Uraforclain
Using RaspberryPi 3 with Pi-Camera and OpenCV to do PeopleCounting From the Top
Wed Jan 17, 2018 10:42 am
I have been stuck for sometime now. Does anyone know of any links that can help me with using
Raspberry Pi 3 connected to a Pi Cam NOT webcam
Then using both hardware mentioned above i wan to use any available software I'm guessing openCV to do people counting from the top.
Example Video: https://www.youtube.com/watch?v=BszUJXLR2oA
Almost all available examples using the raspberry pi to do people counting from the top doesnt use the picam.. webcams are big and bulky. So if there is any tutorial or what available please help. Thank You
supra
Re: Using RaspberryPi 3 with Pi-Camera and OpenCV to do PeopleCounting From the Top
Thu Jan 18, 2018 3:16 am
I attempted this link https://www.hackster.io/phfbertoleti/co ... ncv-015ba5 and it worked for me with webcam. U can attempt with picamera. It will work from top too
Uraforclain
Thu Jan 18, 2018 4:40 am
Actually i attempted this
https://www.hackster.io/deligence-techn ... hon-faf14f
It works with my USB webcam but i have no idea how to use the picam as the input :(
This is the code for the programme that i want which works with normal USB cam
import argparse
import datetime
import imutils
import math
import cv2
import numpy as np
width = 800
textIn = 0
textOut = 0
def testIntersectionIn(x, y):
    res = -450 * x + 400 * y + 157500
    if((res >= -550) and  (res < 550)):
        print (str(res))
        return True
    return False
def testIntersectionOut(x, y):
    res = -450 * x + 400 * y + 180000
    if ((res >= -550) and (res <= 550)):
        print (str(res))
        return True
    return False
camera = cv2.VideoCapture(0)
firstFrame = None
while True:
    (grabbed, frame) = camera.read()
    text = "Unoccupied"
    if not grabbed:
        break
    frame = imutils.resize(frame, width=width)
    gray = cv2.cvtColor(frame, cv2.COLOR_BGR2GRAY)
    gray = cv2.GaussianBlur(gray, (21, 21), 0)
    if firstFrame is None:
        firstFrame = gray
        continue
    frameDelta = cv2.absdiff(firstFrame, gray)
    thresh = cv2.threshold(frameDelta, 25, 255, cv2.THRESH_BINARY)[1]
    thresh = cv2.dilate(thresh, None, iterations=2)
    _, cnts, _ = cv2.findContours(thresh.copy(), cv2.RETR_EXTERNAL, cv2.CHAIN_APPROX_SIMPLE)
    for c in cnts:
        if cv2.contourArea(c) < 12000:
            continue
        (x, y, w, h) = cv2.boundingRect(c)
        cv2.rectangle(frame, (x, y), (x + w, y + h), (0, 255, 0), 2)
        cv2.line(frame, (width / 2, 0), (width, 450), (250, 0, 1), 2) #blue line
        cv2.line(frame, (width / 2 - 50, 0), (width - 50, 450), (0, 0, 255), 2)#red line
        rectagleCenterPont = ((x + x + w) /2, (y + y + h) /2)
        cv2.circle(frame, rectagleCenterPont, 1, (0, 0, 255), 5)
        if(testIntersectionIn((x + x + w) / 2, (y + y + h) / 2)):
            textIn += 1
        if(testIntersectionOut((x + x + w) / 2, (y + y + h) / 2)):
            textOut += 1
    if cv2.waitKey(1) & 0xFF == ord('q'):
        break
    cv2.putText(frame, "In: {}".format(str(textIn)), (10, 50),
                cv2.FONT_HERSHEY_SIMPLEX, 0.5, (0, 0, 255), 2)
    cv2.putText(frame, "Out: {}".format(str(textOut)), (10, 70),
    cv2.putText(frame, datetime.datetime.now().strftime("%A %d %B %Y %I:%M:%S%p"),
                (10, frame.shape[0] - 10), cv2.FONT_HERSHEY_SIMPLEX, 0.35, (0, 0, 255), 1)
    cv2.imshow("Security Feed", frame)
camera.release()
cv2.destroyAllWindows()
And this is the code just to simply use picam to stream a video
# import the necessary packages
from picamera.array import PiRGBArray
from picamera import PiCamera
import time
import cv2
# initialize the camera and grab a reference to the raw camera capture
camera = PiCamera()
camera.resolution = (640, 480)
camera.framerate = 32
rawCapture = PiRGBArray(camera, size=(640, 480))
# allow the camera to warmup
time.sleep(0.1)
# capture frames from the camera
for frame in camera.capture_continuous(rawCapture, format="bgr", use_video_port=True):
	# grab the raw NumPy array representing the image, then initialize the timestamp
	# and occupied/unoccupied text
	image = frame.array
	# show the frame
	cv2.imshow("Frame", image)
	key = cv2.waitKey(1) & 0xFF
	# clear the stream in preparation for the next frame
	rawCapture.truncate(0)
	# if the `q` key was pressed, break from the loop
	if key == ord("q"):
		break
Now the problem is i have no idea how to merge both of them together
supra
Thu Jan 18, 2018 2:20 pm
You simply do wrong way.
