MRFNZ
Gerbot - python code issue
Fri Oct 14, 2016 3:26 am
Hi Gert,
I'm using two gertbot h-bridge boards and a Raspberry pi 2 model B to control 3 stepper motors with python 3. I've freed up the uart and can control my motors by using Gert's GUI. I can also control the motors with my own python code BUT this only works if I've first run Gert's GUI and hit the 'connect' button.
Looking at the Gerbot.py functions that I've been using I can see that it is the 'read_uart' call that sometimes returns -1 for the first gertbot board and always returns -1 for the second gertbot board. If I remove the try, except blocks I see that the specific error is 'OSError: [Errno 11] Resource temporarily unavailable'. If I have first connected to the boards with Gert's GUI (without using this to set motor modes etc, just simply clicking connect and then closing the GUI) my python code works fine. It appears that the connect button is doing something that my python code isn't. I've started looking at the C++ source code for the GUI but haven't yet found anything that fixes this problem.
Gert (or someone) do you have a solution or any suggestions?
Below is an example of my python code (works fine after first connecting with GUI) but motor_error is always [x, y, -1] (where x and y are sometimes 0 sometimes -1) if I haven't first connected with the GUI:
import gertbot as gb
MOTOR_MODE = 8                          #Step gray off
STEPS_MM = 25                           #Steps per mm of stepper motors
GERTBOT_IDS = [0, 0, 1]                 #Gertbot IDs for each MOTOR
MOTOR_IDS = [0, 2, 0]                   #Motor IDs for each GERTBOT ID
STEP_FREQUENCY = 600                    #Stepper motor frequency in Hz
def configure_gertbots(gertbot_ids, motor_ids, motor_mode, step_frequency):
    try:
        gb.open_uart(0) # Open serial port to talk to Gertbot
        motor_error = [0]*len(gertbot_ids)
        number_of_posts = len(gertbot_ids)
        for i in range(0, number_of_posts):
            # Setup as steppers
            gb.set_mode(gertbot_ids[i],motor_ids[i],motor_mode)
            # Set the step frequency
            gb.freq_stepper(gertbot_ids[i],motor_ids[i],step_frequency)
            # Set endstops
            gb.set_endstop(gertbot_ids[i],motor_ids[i],0,2)
            # set short mode
            gb.set_short(gertbot_ids[i],motor_ids[i],1)
        # test for errors
            motor_error[i] = gb.read_error_status(gertbot_ids[i])
        print(motor_error)
        return sum(motor_error)
    except:
        return -1
configure_gertbots(GERTBOT_IDS, MOTOR_IDS, MOTOR_MODE, STEP_FREQUENCY)
Any advice would be much appreciated!
Jochem
Return to “Add-ons”
Who is online
Users browsing this forum: No registered users and 5 guests
