Today I tried again and wanted to get to the root cause. With unrecreatable I2C decodings for the same command I went back to the command that worked well for determining 60fps/90fps difference for v2 camera. But even that did not help.
Then I even saw Pi 2B rebooting on HDMI monitor and realized that the HDMI connection might make a difference. After removing HDMI cable things were not much better, many hundred differences. I switched back to v2 camera and saw the same unrepeatable I2C sequences for same raspivid command. Finally I removed the I2C analyzer from Salea logic analyzer software and added it newly. That made a difference, with v2 camera now two captures for same command generated identical I2C sequences.
Then I switched cameras again, connecting new v2 NoIR camera module. I had to reboot after a camera switch in order to make raspivid work. Now things are much better, although I do not get identical sequences for v2 capturing of same command captured twice. But in total 133 differences and not near 4 digit numbers:
$ diff --side-by-side -W 74 <(cut -f2- -d, 1.csv) <(cut -f2- -d, 2.csv) | grep "<" | wc --lines
48
$ diff --side-by-side -W 74 <(cut -f2- -d, 1.csv) <(cut -f2- -d, 2.csv) | grep "|" | wc --lines
41
$ diff --side-by-side -W 74 <(cut -f2- -d, 1.csv) <(cut -f2- -d, 2.csv) | grep ">" | wc --lines
44
This was the command captured:
$ raspivid -t 3000 -md 7 -fps 60 -o /dev/null -w 640 -h 480 -ex off -ss 1000And this is side-by-side difference to look at:
Analyzer Name, Decoded Protocol R Analyzer Name, Decoded Protocol R
I2C,Setup Write to [0xC8] + NAK I2C,Setup Write to [0xC8] + NAK
I2C,Setup Read to [0x01] + NAK I2C,Setup Read to [0x01] + NAK
I2C,Setup Write to [0xC8] + ACK I2C,Setup Write to [0xC8] + ACK
I2C,Setup Read to [0xC9] + ACK I2C,Setup Read to [0xC9] + ACK
I2C,0x04 + NAK I2C,0x04 + NAK
I2C,0x11 + ACK I2C,0x11 + ACK
I2C,0x33 + ACK I2C,0x33 + ACK
I2C,0x43 + NAK I2C,0x43 + NAK
I2C,0x03 + ACK I2C,0x03 + ACK
I2C,0x07 + ACK I2C,0x07 + ACK
I2C,0x02 + ACK I2C,0x02 + ACK
I2C,0x00 + ACK I2C,0x00 + ACK
I2C,0x1E + ACK I2C,0x1E + ACK
I2C,0x2D + ACK I2C,0x2D + ACK
I2C,0x07 + NAK I2C,0x07 + NAK
I2C,0x01 + ACK I2C,0x01 + ACK
I2C,0x23 + ACK I2C,0x23 + ACK
I2C,0x68 + ACK I2C,0x68 + ACK
I2C,0x8F + ACK I2C,0x8F + ACK
I2C,0x49 + ACK I2C,0x49 + ACK
I2C,0xD4 + NAK I2C,0xD4 + NAK
I2C,0x18 + ACK I2C,0x18 + ACK