Follow this example: http://www.linuxcircle.com/2015/05/24/o ... erry-pi-2/
Btw, I don't have for picamera. And also I don't used 3rd party.
6by9
Thu Jan 18, 2018 3:43 pm
sudo modprobe bcm2835-v4l2
will load a V4L2 driver for the Pi camera module, and then everything that works for your webcam should work on the Pi camera.
Please don't send PMs asking for support - use the forum.
Uraforclain
Fri Jan 19, 2018 7:18 am
Hey @6by9 i tried that before yes it works. However, its very laggy 4 seconds to update what i am actually seeing thus i want to use the picamera library in hope it would be less laggy?
6by9
Fri Jan 19, 2018 10:04 am
Have you profiled where the time is being spent?
In your code
is actually grabbing a frame from the camera. How much time does that take compared to processing the frame?
I also see nothing setting the camera resolution in that code. Try adding
camera.set(CAP_PROP_FRAME_WIDTH, 640)
camera.set(CAP_PROP_FRAME_HEIGHT, 480)
after "camera = cv2.VideoCapture(0)".
Uraforclain
Sat Jan 20, 2018 5:30 am
ok I tried,
But i get error:
NameError: name 'CAP_PROP_FRAME_WIDTH' is not defined
and if i try
camera.set(cv2.CAP_PROP_FRAME_WIDTH, 640)
camera.set(cv2.CAP_PROP_FRAME_HEIGHT, 480)
I also get error but it is:
AttributeError: 'module' object has no attribute 'CAP_PROP_FRAM_WIDTH'
Could it be cause I'm not using a legit USB webcam but a piCam and forcing it to believe its a usb webcam via sudo modprobe bcm2835-v4l2
supra
Sun Jan 21, 2018 1:25 am
camera = PiCamera()
Read the link that I posted. This is meley for picamera not webcam.
Uraforclain
Sun Jan 21, 2018 4:26 am
ok guys look.
Supra you are asking me to use the picamera library but i have tried to merge both codes and i came up with this
import time
import cv2
import numpy as np
import argparse
import datetime
import imutils
import math
width = 800
textIn = 0
textOut = 0
firstFrame = None
    res = -450 * x + 400 * y + 157500   #450 400 157500
        print (str(res))
        return True
    return False
        print (str(res))
        return True
    return False
camera = PiCamera()
camera.framerate = 50
camera.hflip = True
time.sleep(0.1)
        (grabbed, frame) = frame.array     			#This is the part that it has error
        text = "Unoccupied"
        if not grabbed:
            break
            firstFrame = gray
            continue
        for c in cnts:
                continue
            cv2.line(frame, (width -15500, 0), (width , 300), (250, 0, 1), 2)  #blue line
            cv2.line(frame, (width -15500, 0), (width , 400), (0, 0, 255), 2) #red line
                textIn += 1
                textOut += 1
            break
        cv2.imshow("Counter", frame)
Find the line which i commented #This is the part that it has error ... And the error message is
  File "Final.py", line 54, in <module>
ValueError: too many values to unpack
So that is why i tried to use what @6by9 did which was to use sudo modprobe bcm2835-v4l2 to make the pi think that my picam is a USB cam but its just too laggy.. so he suggested to change the width and height.. which i cant i get the errors i mentioned above in my previous post.
Return to “Camera board”
Who is online
Users browsing this forum: No registered users and 16 guests
