linhtran
Gertbot - board not found
Sun Oct 02, 2016 10:59 am
Hi all,
I'm facing a new problem with Gertbot, now when connecting to Raspberry 3, the following messages in log file
"Searching for boards
Board 0...
Not found
Board 1...
Not found
Board 2...
Not found
Board 3...
Not found
No boards found!!
thagrol
Re: Gertbot - board not found
Sun Oct 02, 2016 4:51 pm
Is bluetooth still enabled on your Pi3?
With bluetooth enabled, the serial device expected by the gertbot software (/dev/ttyAMA0) isn't available. You'll need to disable bluetooth and enable the correct serial port in config.txt.
Also have you disabled the getty on the serial port? (see gertbot docs).
Note to self: don't feed the trolls
If you believe "L'enfer, c'est les autres" (Hell is other people) have you considered that it may be of your own making?
Return to “Add-ons”
Who is online
Users browsing this forum: Aydan and 3 guests
