@jbeale;jbeale wrote:Does the log file give any clues? Do you have low motion thresholds, or long timeouts? I got frequent captures when I had an outdoor setup where there was water dripping off a roof right in front of the lens, but apart from that I have not seen huge files here. I have several PiKrellCam systems running 24/7 but they are on versions 2.1.3 and 2.1.1
I occasionally see a system freeze here as well, but it might be due to power glitches because other systems running from a battery-backed UPS do not lock up.
If you have trouble rebooting after the freeze it could be other things also. I wouldboomlikethat wrote:@jbeale;jbeale wrote:Does the log file give any clues? Do you have low motion thresholds, or long timeouts? I got frequent captures when I had an outdoor setup where there was water dripping off a roof right in front of the lens, but apart from that I have not seen huge files here. I have several PiKrellCam systems running 24/7 but they are on versions 2.1.3 and 2.1.1
thanks for the quick response. Here's the log on one big file:
15:39:45 : Video record: /home/pi/pikrellcam/media/videos/2015-12-28_15.39.45_12.mp4.h264 ...
16:28:28 : Video motion record stopped. Header size: 29 h264 file size: -2118109383
16:28:28 : first detect: direction totals - direction: 664 burst: 33 max burst count: 784
My thresholds are:
Vector Magnitude: 5
Vector Count: 5
Burst Count: 200
Burst Frames: 3
My times are:
Confirm Gap: 3
Pre Capture: 3
Event Gap: 30
Post Capture: 5
Don't want to miss anything (there have been some shady things and robberies in recent months around here), so I find this setup is really good, especially for the price.
During windy days (or rain, like you were saying), I see a uptick in recordings too.
As for the power glitches, are we talking about the main outlets, or the power supply that goes to the Pi? I did make sure I had good quality power supplies, and even have them hard-wired to the network for faster file transfer. If it's the outlet, what can I test on my end?
Thanks!
@billw:If you have trouble rebooting after the freeze it could be other things also. I would
measure the voltage on the Pi board, maybe there's power wire resistance dropping some
voltage. Are you overclocking? If so, drop the frequency back down a bit. When you
have reboot failures how far does it get and are there error messages on the screen (if
you aren't headless).
The log from that long video averaged over 13 direction detects per minute for
40 minutes. If you have other videos around that one, what was being detected?
I like to run with low settings but on windy days sometimes I have to adjust the settings
higher. Or sometimes I get some weeds that have grown higher and I have to go trim
them to get back to good detection. Also as the seasons change different sun
angles cause different wind blown tree shadow problems on my driveway.
With low settings sometimes things have to be managed, maybe it could be a temporary
change in your motion regions or a change of settings. You could have a script
run by hand whenever needed that changes all the settings at once to lower
sensitivity and another script to restore them.
Just keep an eye on the thumbs you get for each video. If you get a lot of what youboomlikethat wrote: Usually what's being detected are cars going by, nothing unusual.
Yeah, I need to trim some roses out front...but that would only affect one of the two RPi's deployed. The other one has no obstructions, so I get far fewer huge files on that one. On occasion it might happen, but nothing I can point to.
As for the power supply, I need to check that, maybe even some kind of voltage regulator inline to help.
I do like the script idea. I can do Applescripting on my Mac, how do I do this for the RPi and PiKrellCam?
Thanks!
#!/bin/bash
echo motion limits 12 12 > ~/pikrellcam/www/FIFO
echo motion burst 500 4 > ~/pikrellcam/www/FIFO
#If you want to configure a custom motions regions also:
#echo motion load_regions windy > ~/pikrellcam/www/FIFO
#!/bin/bash
echo motion limits 5 4 > ~/pikrellcam/www/FIFO
echo motion burst 200 3 > ~/pikrellcam/www/FIFO
#echo motion load_regions default > ~/pikrellcam/www/FIFO
Uh, no. It's an oversight on my part. Back when I was adding the commandstomtgrp wrote:Hello,
I am on writing a setup.php and noticed this:
echo "video_bitrate 17000000" > FIFO
gives an error, here the part from the logfile:
18:30:46 : command_process: video_bitrate 17000000
18:30:46 : Bad command: [video_bitrate] [17000000]
should atoi instead of atol be the reason in config.c:516?