I2C,0xAD + ACK I2C,0xAD + ACK
I2C,0x92 + ACK I2C,0x92 + ACK
I2C,0xB9 + ACK I2C,0xB9 + ACK
I2C,0x0A + ACK I2C,0x0A + ACK
I2C,0x7B + ACK I2C,0x7B + ACK
I2C,0x78 + ACK I2C,0x78 + ACK
I2C,0x70 + NAK I2C,0x70 + NAK
I2C,0xEE + ACK I2C,0xEE + ACK
I2C,0x12 + ACK I2C,0x12 + ACK
I2C,0xBE + ACK I2C,0xBE + ACK
I2C,0x84 + NAK I2C,0x84 + NAK
I2C,0x1B + ACK I2C,0x1B + ACK
I2C,0x16 + ACK I2C,0x16 + ACK
I2C,0x8A + ACK I2C,0x8A + ACK
I2C,0xDE + ACK I2C,0xDE + ACK
I2C,0xBF + ACK I2C,0xBF + ACK
I2C,0x3C + ACK I2C,0x3C + ACK
I2C,0x58 + ACK | I2C,0xD6 + ACK
I2C,0x32 + ACK | I2C,0x9D + ACK
I2C,0x4F + ACK | I2C,0xB3 + ACK
> I2C,0x53 + ACK
> I2C,0x88 + ACK
> I2C,0x77 + ACK
> I2C,0x3F + ACK
> I2C,0x35 + ACK
> I2C,0x07 + ACK
> I2C,0x9D + ACK
> I2C,0xC0 + ACK
> I2C,0x59 + ACK
I2C,0x6C + ACK I2C,0x6C + ACK
I2C,0xF5 + ACK | I2C,0x1C + ACK
I2C,0x66 + ACK | I2C,0xA6 + ACK
I2C,0x72 + ACK <
I2C,0x43 + ACK <
I2C,0x6B + ACK <
I2C,0x81 + ACK <
I2C,0xC5 + ACK <
I2C,0x0B + ACK <
I2C,0x1A + ACK I2C,0x1A + ACK
I2C,0xF4 + ACK | I2C,0x77 + ACK
I2C,0xBF + ACK | I2C,0x30 + ACK
I2C,0x19 + ACK <
I2C,0x82 + ACK <
I2C,0xBC + ACK <
I2C,0x23 + NAK I2C,0x23 + NAK
I2C,0x82 + ACK | I2C,0xB1 + ACK
I2C,0x26 + ACK | I2C,0xE0 + ACK
> I2C,0xDB + ACK
> I2C,0xD3 + ACK
> I2C,0xC5 + ACK
I2C,0x60 + ACK I2C,0x60 + ACK
I2C,0x81 + ACK | I2C,0xBE + ACK
I2C,0x82 + ACK | I2C,0x24 + ACK
I2C,0x01 + ACK | I2C,0x66 + ACK
I2C,0xDA + ACK | I2C,0x6B + ACK
I2C,0x3D + ACK | I2C,0xE0 + ACK
I2C,0xF1 + ACK | I2C,0xD1 + ACK
I2C,0xAE + ACK | I2C,0xD5 + ACK
I2C,0xFF + ACK | I2C,0x93 + ACK
I2C,0x97 + ACK | I2C,0x1B + ACK
I2C,0x15 + ACK | I2C,0xB1 + ACK
I2C,0x84 + ACK | I2C,0x8C + ACK
I2C,0x4D + ACK | I2C,0xBD + ACK
I2C,0xA6 + ACK | I2C,0x89 + ACK
I2C,0x10 + ACK | I2C,0x06 + ACK
I2C,0x42 + ACK | I2C,0xED + ACK
I2C,0xA5 + ACK <
I2C,0xD6 + ACK <
I2C,0xFC + ACK <
I2C,0xE5 + ACK <
I2C,0x95 + ACK <
I2C,0x76 + ACK <
I2C,0x90 + ACK <
I2C,0x4A + ACK <
I2C,0x58 + ACK <
I2C,0x3C + ACK <
I2C,0x11 + ACK <
I2C,0x00 + ACK <
I2C,0x9A + ACK <
I2C,0x77 + ACK <
I2C,0xE9 + ACK I2C,0xE9 + ACK
I2C,0x21 + NAK | I2C,0xD3 + ACK
> I2C,0x7A + ACK
> I2C,0x33 + ACK
> I2C,0x1C + ACK
> I2C,0x7E + ACK
> I2C,0x0F + ACK
> I2C,0xEB + ACK
> I2C,0x4F + ACK
> I2C,0xFE + ACK
> I2C,0x27 + ACK
> I2C,0xB0 + ACK
> I2C,0x9B + NAK
I2C,0x40 + ACK I2C,0x40 + ACK
I2C,0x14 + ACK I2C,0x14 + ACK
I2C,0x8D + ACK I2C,0x8D + ACK
