drmatt
matching csi2 camera with i2c device
Tue Jun 15, 2021 4:06 am
This question concerns user-space operation of mipi csi2 cameras, as in raspiraw. For a given cm4 carrier board with two csi2 ports, is there any way to automatically determine which port goes with which i2c bus / device? In other words, we probe i2c-0 and find camera #1, and we probe i2c-10 and find camera #2, but which one receives its frame data using camera_num=0 and which one using camera_num=1?
And a loosely related question: is there a way to swap the assignment of i2c-0 and i2c-10 when using dtparam=i2c_vc=on in /boot/config.txt?
cleverca22
Re: matching csi2 camera with i2c device
Tue Jun 15, 2021 4:19 am
i think ideally, that would be handled with device-tree
you would use a DT overlay to describe that pairing to linux and the unicam driver, and then it all works without userland having to know how its wired up
6by9
Tue Jun 15, 2021 8:32 am
No because it could be wired up either way. The two data paths are totally independent, so whatever is controlling them must be told.
drmatt wrote:And a loosely related question: is there a way to swap the assignment of i2c-0 and i2c-10 when using dtparam=i2c_vc=on in /boot/config.txt?
Only by disabling the mux and dropping back to just i2c-0 on the pins of your choice.
Do NOT use dtparam=i2c_vc=on, but replace it with dtoverlay=i2c0,pins_44_45 and i2c-0 will be on 44&45. This will be incompatible with most of the camera driver overlays, so do not mix and match.
You could reassign the aliases, but don't that to be supported in the main kernel/firmware as it'll just cause confusion.
drmatt
Wed Jun 16, 2021 9:32 pm
This all makes sense. We'll try a couple of options - many thanks!
Return to “Camera board”