BR
Tom
@billw:billw wrote:Just keep an eye on the thumbs you get for each video. If you get a lot of what youboomlikethat wrote: Usually what's being detected are cars going by, nothing unusual.
Thanks!
consider something in the background then probably the vector limit settings you have
are too low for the camera environment (or maybe the motion regions could be adjusted
better). But if the thumbs are what you want (cars, people) then I would adjust the
event gap lower so the videos will be more likely to be shorter and about individual
events. The other option will be something I still need to do and that is put in a way
to limit the video length.
For scripts, you need a bash script that writes pikrellcam settings to the FIFO and you
run it when needed. For example a script when it rains or winds are high could be:And when the weather gets back to normal, run something like this:Code: Select all
#!/bin/bash echo motion limits 12 12 > ~/pikrellcam/www/FIFO echo motion burst 500 4 > ~/pikrellcam/www/FIFO #If you want to configure a custom motions regions also: #echo motion load_regions windy > ~/pikrellcam/www/FIFO
Make the scripts executable and run them from a terminal.Code: Select all
#!/bin/bash echo motion limits 5 4 > ~/pikrellcam/www/FIFO echo motion burst 200 3 > ~/pikrellcam/www/FIFO #echo motion load_regions default > ~/pikrellcam/www/FIFO
I expect that eventually pikrellcam will have a preset system where
a bunch of settings can be saved and restored with a web page
button click, but that's for later.
It is something I've had on my list todo for a PIR or laser interrupted switch or whatever.jbeale wrote:@billw : thanks for the continual improvements to PiKrellCam! It's great the project is so active.
There's one feature I've been thinking about, maybe it is already possible but I'm not sure. Say I wanted to record video based on an external trigger (let's say, an IR motion detector) instead of from video motion vectors. Is it possible? I understand I can use the FIFO 'record on' command, but does that include the several seconds of pre-event buffer also? Is the pre-event buffer process running all the time, or only when motion sensing is enabled? Ideally I'd want to record, for example, three seconds before a trigger and 3 seconds after it. So maybe it would be a FIFO command 'motion trigger' ?
There's a new upgrade. On the help page, see the record examples under "FIFO Commands"jbeale wrote: There's one feature I've been thinking about, maybe it is already possible but I'm not sure. Say I wanted to record video based on an external trigger
