MudAndSnow
Low power pictures
Tue Oct 17, 2017 11:15 pm
This is my first PI project so please excuse my noobness.
Project: Motion activated battery powered camera with long battery life.
Speed: Take picture within 1 second of motion trigger.
Problem: PI draws too much power while on so it must be powered off until motion trigger but it doesn't look like it can boot in less than 1 second.
Is there any way I can hack an image sensor to take and store a picture quickly while the PI boots up and then once the PI is booted, it reads the picture?
Thanks for any suggestions.
Gavinmc42
Re: Low power pictures
Wed Oct 18, 2017 7:47 am
Not within 1 second low power on a Pi.
This can do it and has long battery life.
http://www.digilant.com.au/products/catch-em-cam
However if 3 seconds is ok it can be done with a Pi.
Camera software on Ultibo will boot is 3sec but for low power you will need some that can detect motion and then turn the Pi on.
Something like this controlling a power switch IC/transistor/power supply
http://au.element14.com/panasonic-elect ... dp/2095731
I'm dancing on Rainbows.
MudAndSnow
Wed Oct 18, 2017 4:38 pm
Thanks Gavin. I have a PIR motion sensor sourced already and am looking for a device where an MCU or PI can have access to the images to process them. I do like the external trigger feature on that camera though.
Gavinmc42
Thu Oct 19, 2017 1:50 am
PIR triggered for game camera, RTC triggered for timelapse.
Someone should make a hat.
Unless the Pi is on all the time no per trigger images can be done, but 3 seconds is ok for time lapse.
Battery life is dependent on duty cycle.
Pi Zero with camera 300ma? ~= 10hours with 3000mahr battery.
turned on 300ma for 5 seconds every minute ~= 120hours
The trick to to make the movement sensor the lowest power possible
MudAndSnow
Thu Oct 19, 2017 3:58 pm
I am looking for about 3 months battery life with about 30 pictures a day. I am hoping the motion sensor is the only thing normally on but I am not sure if cameras exist that can turn on or wake up and take a picture in less than 1 second.
Return to “Camera board”
