rollyng
libcamera-raw fails with 4K resolution
Wed Jun 16, 2021 9:38 am
Dear all,
I used to run raspiraw to capture 4K raw data with the HQCam on a Pi4B 8GB. Recently, I would like to try libcamera-raw and found that it fails with the similar configuration. Here is the output:
./libcamera-raw -t 100 --width=4056 --height=3040 --shutter=100 --segment 1 -o /mnt/ramdisk/4k_%03d.raw
WARNING: consider inline headers with 'pause'/split/segment/circular
[0:21:32.873722322] [2637]  INFO Camera camera_manager.cpp:294 libcamera v0.0.0+2681-1fea2730
[0:21:32.914644083] [2640]  WARN CameraSensor camera_sensor.cpp:196 'imx477 10-001a': Recommended V4L2 control 0x009a0922 not supported
[0:21:32.914910826] [2640]  WARN CameraSensor camera_sensor.cpp:248 'imx477 10-001a': The sensor kernel driver needs to be fixed
[0:21:32.914965178] [2640]  WARN CameraSensor camera_sensor.cpp:250 'imx477 10-001a': See Documentation/sensor_driver_requirements.rst in the libcamera sources for more information
[0:21:32.921414343] [2640]  WARN CameraSensorProperties camera_sensor_properties.cpp:100 No static properties available for 'imx477'
[0:21:32.921544843] [2640]  WARN CameraSensorProperties camera_sensor_properties.cpp:102 Please consider updating the camera sensor properties database
[0:21:32.921622548] [2640]  WARN CameraSensor camera_sensor.cpp:402 'imx477 10-001a': Failed to retrieve the camera location
[0:21:33.108766666] [2637]  WARN V4L2 v4l2_pixelformat.cpp:180 Unsupported V4L2 pixel format XB24
[0:21:33.109448984] [2637]  INFO RPI raspberrypi.cpp:121 Mode: 1332x990 fmt RG10 Score: 11052.2 (best 11052.2)
[0:21:33.109595782] [2637]  INFO RPI raspberrypi.cpp:121 Mode: 4056x3040 fmt RG12 Score: 500 (best 500)
[0:21:33.109658800] [2637]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1520 fmt RG12 Score: 7596 (best 500)
[0:21:33.109715134] [2637]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1080 fmt RG12 Score: 8679.84 (best 500)
[0:21:33.109778264] [2637]  INFO RPI raspberrypi.cpp:121 Mode: 1332x990 fmt pRAA Score: 10552.2 (best 500)
[0:21:33.109840838] [2637]  INFO RPI raspberrypi.cpp:121 Mode: 4056x3040 fmt pRCC Score: 0 (best 0)
[0:21:33.109897783] [2637]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1520 fmt pRCC Score: 7096 (best 0)
[0:21:33.109951302] [2637]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1080 fmt pRCC Score: 8179.84 (best 0)
[0:21:33.110839603] [2637]  INFO RPI raspberrypi.cpp:121 Mode: 1332x990 fmt RG10 Score: 11052.2 (best 11052.2)
[0:21:33.111143938] [2637]  INFO RPI raspberrypi.cpp:121 Mode: 4056x3040 fmt RG12 Score: 500 (best 500)
[0:21:33.111205698] [2637]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1520 fmt RG12 Score: 7596 (best 500)
[0:21:33.111263069] [2637]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1080 fmt RG12 Score: 8679.84 (best 500)
[0:21:33.111325180] [2637]  INFO RPI raspberrypi.cpp:121 Mode: 1332x990 fmt pRAA Score: 10552.2 (best 500)
[0:21:33.111387736] [2637]  INFO RPI raspberrypi.cpp:121 Mode: 4056x3040 fmt pRCC Score: 0 (best 0)
[0:21:33.111441273] [2637]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1520 fmt pRCC Score: 7096 (best 0)
[0:21:33.111495255] [2637]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1080 fmt pRCC Score: 8179.84 (best 0)