echo motion trigger > ~/pikrellcam/www/FIFO
echo record on 4 10 > ~/pikrellcam/www/FIFO
#!/bin/bash
echo "still" > /home/pi/pikrellcam/www/FIFO
echo "record on 4 4" > /home/pi/pikrellcam/www/FIFO
motion_pre_capture 4
motion_post_capture 4
# pikrellcam Program Configuration
# When editing this file, stop and then restart pikrellcam so your changes
# will be in effect. Otherwise, pikrellcam may overwrite this file and your
# changes will be lost.
# Commands in this file should not be enclosed in quotes and commands may
# have substitution variables.
# See ~/.pikrellcam/at_commands.conf for a list of the substitution variables.
# The web interface can modify many settings here but caonnot modify any
# commands or filename templates. If a setting is modified from the web
# interface, this file will be written.
# The PiKrellCam installation directory.
# This must match where PiKrellCam is installed and it is checked by
# the install-pikrellcam.sh script. This should not need to be edited.
install_dir /home/pi/pikrellcam
# Directory for the stream mjpeg file and info file. These files
# are frequently updated so this directory should be in a tmpfs.
# This could be a directory in /tmp if your /tmp is a tmpfs.
# Avoid putting this directory under /run/shm or /dev/shm because these
# directories are subject to automatic cleanups which could delete the
# tmpfs_dir out from under a running pikrellcam if running headless.
tmpfs_dir /run/pikrellcam
# If media_dir has no leading '/' it will be a sub directory in install_dir.
# Otherwise it is a full pathname to the media directory.
# So the default media dir is /home/pi/pikrellcam/media.
# An alternate choice could be /home/pi/media if you set the full path.
# Even /tmp/media with /tmp a tmpfs can be an option for a setup that
# will manage by hand or script the limited space available.
# A file system may be mounted on the media dir in the startup script.
media_dir media
# If archive_dir has no leading '/' it will be a sub directory under media_dir.
# Otherwise it is a full pathname to the archive directory.
# So the default archive dir is /home/pi/pikrellcam/media/archive.
# When media files are archived, they will be moved to sub directories:
# archive_dir/year/month/day/[videos|thumbs|stills]
# A file system may be mounted on the archive dir in the startup script.
archive_dir archive
# Log file.
log_file /tmp/pikrellcam.log
# At startup and at each new day, trim the log file number of lines
# to log_lines. If log_lines is 0 the log file is not trimmed.
log_lines 1000
# Command to run at PiKrellCam startup. This is run after the config
# files are loaded but before the camera is started or directories
# are checked. If you want a start command that runs after the camera
# is started, add a command to the file: ~/.pikrellcam/at-commands.conf.
# The default on_startup script can mount a drive on the media directory.
# Edit MOUNT_DISK in the startup script in $C (the scripts directory) to
# enable mounting.
on_startup $C/startup $I $m $G
# -------------------- Motion Detect Options -----------------------
# Enable pikrellcam motion detection at startup
motion_enable on
# Motion vectors must be at least this magnitude for a motion detect.
# Minimum is 3 for detecting the slowest moving objects possible.
motion_magnitude_limit 500
# The count of vectors required for a motion detect.
# Minimum is 2 for detecting the smallest objects possible.
motion_magnitude_limit_count 400
# Motion vector count minimum for a burst motion detect.
# For large/close object detection.
motion_burst_count 4000
# The number of sustained frames for a burst motion detect.
motion_burst_frames 30
# Time length limit of motion video record excluding pre_capture time.
# If zero, there is no time limit or else the minimum is 10 seconds.
motion_record_time_limit 10
# Percent to dim image when drawing motion vectors. Range 30 - 60
motion_vectors_dimming 45
# Require a second motion detect within this period of seconds before
# triggering a real motion detect event. Set to zero to not require a
# second confirming motion detect.
motion_confirm_gap 0
# event_gap seconds since the last motion detect event must pass
# before a motion video record can end. Each motion detect within
# an event_gap resets a new full event_gap period. When an event gap period
# does expire without a new motion event occurring, the video will end with
# an end time of the last motion detect time plus the post_capture time.
motion_event_gap 0
# Seconds of video that will be recorded in a motion video before the
# time of the first motion event.
# Seconds of video that will be recorded after the last motion event.
# Command/script to run when a motion detect event begins.
on_motion_begin $C/motion-begin $v $P $G
# Command/script to run when a motion detect event ends.
# The motion_end script uses scp to immediately archive motion detect
# videos to a different computer.
# To enable this, add your machine information to the motion-end script
# and make this the on_motion_end command:
# on_motion_end $C/motion-end $v $P $G
#on_motion_end
# When to save the motion preview file.
# first - when motion is first detected.
# The on_motion_preview_save command runs immediately.
# best - best motion based on vector count and position.
# The on_motion_preview_save command runs at motion end.
motion_preview_save_mode first
