Raspberry Vitaly
Ble with record video
Mon Jul 24, 2017 8:07 am
When I try to run the command:
sudo ffmpeg -f video4linux2 -i /dev/video0 -video_size 640x480 -r 25 output.avi
to record video.
In this time,I try to connect with Bluetooth.
The BT cannot connect.
the exception I get is:
A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
Did you encounter with this?
Do you have a clue what can be done?
Re: Ble with record video
Mon Jul 24, 2017 8:32 am
I'm guessing that the ffmpeg commandis taking up all the CPU timne, which is stopped the BT from responding in a sane time. What does 'top' say?
Also, why are you running it under sudo? I don't think that is necessary.
Please direct all questions to the forum, I do not do support via PM.
Raspberry Vitaly
Mon Jul 24, 2017 9:04 am
top result:
1156 root 20 0 299860 197172 137736 S 80.6 20.9 40:21.35 ffmpeg
80.6 % cpu and 20.9 % mem.
all the other processes take less than 1%.
Thu Jul 27, 2017 2:22 pm
Can you run ffmpeg as a normal user? Does that make any difference?
Danielya
Sun Jul 30, 2017 3:00 am
I'm on Vitaly's team so answering on his behalf...
Running the commands without sudo does not make any difference
KyysmaWen
Thu Aug 03, 2017 4:56 pm
Thanks. Need to get back out there and make and catch some more. Work has kept me off the water the last few weeks.
Danielya
Sun Aug 13, 2017 8:39 am
Any news?
Return to “Camera board”
Who is online
Users browsing this forum: herbert570, HermannSW and 15 guests