[0:21:33.112758780] [2637]  INFO RPI raspberrypi.cpp:121 Mode: 1332x990 fmt RG10 Score: 11052.2 (best 11052.2)
[0:21:33.112884985] [2637]  INFO RPI raspberrypi.cpp:121 Mode: 4056x3040 fmt RG12 Score: 500 (best 500)
[0:21:33.112946004] [2637]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1520 fmt RG12 Score: 7596 (best 500)
[0:21:33.113002615] [2637]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1080 fmt RG12 Score: 8679.84 (best 500)
[0:21:33.113065375] [2637]  INFO RPI raspberrypi.cpp:121 Mode: 1332x990 fmt pRAA Score: 10552.2 (best 500)
[0:21:33.113127394] [2637]  INFO RPI raspberrypi.cpp:121 Mode: 4056x3040 fmt pRCC Score: 0 (best 0)
[0:21:33.113184449] [2637]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1520 fmt pRCC Score: 7096 (best 0)
[0:21:33.113238450] [2637]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1080 fmt pRCC Score: 8179.84 (best 0)
[0:21:33.113825064] [2637]  INFO RPI raspberrypi.cpp:121 Mode: 1332x990 fmt RG10 Score: 11052.2 (best 11052.2)
[0:21:33.113923750] [2637]  INFO RPI raspberrypi.cpp:121 Mode: 4056x3040 fmt RG12 Score: 500 (best 500)
[0:21:33.113981491] [2637]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1520 fmt RG12 Score: 7596 (best 500)
[0:21:33.114036306] [2637]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1080 fmt RG12 Score: 8679.84 (best 500)
[0:21:33.114096695] [2637]  INFO RPI raspberrypi.cpp:121 Mode: 1332x990 fmt pRAA Score: 10552.2 (best 500)
[0:21:33.114168492] [2637]  INFO RPI raspberrypi.cpp:121 Mode: 4056x3040 fmt pRCC Score: 0 (best 0)
[0:21:33.114221696] [2637]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1520 fmt pRCC Score: 7096 (best 0)
[0:21:33.114275289] [2637]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1080 fmt pRCC Score: 8179.84 (best 0)
[0:21:33.114640494] [2637]  INFO Camera camera.cpp:905 configuring streams: (0) 4056x3040-YUV420 (1) 4056x3040-SBGGR12_CSI2P
[0:21:33.115297924] [2640]  INFO RPI raspberrypi.cpp:121 Mode: 1332x990 fmt RG10 Score: 11052.2 (best 11052.2)
[0:21:33.115417776] [2640]  INFO RPI raspberrypi.cpp:121 Mode: 4056x3040 fmt RG12 Score: 500 (best 500)
[0:21:33.115475703] [2640]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1520 fmt RG12 Score: 7596 (best 500)
[0:21:33.115530573] [2640]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1080 fmt RG12 Score: 8679.84 (best 500)
[0:21:33.115590037] [2640]  INFO RPI raspberrypi.cpp:121 Mode: 1332x990 fmt pRAA Score: 10552.2 (best 500)
[0:21:33.115651556] [2640]  INFO RPI raspberrypi.cpp:121 Mode: 4056x3040 fmt pRCC Score: 0 (best 0)
[0:21:33.115705389] [2640]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1520 fmt pRCC Score: 7096 (best 0)
[0:21:33.115758889] [2640]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1080 fmt pRCC Score: 8179.84 (best 0)
[0:21:33.116102502] [2640]  INFO RPI raspberrypi.cpp:618 Sensor: /base/soc/i2c0mux/i2c@1/imx477@1a - Selected mode: 4056x3040-pRCC
[0:21:33.256361456] [2640] ERROR V4L2 v4l2_videodevice.cpp:1133 /dev/video0[12:cap]: Not enough buffers provided by V4L2VideoDevice
ERROR: *** failed to allocate capture buffers ***
I have tested 2K resolution which produce 22 raw files,
./libcamera-raw -t 100 --width=2028 --height=1520 --shutter=100 --segment 1 -o /mnt/ramdisk/2k_%03d.raw
The output i,
