Gert van Loo
Re: Gertbot
Sat Apr 14, 2018 10:47 am
RS have been the only one still buying from me. You should have a look at their stock.
Manufacturing is done in batches of 2500. As sales have been declining, it is not economic
viable for me to start a new batch. (I sold ~400 last year). I still have a few hundred in stock
but I am not set-up to e.g. sell them on ebay. Too much hassle with packaging, payment, shipment etc.
durian
Re: Gertbot
Sat Apr 14, 2018 3:21 pm
I am trying the new 2.8 GUI now (on a 2.8 gerbot board) and I am not able to specify the ramp up/down for the stepper motor. Wasn't that possible with version 2.8, or did I misunderstand something?
-peter
Gert van Loo
Re: Gertbot
Sat Apr 14, 2018 3:56 pm
I just did the following:
Downloaded the GUI 2.8
Downloaded the gb_upload program.
Connected a gertbot version 2.7
Uploaded version 2.8 to the board.
Started the GUI.
Selected Step Gray Pwr.
Kept the Frequency at 100.
Set the ramp start/stop as 1
Set the ramp speed as 0.1
Set 10000 steps.
Start the stepper motor.
For me it works. Where did you encounter problems?
featherfeet
Re: Gertbot
Sat Apr 14, 2018 6:06 pm
They only have 123 left, and they won't ship to the US. If you stop manufacturing the GertBot's, would you consider releasing the source code for the firmware or even the board layout?
durian
Re: Gertbot
Sun Apr 15, 2018 5:42 am
The ramp-settings were still greyed out and could not be changed. I downloaded the GUI again, now I can change them,
-peter
durian
Re: Gertbot
Sun Apr 15, 2018 10:50 am
Odd behaviour - I was seeing random directions on my stepper motor. Changed to the other plug on the board, now it is working as it should, no more random directions.
-peter
olio
Re: Gertbot
Thu Apr 19, 2018 1:57 pm
I jumped from my thread viewtopic.php?f=42&t=211446 into this one.
I searched here, if there is a similar problem, but I didn't find this specific error message.
Next I wanted to update the board with a new firmware version (2.8).
- Downloaded the gb_upload.exe and the latest firmware as described in the download sequence.
- If I run the executable, then a window opens (Main window) with two active buttons "connect" and "exit" and two inactive buttons "upload" and "download" (greyed out) as well as an empty field.
- I can't do any action with it...pressing "connect" or "exit" shows no reaction. Closing the window results into the message "The window "Main Window" does not seem to be responding..."
I think there is simply a communication failure with the board...maybe something very easy, if it can be found?!
Greetings and have a nice day!
oliver
Gert van Loo
Re: Gertbot
Thu Apr 19, 2018 2:10 pm
Most likely your serial port is not enabled on the Pi3.
See https://www.gertbot.com/pi3.html for how to get your serial port working.
olio
Re: Gertbot
Thu Apr 19, 2018 2:25 pm
that would have been too easy...however I first read a bit in the manual and your website about how to get it working...the basic things like enabling the UART are done...maybe not correctly? I'll double check and come back.
olio
Re: Gertbot
Thu Apr 19, 2018 2:57 pm
I did the following in the boot/config.txt
replaced the line:
dtoverlay=pi3-disable-bt
with
dtoverlay=pi3-miniuart-bt
and added
core_freq=250
not sure if the latter is necessary
after reboot the Pi, I was able to run the gb_upload executable, connected to the board and finished uploading the SW version 2.8 to the board (2.5 was installed)...
again a reboot: the gertbot exe shows still the error, but the python drivers_test.py is now able to work with the board. The baud rate test is already done with a reply from the board.
If the control with python is working well, then I'm already happy...coming back soon ;-)
Thanks for getting me already in the right direction!
Oliver
olio
Re: Gertbot
Fri Apr 20, 2018 6:06 am
Hello again,
the only issue left was the wrong board address in the python script. After a second connect with the gb_upload executable I could see that it's addressed with board 3 by default (why not 0?)...however,
my board is now doing the tests well after a few corrections in the python script (e.g. you wrote somewhere that one should start with a low frequency...the move_stepper test starts with 5kHz, which gives only a noise without moving the motor...my stepper runs with up to 900 Hz).
so for me with Jessie on a Pi3 the following lines work for enabling the serial communication with the board:
enable_uart=1
core_freq=250
Finally I can start programming my application.
Thank you very much Gert for this very functional board (I appreciate the end switches and the higher frequency than the adafruit board)!
Greetings and have a sunny weekend (already ;-)
Oliver
Gert van Loo
Gertbot sales in the US
Tue Apr 24, 2018 7:57 am
featherfeet:
I have contacted a Dutch company who still have stock: https://www.kiwi-electronics.nl/
They tell me they ship world wide.
Brunobaer
Gertbot endurance test
Mon Apr 30, 2018 9:34 am
Hello Gert,
thanks very much for the „Gertbot“ which gives me the opportunity to run model trains with a RPI A+ via Wifi (WLAN0). Unfortunately I killed up to now two gertbots and I hope, You can help me to reanimate them.
