jim.glover
Arduino IDE on Jessie fails
Sun Nov 29, 2015 11:42 am
Raspberry Pi Raspbian Jessie clean install
Then I followed the instructions at
https://projects.drogon.net/raspberry-p ... ation-isp/
This worked on wheezy
On Jessie using either arduino on the command line or the Menu item for Arduino IDE
I get this error.
Exception in thread "main" java.lang.ExceptionInInitializerError
at processing.app.Preferences.save(Preferences.java:735)
at processing.app.Preferences.init(Preferences.java:249)
at processing.app.Base.main(Base.java:117)
Caused by: java.awt.HeadlessException
at sun.awt.HeadlessToolkit.getMenuShortcutKeyMask(HeadlessToolkit.java:234)
at processing.core.PApplet.<clinit>(Unknown Source)
... 3 more
Can someone tell what I have done wrong or am missing?
fruit-uk
Re: Arduino IDE on Jessie fails
Sun Nov 29, 2015 9:40 pm
Those instructions are from some time ago.
I have a recollection that the raspbian Arduino IDE was somewhere about v0.6.x at that time.
IIRC jessie now has 1.0.5 so there may have been many internal changes
Milliways
Tue Dec 01, 2015 1:34 am
I haven't actually tried Jessie with the Gertboard, but AFAIK the only changes to avrdude are the configuration files. I have installed the latest Arduino, which includes avrdude: Version 6.1
If you compare /etc/avrdude.conf and /usr/share/arduino/hardware/arduino/boards.txt and ⋯programmer.txt with the modified version you will see changes. Rather than installing the old versions I suggest editing the changes into the new files.
I have been gradually configuring a new installation of Jessie, but had not tackled the Gertboard.
The version of avrdude installed by default with arduino is Version 6.1.
There is no need for a custom avrdude.
This has support for gpio, but it is commented out.
Find linuxgpio in avrdude.conf and uncomment the lines.
Set the pins to the Gertboard values
reset = 8;
sck = 11;
mosi = 10;
miso = 9;
Include Gordon's changes to boards.txt and programmers.txt, but with the following mods from
gpio to linuxgpio
gert328.upload.using=linuxgpio
gert328.upload.protocol=linuxgpio
gpio.protocol=linuxgpio
jim.glover
Tue Dec 01, 2015 2:00 pm
Thanks for your replies.
I have installed the standard arduino and avrdude and made the changes.
Still had the same failure.
The real problem was that my java was defaulting to a headless version - installed for another reason
I configured the java alternative and the Arduino IDE now works again.
Again thanks.