# Command to run on the motion preview jpeg file.
# Specify the preview jpeg file name with $F.
# A jpeg thumb of the motion area is automatically extracted from the
# preview jpeg and saved to the thumbs directory. However, if you
# want to do something else with the motion area, the motion detect
# area in the jpeg can be passed to this command with these substitution
# variables
# $i width of the area
# $J height of the area
# $K x coordinate of the area center
# $Y y coordinate of the area center
# Example command to email the motion detect preview jpeg:
# on_motion_preview_save mpack -s [email protected]$H $F [email protected]
# Or, example command to run the default preview-save script which you
# can edit to enable emailing or copying the jpeg.
# on_motion_preview_save $C/preview-save $F $m $P $G
#on_motion_preview_save
on_motion_preview_save $C/preview-save $F $m $P $G $i $J $K $Y
# Set to off if you want jpeg preview files to show the OSD overlay text
# or graphics. This can be considered a debug or instructional option.
# Normally it is nicer to have clean preview jpegs and thumbs.
motion_preview_clean on
# Minimum width and height in pixels for the substitution width and height
# variables for motion detect areas in the preview jpeg.
# This minimum helps with possible frame skew for smaller relatively
# faster moving objects.
motion_area_min_side 60
# Enable writing a motion statistics .csv file for each motion video.
# For users who have a need for advanced video post processing.
motion_stats off
# --------------------- Video Record Options -----------------------
# Motion and manual record video filename format.
# NOTE: PHP code on the web page tries to extract a video time from
# the video name so there is restricted flexibility for changing
# this format. In particular, the PHP code expects at least:
# xxx_xxx_%H.%M.%S_xxx.mp4
# where the '_' chars are required and '.mp4' may be '.h264'
# You can use strftime() % time specifiers.
# Note: only a recent gpac release can handle ':' in the filename.
# So, the time format may not be able to use %T specifier.
# %F is %Y-%m-%d %T is %H:%M:%S
# A video_filename may use these pikrellcam substitution vvariables:
# $M - The video_manual_tag or video_motion_tag string
# $N - The video_manual_sequence or video_motion_sequence number
# If the name has a .mp4 suffix, the video file will be boxed into a
# mp4 container using the MP4Box program. Otherwise you should give the
# name a .h264 suffix since that is the format of the Pi camera video
# output. Note that omxplayer can play a raw h264 video, but that other
# programs like vlc and mplayer will need a mp4 video.
video_filename $M_%F_%H.%M.%S_$N.mp4
# The string to substitute into a video_filename for the $M variable
# when there is a manually initiated video record.
video_manual_tag manual
# when there is a motion detect initiated video record.
video_motion_tag motion
# Pixel width of videos recorded.
video_width 1920
# Pixel height of videos recorded.
video_height 1080
# Video frames per second. The processing required to implement the
# multiple video paths in PiKrellCam limits this fps to about 24.
# Above that may cause web page mjpeg frames to be dropped. But if
# you are overclocking the GPU you may be able to set higher.
video_fps 24
# MP4Box output frames per second if video filename is a .mp4
# If this is different from video_fps, the final mp4 will be a
# slow or fast motion video.
video_mp4box_fps 24
# Video bitrate affects the quality and size of a video recording.
# Along with pre_capture and event_gap times, it also determines the
# PiKrellCam video circular buffer memory usage.
# Set the bitrate lower or higher as you wish to trade off video size
# and memory usage with video quality. The Pi camera lens and sensor
# pixel size combination also can be a limiting factor on video quality
# and may limit the benefit of the highest bitrate settings.
video_bitrate 6000000
# Pixel width of the stream jpeg file. Aspect ratio is determined by the video.
mjpeg_width 640
# Quality factor (up to 100) affects the quality and size of the stream jpeg.
# Set this lower if you need to reduce the stream bandwidth.
mjpeg_quality 20
# Divide the video_fps by this to get the stream jpeg file update rate.
# This will also be the motion frame check rate for motion detection.
# For example if video_fps is 24 and this divider is 4, the stream jpeg file
# is updated and motion is checked 6 times/sec.
mjpeg_divider 4
# ------------------ Still Capture Options -----------------------
# Still filename format. See comments about strftime() above.
# NOTE: PHP code on the web page tries to extract a still time from
# the still name so there is restricted flexibility for changing
# where the '_' chars are required.
# A still_filename may use this pikrellcam substitution variable:
# $N - The still capture sequence number
# Width of a still capture in pixels. Max value 2592
still_width 1944
# Height of a still capture in pixels. Max value 1944
still_height 2592
# This quality factor affects the size and quality of still captures.
still_quality 95
# Command to run after a still capture.
# email the still somewhere with:
# on_still_capture mpack -s [email protected]$H $s [email protected]
# Or do an email and/or something like copy or move the still somewhere
# with a script you write ($s is the still file pathname):
# on_still_capture $C/still-capture $s $P $G
#on_still_capture
# Timelapse video name format. See comments about strftime() above.
# A timelapse_video_name may use this pikrellcam substitution variable:
# $n - The timelapse capture series number (printed as %05d)
# This video name is used in $T in the on_timelapse_end command.
timelapse_video_name tl_%F_%H.%M_$n.mp4
