I am currently having trouble when i use a too short period between captures :
When i capture an image, my screen display just show the image captured for like 0.5 secondes (i would like to remove that but don't know if its possible and if my problem is caused by that) and then the camera stream start again.
But at this moment, the speckle gonna moves and will stabilisizes after maybe 2 secondes.
I suspect an autoset mod that i couldn't set off (sherlock).
I would like to have a 'fix' streaming cause i have to check how is the speckle moving (i can 'solve' the problem with a bigger period but would like to use 1 seconds or even less if possible) :/
Any idea how could i fix that ?
Thanks !