I2C,0x0B + ACK | I2C,0xF3 + ACK
I2C,0x49 + ACK | I2C,0x42 + ACK
> I2C,0x28 + ACK
> I2C,0x43 + ACK
> I2C,0x01 + ACK
> I2C,0x92 + ACK
> I2C,0x83 + ACK
> I2C,0xA5 + ACK
> I2C,0xA5 + ACK
> I2C,0x06 + ACK
> I2C,0x6E + ACK
> I2C,0x18 + ACK
> I2C,0x87 + ACK
> I2C,0x60 + ACK
> I2C,0x8E + ACK
> I2C,0xA5 + ACK
> I2C,0x50 + ACK
> I2C,0xDE + ACK
> I2C,0xBA + ACK
> I2C,0x1E + ACK
> I2C,0x02 + ACK
I2C,0x5E + ACK I2C,0x5E + ACK
I2C,0xC6 + ACK <
I2C,0xBF + ACK <
I2C,0x57 + ACK I2C,0x57 + ACK
I2C,0x51 + ACK | I2C,0xA2 + ACK
I2C,0x3D + ACK | I2C,0xA2 + ACK
I2C,0x86 + ACK | I2C,0xBC + ACK
> I2C,0x80 + ACK
> I2C,0x33 + ACK
I2C,0x7F + ACK I2C,0x7F + ACK
I2C,0xCD + ACK | I2C,0xB7 + ACK
I2C,0xD7 + ACK | I2C,0x58 + ACK
I2C,0xEA + ACK | I2C,0x65 + ACK
I2C,0x6E + ACK <
I2C,0xA7 + ACK <
I2C,0xFB + ACK <
I2C,0xFD + ACK <
I2C,0x69 + ACK <
I2C,0x0B + ACK <
I2C,0x4A + ACK <
I2C,0xD4 + ACK <
I2C,0xBF + ACK <
I2C,0x5B + ACK <
I2C,0xD8 + ACK I2C,0xD8 + ACK
I2C,0x34 + ACK | I2C,0xC6 + NAK
I2C,0x2D + ACK <
I2C,0xD5 + ACK <
I2C,0xBF + ACK <
I2C,0xC3 + ACK <
I2C,0xE2 + ACK <
I2C,0x07 + ACK <
I2C,0xD7 + ACK <
I2C,0x59 + ACK <
I2C,0x71 + NAK <
I2C,Setup Write to [0x20] + ACK I2C,Setup Write to [0x20] + ACK
I2C,Setup Read to [0x21] + ACK I2C,Setup Read to [0x21] + ACK
I2C,0x19 + NAK I2C,0x19 + NAK
I2C,0x10 + NAK I2C,0x10 + NAK
I2C,Setup Write to [0x20] + NAK I2C,Setup Write to [0x20] + NAK
I2C,0x66 + ACK I2C,0x66 + ACK
I2C,0x20 + ACK I2C,0x20 + ACK
I2C,0x22 + ACK I2C,0x22 + ACK
I2C,0x30 + ACK I2C,0x30 + ACK
I2C,0xEB + ACK I2C,0xEB + ACK
I2C,0x05 + ACK I2C,0x05 + ACK
I2C,Setup Write to [0x20] + ACK I2C,Setup Write to [0x20] + ACKhttps://www.raspberrypi.org/forums/viewtopic.php?f=43&t=109137&p=1250619#p1250619
I2C,0x0C + ACK I2C,0x0C + ACK
I2C,0xFF + ACK I2C,0xFF + ACK
I2C,0x09 + ACK I2C,0x09 + ACK
I2C,0x28 + ACK I2C,0x28 + ACK
I2C,0x2A + ACK I2C,0x2A + ACK
I2C,0x01 + ACK I2C,0x01 + ACKhttps://www.raspberrypi.org/forums/viewtopic.php?f=43&t=109137&p=1250619#p1250619
I2C,0x5A + ACK I2C,0x5A + ACK
I2C,0x85 + ACK I2C,0x85 + ACK
I2C,0x89 + ACK I2C,0x89 + ACK
I2C,0x62 + ACK I2C,0x62 + ACK
I2C,0x0D + ACK I2C,0x0D + ACK
I2C,0xE8 + ACK I2C,0xE8 + ACK
I2C,0x64 + ACK I2C,0x64 + ACK
I2C,0x08 + ACK I2C,0x08 + ACK
I2C,0xE7 + ACK I2C,0xE7 + ACK
I2C,0xF0 + ACK I2C,0xF0 + ACK
I2C,0x6A + ACK I2C,0x6A + ACK
I2C,0x06 + ACK I2C,0x06 + ACK
I2C,0xAF + ACK I2C,0xAF + ACK
