HavijMirza
HDMI2CSI Image processing problem
Tue Jun 15, 2021 2:46 am
Hi to all.
We are working on a project about HDMI processing.
our goal is to detect pixels or lines with certain criteria in the input frames
Problem is code works fine for either black or white pixels but not in between.how can we fix it?
camera = PiCamera()
camera.resolution = (1280, 720)
camera.framerate = 25
camera.image_denoise = False
rawCapture = PiRGBArray(camera, size=(1280, 720))
# allow the camera to warmup
print("sleep for 5 seconds ...")
time.sleep(5)
i =0
# capture frames from the camera
for frame in camera.capture_continuous(rawCapture, format="rgb", use_video_port=True):
        # grab the raw NumPy array representing the image, then initialize the timestamp
        # and occupied/unoccupied text
        image = frame.array
        if i==10:
                print("Pixels after 10 rounds:", "\n")
                #show_pixels(image)
                #pil_image.save('hdmi_image.png')
                print(image[0,0])
                print(image[0,1])
                print(image[0,2])
                print(image[0,3])
                print(image[0,4])
                break
        i = i+1
____________________________________________________________________________________________________
camera = PiCamera()
camera.resolution = (1024, 768)
rawCapture = PiRGBAArray(camera)
print("wait 5 seconds to warmup camera ...")
time.sleep(5)
i =0
for frame in camera.capture_continuous(rawCapture, format="bgra", use_video_port=True):
        image = frame.array
        if i==10:
                #show_pixels(image)
                print(image[0,0])
                print(image[0,1])
                print(image[0,2])
                print(image[0,3])
                print(image[0,4])
                break
        i = i+1
with picamera.PiCamera() as camera:
    with picamera.array.PiYUVArray(camera) as stream:
        camera.start_preview()
        time.sleep(2)
        camera.capture(stream, 'yuv')
        # Show size of YUV data
        print(stream.array.shape)
        # Show size of RGB converted data
        print(stream.rgb_array.shape)
        image = stream.rgb_array
        for i in range (0, 50):
                for j in range (0, image.shape[1]-1):
                        if (image[i,j,0]!=255):
                                print(i,image[i,j])
        print(image[0,0])
        print(image[0,1])
        print(image[0,2])
        print(image[0,3])
        print(image[0,4])
6by9
Re: HDMI2CSI Image processing problem
Wed Jun 16, 2021 8:20 am
The only results for HDMI2CSI from a search engine are for a TC358840 based board for Nvidia Tegra X1/X2 boards - https://blog.zhaw.ch/high-performance/c ... /hdmi2csi/
If you're referring to the TC358743 boards HDMI to CSI2 that work with the Pi, then the firmware based drivers (as used via picamera) are unsupported and are only provided as-is.
The V4L2 drivers are supported - see viewtopic.php?f=38&t=281972
HavijMirza
Sun Jun 20, 2021 6:13 pm
Thank you for your reaply.
I meant Auvidea b101
TC358743
https://auvidea.eu/product/70501/
Return to “Camera board”
