metalmajor
FPS influence possible by writing to sd-card?
Mon Dec 02, 2019 6:43 pm
I have an application in C++, and I record 640x480 jpg images to an SD-card on the PI3B+. This works, but sometimes I get some frame skips. The pts timestamps shows a diff of 1800 ms sometimes, so there is a gap there. Now when I record to a tmpfs instead of an sd-card, then I never have those gaps. Is there some sort of correlation between the camera bandwidth and SD-card writes? How could I detect where the framedrop happens, and why?
Best regards,
Tom,
topguy
Re: FPS influence possible by writing to sd-card?
Mon Dec 02, 2019 7:05 pm
I think the ext4 file system flush its cached data about every 5 seconds and writing to sd-flash is a bit slow, so while this is happening creating/writing new files might be blocking. In a RAM disk write time is not an issue.
metalmajor
Mon Dec 02, 2019 7:43 pm
Maybe I should have mentioned that I already do the writes in a separate thread.
I just did a test where I only capture the camera in my program, and in a separate shell i run a dd /dev/urandom to a file on my sdcard, and after a few seconds i start to see the frameskips in my program.
So I want to know if this is some known behaviour that sdcard bandwidth and the camera bandwidth are somehow shared?
Mon Dec 02, 2019 9:29 pm
Not shared, but they do affect each other. The camera can work fine is you dump the data to NUL, but as soon as you start writing to the SD card, that can affect the rest of the system. So if the system has to go off and write a load of data to the card, that can affect processing elsewhere. There could be locks going on inside the kernel that are held a bit longer whilst the write is happening for example, that could affect something else. Not easy to find out what though, but there is no direct link between the CSI bus and the SD card bus.
HermannSW
Tue Dec 03, 2019 12:06 am
1800ms frame skip is 900ms between frames, is roughly 1 frame per second only.
If you alternatively would record a [email protected] video, even the Pi Zero would have no problem to store the resulting [GPU] compressed .h264 video to SD card.
And you can extract the frames easily into JPEG frames with this command in post-processing:
You can verify that no frameskips happen that way by using raspivid's "-pts" option that writes timestamps while recording:
raspivid -md 7 -w 640 -h 480 -p 22,50,640,480 -pts tst.pts -o tst.h264
You can analyze the generated timestamp file using this tool:
https://github.com/Hermann-SW/userland/ ... ptsanalyze
./ptsanalyze tst.pts 0
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/github_repo_i420toh264
https://twitter.com/HermannSW
Return to “Camera board”
