Real time processing images with OpenCV
Posted: Sat Aug 15, 2015 3:09 pm
Hello all,
I'm trying to use the camera in a project where real-time response is important. I want to play sounds in response to movements.
Focused in the problem of acquiring images fast and processing it, and after many tests, I have finnally developed two utility classes, based on the advanced recipe proposed in picamera docs.
Please, analyse/use/test it, any feedback to improve it will be welcome.
Note than the condicions are:
The processor class (a thread too):
Test code:
In this particular sample, some times a frame seams to be processed unordered and a flick is observed. Haven't found why.
- Only one frame is proccessed at a time
- If a new frame is captured and another is waiting processing, the "old" frame is discarded.
- While capturing a frame (before yield is called) if image processor thread detects is finalyced, the frame is processed inmediatelly. Again, "old" frames could be discarded.
import threading, time, io
import picamera, picamera.array, cv2
import imageprocessor
class RTOpenCV(threading.Thread):
# stop condition for the thread
stop = False
status_lock = threading.Lock()
# possible frame status: Empty, Capturing, Ready, Processing
status = ['Empty','Empty','Empty']
def __init__(self, camera, callback):
super(RTOpenCV, self).__init__()
RTOpenCV.camera = camera
# three streams will be used
# only one is in Processing/Capturing at a time
RTOpenCV.streams = [picamera.array.PiRGBArray(self.camera),
picamera.array.PiRGBArray(self.camera)]
RTOpenCV.processor = imageprocessor.ImageProcessor()
RTOpenCV.callback = staticmethod(callback)
self.start()
def run(self):
RTOpenCV.camera.capture_sequence(RTOpenCV._streams(), use_video_port=True, format='bgr')
def close(self):
RTOpenCV.stop = True
self.join()
RTOpenCV.processor.join()
@staticmethod
def _discard_frames(last_frame):
# check if another frame is Ready
# in that case, discard it (only last frame is usefull)
if RTOpenCV.status[(last_frame+1)%3] == 'Ready':
RTOpenCV.status[(last_frame+1)%3] = 'Empty'
if RTOpenCV.status[(last_frame+2)%3] == 'Ready':
RTOpenCV.status[(last_frame+2)%3] = 'Empty'
@staticmethod
def _streams():
# yield a stream for capture_sequence
frames=0
# first select an non used stream
while not RTOpenCV.stop:
free_stream = -1
with RTOpenCV.status_lock:
for i in range(3):
if RTOpenCV.status[i] == 'Empty':
RTOpenCV.status[i] = 'Capturing'
free_stream = i
break
if free_stream == -1:
for i in range(3):
if RTOpenCV.status[i] == 'Ready':
free_stream = i
break
RTOpenCV.streams[free_stream].seek(0)
yield RTOpenCV.streams[free_stream]
# if stream have not been used, mark it ready
if RTOpenCV.status[free_stream]=='Capturing':
RTOpenCV.status[free_stream]='Ready'
RTOpenCV._discard_frames(free_stream)
frames+=1
import cv2
class ImageProcessor(threading.Thread):
def __init__(self):
super(ImageProcessor, self).__init__()
import rtopencv
self.frame_size = rtopencv.RTOpenCV.camera.resolution[0]*\
rtopencv.RTOpenCV.camera.resolution[1]*3
self.num_frames = 0
self.start()
def run(self):
import rtopencv
while not rtopencv.RTOpenCV.stop:
# search the last captured frame
ready = -1
with rtopencv.RTOpenCV.status_lock:
for i in range(3):
if rtopencv.RTOpenCV.streams[i].tell()==self.frame_size\
and rtopencv.RTOpenCV.status[i] == 'Capturing':
rtopencv.RTOpenCV.status[i] = 'Processing'
rtopencv.RTOpenCV._discard_frames(i)
ready = i
break
if ready == -1:
for i in range(3):
if rtopencv.RTOpenCV.status[i] == 'Ready':
ready = i
break
# if frame found, process it
if ready > -1:
rtopencv.RTOpenCV.callback(rtopencv.RTOpenCV, rtopencv.RTOpenCV.streams[ready].array)
self.num_frames+=1
# when processed, mark stream empty
rtopencv.RTOpenCV.status[ready]='Empty'
else:
#no frame available
time.sleep(0.002)
import time, io
import picamera
import cv2
import rtopencv
# process de frame , rtopencv and frame a passed as parameters
def process_image(rtopencv_class, frame):
cv2.imshow("Frames",frame)
cv2.waitKey(1)
with picamera.PiCamera() as camera:
# initialice the camera as desired
camera.resolution = (640, 480)
camera.framerate = 20
time.sleep(1)
# create an instance (two thread ar created,
# one for capturing, other for processing)
opencv = rtopencv.RTOpenCV(camera, process_image)
# make other things
time.sleep(10)
# when want to finish image processing, call close()
opencv.close()
