InamKhan
Show 5V on ground pin
Sat Jan 09, 2016 7:17 pm
HI. I have raspberry pi 2 model b. In groud gpio pin 6 it also show 5v voltage what is the actual problem please guaid me ...
gordon77
Re: Show 5V on ground pin
Sat Jan 09, 2016 7:23 pm
Measured relative to where?
InamKhan
Sat Jan 09, 2016 7:33 pm
gordon77 wrote:Measured relative to where?
i mean like gpio 2 it is a 5V voltage supplier pin. and gpio 6 is a ground pin. but in gpio 6 its also show same voltage as shown in VCC pin i mean in gpio 2. actually in all 40 gpio pin its show a 5v voltage .. i use tester to measure the voltage....
gordon77
Sat Jan 09, 2016 7:35 pm
Where are you connecting the other lead from the meter when measuring pin 6?
InamKhan
Sat Jan 09, 2016 7:41 pm
gordon77 wrote:Where are you connecting the other lead from the meter when measuring pin 6?
i use this electric tester to check the voltage and the bulb will be switch on same as on on pin2
gordon77
Sat Jan 09, 2016 7:48 pm
How does this show 5v?
You need a meter connected between the pi pin and the pi gnd pin to measure the volts.
InamKhan
Sat Jan 09, 2016 7:54 pm
gordon77 wrote:How does this show 5v?
the light also burn on ground pin therefore i say that ground pin also give 5V
rzusman
Sat Jan 09, 2016 8:04 pm
Throw that tester away.
It’s useless for this.
gordon77
Sat Jan 09, 2016 8:07 pm
It's probably an a.c. meter just showing hum?
Agree no use for this job.
InamKhan
Sat Jan 09, 2016 8:11 pm
gordon77 wrote:It's probably an a.c. meter justing showing hum?
hmm thanks alot dear
ElEscalador
Sat Jan 09, 2016 8:25 pm
When we measure voltage on a pin it has to be compared to something else - we say 5v for short but in reality we are comparing 5v to a reference which usually happens to be what we call ground. Use a multimeter with two leads and measure from ground to whatever else.
My Autonomous Robot Project and a few of my other projects below.
https://lloydbrombach.wordpress.com/