pi@raspberrypi:~/libcamera-apps/build $ ./libcamera-raw -t 100 --width=2028 --height=1520 --shutter=100 --segment 1 -o /mnt/ramdisk/2k_%03d.raw
[0:24:52.858803797] [2702]  INFO Camera camera_manager.cpp:294 libcamera v0.0.0+2681-1fea2730
[0:24:52.900338437] [2705]  WARN CameraSensor camera_sensor.cpp:196 'imx477 10-001a': Recommended V4L2 control 0x009a0922 not supported
[0:24:52.900615605] [2705]  WARN CameraSensor camera_sensor.cpp:248 'imx477 10-001a': The sensor kernel driver needs to be fixed
[0:24:52.900707199] [2705]  WARN CameraSensor camera_sensor.cpp:250 'imx477 10-001a': See Documentation/sensor_driver_requirements.rst in the libcamera sources for more information
[0:24:52.909133409] [2705]  WARN CameraSensorProperties camera_sensor_properties.cpp:100 No static properties available for 'imx477'
[0:24:52.909320465] [2705]  WARN CameraSensorProperties camera_sensor_properties.cpp:102 Please consider updating the camera sensor properties database
[0:24:52.909439670] [2705]  WARN CameraSensor camera_sensor.cpp:402 'imx477 10-001a': Failed to retrieve the camera location
[0:24:53.105686960] [2702]  WARN V4L2 v4l2_pixelformat.cpp:180 Unsupported V4L2 pixel format XB24
[0:24:53.106737058] [2702]  INFO RPI raspberrypi.cpp:121 Mode: 1332x990 fmt RG10 Score: 11052.2 (best 11052.2)
[0:24:53.106949429] [2702]  INFO RPI raspberrypi.cpp:121 Mode: 4056x3040 fmt RG12 Score: 500 (best 500)
[0:24:53.107010763] [2702]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1520 fmt RG12 Score: 7596 (best 500)
[0:24:53.107069726] [2702]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1080 fmt RG12 Score: 8679.84 (best 500)
[0:24:53.107131412] [2702]  INFO RPI raspberrypi.cpp:121 Mode: 1332x990 fmt pRAA Score: 10552.2 (best 500)
[0:24:53.107193190] [2702]  INFO RPI raspberrypi.cpp:121 Mode: 4056x3040 fmt pRCC Score: 0 (best 0)
[0:24:53.107248616] [2702]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1520 fmt pRCC Score: 7096 (best 0)
[0:24:53.107302894] [2702]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1080 fmt pRCC Score: 8179.84 (best 0)
[0:24:53.107825508] [2702]  INFO RPI raspberrypi.cpp:121 Mode: 1332x990 fmt RG10 Score: 11052.2 (best 11052.2)
[0:24:53.107917175] [2702]  INFO RPI raspberrypi.cpp:121 Mode: 4056x3040 fmt RG12 Score: 500 (best 500)
[0:24:53.107974120] [2702]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1520 fmt RG12 Score: 7596 (best 500)
[0:24:53.108084324] [2702]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1080 fmt RG12 Score: 8679.84 (best 500)
[0:24:53.108147176] [2702]  INFO RPI raspberrypi.cpp:121 Mode: 1332x990 fmt pRAA Score: 10552.2 (best 500)
[0:24:53.108211084] [2702]  INFO RPI raspberrypi.cpp:121 Mode: 4056x3040 fmt pRCC Score: 0 (best 0)
[0:24:53.108265547] [2702]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1520 fmt pRCC Score: 7096 (best 0)
[0:24:53.108319288] [2702]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1080 fmt pRCC Score: 8179.84 (best 0)
[0:24:53.109029107] [2702]  INFO RPI raspberrypi.cpp:121 Mode: 1332x990 fmt RG10 Score: 3956.22 (best 3956.22)
[0:24:53.109169978] [2702]  INFO RPI raspberrypi.cpp:121 Mode: 4056x3040 fmt RG12 Score: 1387 (best 1387)
[0:24:53.109227515] [2702]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1520 fmt RG12 Score: 500 (best 500)
