Wolfiesden
Motion-MMAL Auto Start on Boot?
Tue Jul 07, 2015 4:35 am
Ok, I have searched and searched. I can't find whats wrong. I simply can't get mmal to run on boot. I have it working so when I log in and run ./startmotion it works just fine. I simply can't get it to run as a daemon.
In /etc/default/motion :
start_motion_daemon=yes
in /etc/motion.conf
daemon on
I even tried copying motion and motion-mmal as well as the conf to /etc and put this in /etc/rc.local
(sleep 10;su – pi -c "/etc/motion-mmal -n -c /etc/motion.conf")&
As I said, I can log in as pi and run ./startmotion from the mmal directory and it runs fine. I just can't get it to start the daemon.
Could some kind soul give me a step by step on how to get this running at power on without having to ssh in and start it manually? Please.
Thicko_1970
Re: Motion-MMAL Auto Start on Boot?
Wed Jul 15, 2015 6:15 pm
I start motion with a cron job
Edit the root cron job file:-
sudo crontab -e
add the line:-
@reboot motion
save and exit (ctrl+x, then Y to confirm changes)
It should work if you have the motion daemon enabled.
TJphonix
Fri Jun 16, 2017 9:33 am
Not need to edit cron job file.
Simply ensure that the /etc/default/motion file is written with the right character encoding, or check that there are no blank spaces at the end of the file. The file must have only two rows with no blank spaces at the end of the string, otherwise the autostart daemon don't recognize it and fail to load.
It's useful to download on windows desktop the /etc/default/motion file, edit it with Notepad++ and reupload on rapsberry pi.
I did this and now works fine!
Return to “Camera board”
