Lactobacillus
Longer exposure time with camera V1
Sun Oct 20, 2019 10:20 am
I tried to extend the maximum exposure time on camera V1. I have good and bad news.
The good news:
Lowering the register value 0x3036 (SC_CMMN_PLL_MULTIPLIER) extends the exposure time.
Increasing the upper nibble of 0x3035 (SC_CMMN_PLL_CTRL1) extend the exposure time by dividing all clocks.
Increasing the register value 0x380C and 0x380D (TIMING_HTS) extends the exposure time (max 0x1FFF).
This way I could take shots of about 25 s exposure with raspiraw.
0x3036 = 0x30
0x3035 = 0x81
0x380D = 0xFF
Also: line_time_ns in ov5647_modes.h set to 889026
Tha bad news:
The reproduceablilty of my experiments was really bad. I tried different or the same register settings on different days and got good and bad results with the same settings. Sometimes no images were captured, sometimes they were broken (missing lines). It seems that the timing for the start of a line is broken. Does anyone has an idea how to fix this?
Raspberry Pi 1B; Rev2; 512mb RAM (Samsung)
Raspberry Pi Zero, V1.3 + Esp8266
6by9
Re: Longer exposure time with camera V1
Sun Oct 20, 2019 12:52 pm
Messing with pll settings is not something that can sensibly be merged into the firmware. PLL changes typically take a short period of time to adapt, so swapping settings between modes is likely to mean bad behaviour on mode switches.
Lactobacillus
Sun Oct 20, 2019 6:30 pm
Attached you can find an exemplary image.
Is the responsible part of the firmware closed?
I took about 5 images with raspiraw waited some time and took more with a new instance but the same settings. So you expect better results when i take 50 images?
Lactobacillus
Sat Nov 02, 2019 9:32 pm
I tried to take more photos in a row. No improvement.
Is there anything I can do to optimize the timings of the firmware?
Lactobacillus
Fri Nov 08, 2019 8:55 pm
I looked around a bit in the code of raspiraw and the forums.
MMAL_PARAMETER_CAMERA_RX_TIMING looks promising.
Could the arrays in this line and the following line be modified to fix my problem?
What do the different elments of the arrays do?
Lactobacillus
Thu Nov 14, 2019 9:47 pm
I would be really thankful for help. Most of the people here rapid videos or photos of small things. I try to do something different:
Long exposures of big things (stars/planets). This can even evolve to something what can relatively easy been done in class to teach kids more about space.
Maybe someone with knowledge about the camera driver (@6by9; @HermannSW) can give at least a hint where I have to look to fix the problem.
gordon77
Thu Nov 14, 2019 10:06 pm
You don't need really long exposures for planets, but you need a larger scope.
https://www.raspberrypi.org/forums/view ... 25#p537459
https://www.raspberrypi.org/forums/view ... 00#p518110
Return to “Camera board”