[0:24:53.109282237] [2702]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1080 fmt RG12 Score: 1583.84 (best 500)
[0:24:53.109341997] [2702]  INFO RPI raspberrypi.cpp:121 Mode: 1332x990 fmt pRAA Score: 3456.22 (best 500)
[0:24:53.109402627] [2702]  INFO RPI raspberrypi.cpp:121 Mode: 4056x3040 fmt pRCC Score: 887 (best 500)
[0:24:53.109456683] [2702]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1520 fmt pRCC Score: 0 (best 0)
[0:24:53.109510035] [2702]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1080 fmt pRCC Score: 1083.84 (best 0)
[0:24:53.110012667] [2702]  INFO RPI raspberrypi.cpp:121 Mode: 1332x990 fmt RG10 Score: 3956.22 (best 3956.22)
[0:24:53.110085871] [2702]  INFO RPI raspberrypi.cpp:121 Mode: 4056x3040 fmt RG12 Score: 1387 (best 1387)
[0:24:53.110142131] [2702]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1520 fmt RG12 Score: 500 (best 500)
[0:24:53.110196390] [2702]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1080 fmt RG12 Score: 1583.84 (best 500)
[0:24:53.110254446] [2702]  INFO RPI raspberrypi.cpp:121 Mode: 1332x990 fmt pRAA Score: 3456.22 (best 500)
[0:24:53.110313928] [2702]  INFO RPI raspberrypi.cpp:121 Mode: 4056x3040 fmt pRCC Score: 887 (best 500)
[0:24:53.110367817] [2702]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1520 fmt pRCC Score: 0 (best 0)
[0:24:53.110420521] [2702]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1080 fmt pRCC Score: 1083.84 (best 0)
[0:24:53.110742301] [2702]  INFO Camera camera.cpp:905 configuring streams: (0) 2028x1520-YUV420 (1) 2028x1520-SBGGR12_CSI2P
[0:24:53.111529508] [2705]  INFO RPI raspberrypi.cpp:121 Mode: 1332x990 fmt RG10 Score: 3956.22 (best 3956.22)
[0:24:53.111635250] [2705]  INFO RPI raspberrypi.cpp:121 Mode: 4056x3040 fmt RG12 Score: 1387 (best 1387)
[0:24:53.111693176] [2705]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1520 fmt RG12 Score: 500 (best 500)
[0:24:53.111747454] [2705]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1080 fmt RG12 Score: 1583.84 (best 500)
[0:24:53.111804954] [2705]  INFO RPI raspberrypi.cpp:121 Mode: 1332x990 fmt pRAA Score: 3456.22 (best 500)
[0:24:53.111864936] [2705]  INFO RPI raspberrypi.cpp:121 Mode: 4056x3040 fmt pRCC Score: 887 (best 500)
[0:24:53.111918381] [2705]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1520 fmt pRCC Score: 0 (best 0)
[0:24:53.111970474] [2705]  INFO RPI raspberrypi.cpp:121 Mode: 2028x1080 fmt pRCC Score: 1083.84 (best 0)
[0:24:53.112347161] [2705]  INFO RPI raspberrypi.cpp:618 Sensor: /base/soc/i2c0mux/i2c@1/imx477@1a - Selected mode: 2028x1520-pRCC
[0:24:53.208045395] [2708]  INFO IPARPI raspberrypi.cpp:611 Request ctrl: Sharpness = 1.000000
[0:24:53.208330008] [2708]  INFO IPARPI raspberrypi.cpp:611 Request ctrl: Saturation = 1.000000
[0:24:53.208430990] [2708]  INFO IPARPI raspberrypi.cpp:611 Request ctrl: Contrast = 1.000000
[0:24:53.208514620] [2708]  INFO IPARPI raspberrypi.cpp:611 Request ctrl: Brightness = 0.000000
[0:24:53.208580009] [2708]  INFO IPARPI raspberrypi.cpp:611 Request ctrl: AwbMode = 0
[0:24:53.208749102] [2708]  INFO IPARPI raspberrypi.cpp:611 Request ctrl: FrameDurationLimits = [ 33333, 33333 ]
[0:24:53.209003400] [2708]  INFO IPARPI raspberrypi.cpp:611 Request ctrl: NoiseReductionMode = 3