I2C,0x80 + ACK I2C,0x80 + ACK
I2C,0x6E + ACK I2C,0x6E + ACK
I2C,0xE0 + ACK I2C,0xE0 + ACK
I2C,0x70 + ACK I2C,0x70 + ACK
I2C,0x74 + ACK I2C,0x74 + ACK
I2C,0x8C + ACK I2C,0x8C + ACK
I2C,0x39 + ACK I2C,0x39 + ACK
I2C,0x0B + ACK I2C,0x0B + ACK
I2C,0x72 + ACK I2C,0x72 + ACK
I2C,0x45 + ACK I2C,0x45 + ACK
I2C,0x47 + ACK I2C,0x47 + ACK
I2C,0x4B + ACK I2C,0x4B + ACK
I2C,0x67 + ACK I2C,0x67 + ACK
I2C,0x0F + ACK | I2C,0x0F + NAK
I2C,0x50 + ACK I2C,0x50 + ACK
I2C,0xB4 + ACK I2C,0xB4 + ACK
I2C,0x13 + ACK I2C,0x13 + ACK
I2C,0x8B + ACK I2C,0x8B + ACK
I2C,0x10 + ACK I2C,0x10 + ACK
I2C,0x93 + ACK I2C,0x93 + ACK
I2C,0x97 + ACK I2C,0x97 + ACK
I2C,0x0E + ACK I2C,0x0E + ACK
I2C,0x9B + ACK I2C,0x9B + ACK
I2C,0x04 + ACK I2C,0x04 + ACK
I2C,0xFD + ACK I2C,0xFD + ACK
I2C,0x57 + ACK <
I2C,0xE0 + ACK <
I2C,Setup Write to [0x20] + ACK <
I2C,0x01 + ACK <
I2C,0x0C + NAK | I2C,0x09 + ACK
I2C,0x05 + ACK | I2C,0x0A + ACK
I2C,0x0F + ACK I2C,0x0F + ACK
I2C,0x55 + ACK I2C,0x55 + ACK
I2C,0x2F + ACK I2C,0x2F + ACK
I2C,0xE0 + ACK | I2C,0x00 + ACK
I2C,0xE5 + ACK | I2C,0x00 + ACK
I2C,0x2E + ACK I2C,0x2E + ACK
I2C,0x00 + ACK I2C,0x00 + ACKThe differences starting here and later can be ignored, since 0x01,0x00,0x00 is lock down of data lanes after 3 seconds of recording:
I2C,0x57 + ACK <
I2C,0xE0 + ACK <
I2C,0x01 + ACK <
...Some questions on capturing register sets now:
- Shouldn't v2 camera give identical I2C captures for executing and capturing same command twice as v1 camera does?
- I read that v2 camera has some crypto chip inside -- does that affect I2C channel from Raspberry to camera, or only data lanes back from camera to Raspberry?
- In case there will always be a small amount of differences for different captures of same command, is it OK to take any of them?
- What should be the command to capture for a given mode? Perhaps "raspivid -md 7 -t 3000 -o /dev/null"?
The new 8Mpixel mode is cool,
https://stamm-wilbrandt.de/en/forum/8Mpixel.test.jpg
although I am much more interested in high framerate modes derived from 640x480 or 1280x720 ...
- with v1 camera with 480p at 90fps, new modes 640x128_s stretched or 640x64 can do 665fps
- according imx219 datasheet: 180 frame/s @720p
- if linearity is given between both chips, maybe imx219 can do 1.5*2=3 times better at 2000fps?!?!?
- a 320x240 mode at 540fps would be nice as well ...