# Command to run when a time lapse series is ended.
# The default on_timelapse_end command converts captures in the
# media_dir/timelapse directory to a video which is saved in
# the media_dir/videos directory.
# See the timelapse-end script in the scripts directory.
# NOTE: $l embeds a '%' qualifier in the command string so it
# can only be used as the last $X variable.
on_timelapse_end $C/timelapse-end $L $T $n $G $P $l
# ------------------- Miscellaneous Options -----------------------
# How long in seconds a notify string should stay on the stream jpeg file.
notify_duration 4
# Your latitude used to calculate sun rise, set, dawn, and dusk times.
latitude 30.12N
# Your longitude used to calculate sun rise, set, dawn, and dusk times.
longitude 97.88W
# Do not edit. Used internally to force startup config write if needed.
config_sequence 13
# ------------------- Annotate Text Options -----------------------
# Format for a date string that can be superimposed on videos and stills.
annotate_format_string %a %b %e, %l:%M.%S %p
# Enables drawing the annotate date string.
annotate_enable on
# Extra information drawn on the video.
annotate_show_motion off
annotate_show_frame off
# Draw text characters with black background.
annotate_black_bg on
# Raspberry Pi Initial Camera Parameters
sharpness 0
contrast 0
brightness 50
saturation 0
iso 0
shutter_speed 0
exposure_compensation -7
video_stabilisation false
raw_capture false
rotation 270
exposure_mode sports
image_effect none
hflip off
vflip off
crop 0 0 65536 65536
metering_mode average
white_balance auto
color_effect false 128 128
I thought I might get another version out tonight, but now maybe not.jbeale wrote: The "record on 4 4" command works as expected, giving a video of 8 seconds total, but apparently does not trigger the motion-end and preview-save script actions(?)
echo motion trigger 1 4 4 > FIFO
echo motion trigger 0 4 4 > FIFO
post caputure must be >= event gap time because expiring event gap forces a video stop.jbeale wrote: Observation: if I use the "motion trigger" command into the FIFO, with the below config settings, the resulting video shows 4 seconds pre-event as expected but only one single frame post-event.
Ok, there's an upgrade you can try. The help page is updated to describebillw wrote: I thought I might get another version out tonight, but now maybe not.
So, tomorrow, I'll put up a new version with:
1) record on precapture timelimit won't change since it is a record function.
2) I'll enhance the "motion trigger" command so it will take a pre capture and
time limit arg and it will run the modition end/ preview save.
Additionally it will have a motion enable override so if motion is disabled from the
web page, you can override turn it on just for the current FIFO motion trigger.
Example:will override the web enable, but this will notCode: Select all
Thanks! Yes indeed the previous version works as I had hoped when I increase the motion_event_gap to be longer than the motion_post_capture time. I just hadn't realized that requirement until now.billw wrote:post capture must be >= event gap time because expiring event gap forces a video stop.
There can only be a post capture that has been accumulated while waiting in the event
gap. But this now does not apply if you use the new motion trigger + custom times because
custom times will override the event gap.
echo "motion trigger 1 4 4 " > /home/pi/pikrellcam/www/FIFO
Upgrade available - thumbs page can select by days or all.boomlikethat wrote: Been thinking about this for a bit, and that's a request to have a "select all" button for the thumbs area. The reason I ask is this. Because I live on a busy street, I get a lot of hits each day (cars, etc). That's to be expected on my end.
However, after manually scanning the videos, archiving the ones I need for further review, I would use the "delete all". What I was not aware of is that I think it also deletes any recordings that are still in process. In the previous app I used, I could select all, and then de-select ones I wanted to further review.
I think with a "select all" button, it would only select those completed in the thumbs area.
Please correct me if I'm wrong on this, or whatever. Thanks!
Wow, thanks for doing that! I'll be testing it, but it's exactly what I was looking for.billw wrote:Upgrade available - thumbs page can select by days or all.boomlikethat wrote: Been thinking about this for a bit, and that's a request to have a "select all" button for the thumbs area. The reason I ask is this. Because I live on a busy street, I get a lot of hits each day (cars, etc). That's to be expected on my end.
Delete Day can delete a recording in progress and that is a problem. And deleting by selection
will only delete videos you can see on the thumbs page, so as you are saying, that seems to
me a better way to do it.
So I've removed the "Delete Day" and "Archive Day" buttons from the thumbs page and now
all deleting/archiving is done by selections. The delete day from the videos page can still
be a problem and I'll be looking at that.
One thing I'm wondering, is anybody using the videos page preferentially over the thumbs page?
For my part, I find since I added selections to the thumbs page I rarely manage videos from
the videos page anymore, and once I get to adding thumbs for manual and timelapse
recordings, I expect I'll never be using the videos page. So if nobody speaks up I may end up
getting rid of the videos page.
echo fix_thumbs test > ~/pikrellcam/www/FIFO
echo fix_thumbs fix > ~/pikrellcam/www/FIFO