[0:24:53.209274364] [2708]  INFO IPARPI raspberrypi.cpp:611 Request ctrl: ExposureTime = 100
[0:24:53.209423791] [2708]  INFO IPARPI raspberrypi.cpp:611 Request ctrl: AeMeteringMode = 0
[0:24:53.209502014] [2708]  INFO IPARPI raspberrypi.cpp:611 Request ctrl: AeExposureMode = 0
[0:24:53.209580255] [2708]  INFO IPARPI raspberrypi.cpp:611 Request ctrl: ExposureValue = 0.000000
[0:24:53.213086143] [2705]  INFO RPISTREAM rpi_stream.cpp:122 No buffers available for Unicam Image
[0:24:53.213547331] [2705]  INFO RPISTREAM rpi_stream.cpp:122 No buffers available for Unicam Embedded
[0:24:53.213994315] [2705]  INFO RPISTREAM rpi_stream.cpp:122 No buffers available for ISP Output0
[0:24:53.724997469] [2705]  INFO RPISTREAM rpi_stream.cpp:122 No buffers available for Unicam Embedded
[0:24:53.725221322] [2705]  INFO RPISTREAM rpi_stream.cpp:122 No buffers available for Unicam Embedded
[0:24:53.725312323] [2705]  INFO RPISTREAM rpi_stream.cpp:122 No buffers available for Unicam Embedded
[0:24:53.725394601] [2705]  INFO RPISTREAM rpi_stream.cpp:122 No buffers available for Unicam Embedded
[0:24:53.725473768] [2705]  INFO RPISTREAM rpi_stream.cpp:122 No buffers available for Unicam Embedded
[0:24:53.725554879] [2705]  INFO RPISTREAM rpi_stream.cpp:122 No buffers available for Unicam Embedded
[0:24:53.756146648] [2705]  INFO RPI raspberrypi.cpp:1626 Dropping frame at the request of the IPA (6 left)
[0:24:53.787772886] [2705]  INFO RPI raspberrypi.cpp:1626 Dropping frame at the request of the IPA (5 left)
[0:24:53.822532676] [2705]  INFO RPI raspberrypi.cpp:1626 Dropping frame at the request of the IPA (4 left)
[0:24:53.853689096] [2705]  INFO RPI raspberrypi.cpp:1626 Dropping frame at the request of the IPA (3 left)
[0:24:53.885507668] [2705]  INFO RPI raspberrypi.cpp:1626 Dropping frame at the request of the IPA (2 left)
[0:24:53.923241270] [2705]  INFO RPI raspberrypi.cpp:1626 Dropping frame at the request of the IPA (1 left)
[0:24:53.951821158] [2705]  INFO RPI raspberrypi.cpp:1626 Dropping frame at the request of the IPA (0 left)
Raw stream: 2028x1520 stride 3072 format SBGGR12_CSI2P
Can anyone help to to solve the problem? Thank you!
6by9
Re: libcamera-raw fails with 4K resolution
Wed Jun 16, 2021 10:59 am
V4L2 has a slightly weird API in that you ask it to allocate N buffers, but should it not be able to it keeps going and tells you that it allocated M (where M < N). If you need N buffers then the only thing to do is throw an error and quit, which is what libcamera-raw has done.
The default configuration for Pi4 is to have a 256MB CMA heap (which is where these allocations come from), but it is also shared with the display resources.
Edit /boot/config.txt (you'll need to use sudo), find the line "dtoverlay=vc4-fkms-v3d", and make it "dtoverlay=vc4-fkms-v3d,cma-384".
Do NOT increase gpu_mem when using libcamera as there is no point, and both the gpu_mem and CMA heaps have to fit in the bottom 1GB of RAM.
rollyng
Wed Jun 16, 2021 4:26 pm
Thanks very much for your prompt response. I have to change to cma-512 in order to work. To compare the speed of recording individual frame one by one, raspiraw records 6-7 fps on my SSD but with libcamera-raw it reaches 8-9 fps. A good improvement indeed. :D
Return to “Camera board”
