bob332
Extending HQ Pi Cam
Sat Jul 24, 2021 10:22 pm
What would be the best extension to extend the camera cable too 100'+?
Electrical outlets can be installed along the way if necessary, and I don't care what type of cable it needs to be - it could be a tiny csi->HDMI or the camera board ( 2 or 4 layer depending on shielding if that would help ) itself could have a HDMI on it, or if there is schematic around I could build off of that (I could re-learn Eagle or learn KiCAD if necessary ). Hell, I could build a HDMI cable if I was led to the schematic of one. Ethernet to HDMI is not a problem either as I have all the tools to make Ethernet cables up to 6a.
I just need crystal clear 1080 up to 4k video (not going to a higher res due to cost ), and this would be for an inside setup, so temp will not be an issue and I don't use the heater in the winter ( PHX, AZ).
Thanks in advance,
Bob
Gavinmc42
Re: Extending HQ Pi Cam
Sun Jul 25, 2021 12:59 am
Why not just stick a Pi there and use 1Gbs Ethernet?
Jeff Geerling is getting 2.5Gbs with CM4 solutions.
The CM4 maxes out at about 3.5Gbs.
A HDMI solution is possible, TV station cabling?
Won't be cheap.
I'm dancing on Rainbows.
bob332
Sun Jul 25, 2021 2:03 am
Thanks, was not aware of that!
6by9
Sun Jul 25, 2021 9:03 am
CSI2 is designed for up to about 30cm. Anything more is chance as to whether it works. Some people have had it working at a couple of metres when using high quality HDMI leads and adapters (HDMI happens to have the right number of screened differential pairs), but nowhere near 100'.
IP is your best bet.
TV studios will generally use SDI, as a single coax is far easier to handle than the multiple differential pairs required for HDMI.
BillyBonce
Tue Jul 27, 2021 7:44 am
Welcome to hell...
Many years ago make a system (industrial television) based on diskless stations and an rtsp streaming server (on Ubuntu 12.04 on both sides). Distance between cam and control center around 5 km.
Fiber optic was used as a backbone.
Gavinmc42
Tue Jul 27, 2021 9:15 am
I saw some HDMI over fibre cables just yesterday.
Surprising cheap from a big electronics retailer/wholesaler. :lol:
18GBs $240 AUD for 30M
cleverca22
Wed Jul 28, 2021 4:36 pm
but those expect a proper hdmi protocol, not CSI over an hdmi cable
Gavinmc42
Wed Jul 28, 2021 10:39 pm
Have not pulled one apart, but differential pairs to fibre then back again should be protocol independent?
HDMI over Ethernet cable?
trejan
Wed Jul 28, 2021 10:59 pm
It might not care what protocol is going over it but the voltages and signalling method are completely different so not compatible.
cleverca22
Wed Jul 28, 2021 11:32 pm
CSI and DSI also have a bus turn-around thing, where the direction of data flow changes
a dumb hdmi signal converter wont allow data to flow the other direction
aBUGSworstnightmare
Thu Jul 29, 2021 5:31 am
Thanks in advance,
Bob
100' is 3048cm, right? What about https://www.thinesolutions.com/cable-extension-kit ? https://thepihut.com/products/lan-cable ... -pi-camera or if you prefer DIY https://www.thine.co.jp/en/products/detail/THCV242.html
Last edited by aBUGSworstnightmare on Thu Jul 29, 2021 5:34 am, edited 1 time in total.
schoolpost
Thu Jul 29, 2021 5:33 am
I've posted this one here in the past ( one of the first results if you google camera extender for pi ) I own one and can vouch for it's operation.
https://www.tomshardware.com/news/camer ... the-action
https://www.digikey.ca/en/products/deta ... 1/13883531
https://static1.squarespace.com/static/ ... SER101.pdf
Haven't tried with super long cables, but it states it can do 20M length.
This seems like a pretty good option. Don't mess with those HDMI options IMO. That or keep the Pi closer to the camera and just do your data processing/application over ethernet using traditional protocol to a different PC?
EDIT: looks like aBUGSworstnightmare beat me to it ;)
-Csaba Nagy
Return to “Camera board”
