I am still experimenting with the hq cam and raw images via PyDNG.
JPGs look fine - which I guess is the result of internal noise reduction.
The images are taken with in a dark room with a roughly synchronised strobe light via a subprocess call of raspistill.
Does anyone have a tip how to minimise image noise?
Re: HQ-cam noisy DNGs
The point of using RAW images is so you can have better options when processing the images in programs like RawTherapee etc.. ? You are supposed to postprocess them which include finetuning the noise-suppression.
Other tip:
Don't take pictures in a dark room
Other tip:
Thanks for the reply!
I’m aware how raw works, but thought there might be a calibration or filter option that could be used.
- Contact: Website
Thanks!
I’m already minimaxing focus, exposure and strobe intensity... what have you.
My “fixed” measurements so far:
Optimal aperture is roughly between f5.6 an f8
The shortest capture time I can reliably manage over all 12 cams used is 1/4s
(Trigger, delay x, flash)
I can indeed reduce noise via adobe raw, and all the images are - given they come out of a raspberry- very good.
I was just wondering, if I could spare myself some time and calibrate the raw profile or apply a filter at the pi level
