module though
Return to “Camera board”