What I did: I put the gertbot (Vers. 2.6) on a rpi A+ and connected two dc-brushed motors (24V, 1A) in parallel to channel 0. I wrote a c-program (modified copy of the “Rover” (thanks for that nice program)). I enabled the uart-interface and everything went well. The supply voltage was 23 V, the current about 1.8 A. the supply voltage is generated by a rectifier (6 A) stabilized by a capacitor of 170 mF (gold caps).
After a few minutes running the model train stopped and the led D7 was fast blinking. So I thought something went wrong. I took the gertbot out of the train and connected it to an other rpi A+ in my test lab. An equivalent other dc brushed motor (24V, 1 A) was connected to channel 0 and an external power supply with 20 V DC. The gertbot GUI showed “Enable 0 was negated”. So I tried Your recommendation with the ramp-up and ramp-down option. No result.
Next I tried to reset the gertbot by shortening pin 6 with pin 7 on J10. Fast blinking of D7 stopped but no result (D8 normal heart beat blinking).
Then I renewed the image with gb_upload (rmc_2.6.crypt) successfully but no result. So I connected the two brush motors on channel 1. The model train run for a few minutes and again the same break down as on channel 0.
Channel 2 and 3 I killed by putting the wrong polarity of the supply voltage (V+ to Gnd, Gnd to V+, my fault).
Next step was to connect to the second gertbot each dc brushed motor to channel 0 and channel 1. I modified the c-program by doubling all motor program lines but change only the channel from 0 to 1. Everything worked fine. During the endurance test after about 10 minutes on the track channel 0 stopped while channel 1 was still running.
Same procedure as described above without any result.
So I did additionally the ./gtest -t3 (move brushed motors). A warning came up “make sure that short/hot has been disabled!!” But how to do this? I did not found it in the different gertbot manuals.
Again I reconnected the model train now to channel 2 and 3. Everything looked perfect in the test lab. But during the endurance test, both motors stopped at the same time after about 5 minutes. Same procedure , described above but this time, no fast blinking of D7 (D8 regular heart beat blinking). No error code (Board 3 ; No error) without any result.
Before I will kill further gertbots I would like to ask You for help, how to avoid the damages.
Thank You in advance for Your answer.
Peter
Gert van Loo
Re: Gertbot
Mon Apr 30, 2018 11:55 am
Peter,
I have to work through your text in detail and think about what may be happening.
I have thus far, (keep fingers crossed) not been able to blow up a board other then by a too high voltage
on the motor connector. I have run test with directly shorted outputs.
The ramp-up and will only prevent the 'Enable-x ' error during starting as it reduces the in-rush current.
If the error happens after a few minutes somehow your motor(s) draw a too much current whilst running.
As to the fast blinking LED: it disappears when there are no more errors in the report queue.
Thus you have to read the errors, which are in a short FIFO.
I'll come back to you.
Brunobaer
Re: Gertbot
Mon Apr 30, 2018 2:22 pm
Gert,
Thanks for the fast reply.
In the second endurance test I forgot to tell, that I only run the duty cycle by 75% and in the first test at 100%. As there was really only the locomotive running, a too high current seems to me not the root cause, as I understood the specification right, each channel cane drive 2.5 A. Even if I put a very high load on the motor, the current does not exceed 1.2 A.
The strange thing to me is, that it happened in a stable situation, far away from any specification limits (30 V, 2,5 A).
Best regards
Peter.
Gert van Loo
Re: Gertbot
Mon Apr 30, 2018 2:41 pm
The problem is that the hardware and CPU are very, very fast.
Even a very short current spike may trigger the stop-mode.
Command <0x21 <id> 0x00> will prevent that.
Thus 0x21 0x00 0x00 for channel 0,
0x21 0x01 0x00 for channel 1 etc.
It does NOT disable the short circuit protection. That is always enabled.
All it does, is tell the CPU to ignore any short-circuit pulses and keep the system running.
What duty cycle frequency are you using?
A very low frequency may be seen as continuous start-stop.
In fact that was the way I tested overheating:
big motor 50% duty cycle, 10 Hz. PWM.
Brunobaer
Re: Gertbot
Tue May 01, 2018 7:15 am
Hello Gert,
this seems to me possible. I know this Problem with the very fast CPU from Counters, which also count the Spikes.
But it cannot be the current spike, because the current in an inductivity (coil) is not able to jump! It is the voltage that causes the Spikes. If You disconnect an inductivity it wants to continue the current and when you force it to do so it answers with high voltage spikes. This happens in every DC brushed Motor, because the coil of the rotor is forced to be disconnected by the Rotation of the rotor. At bigger DC brushed Motors (>1 kW) you can see the firing.
So the cpu detects the voltage spikes (not current spikes!). So I have to suppress the voltage Spikes by a capacity. I have to look up how to calculate the Dimension of that capacity.
As I understood the H-Bridges are driven by MOS-FET's, which are very sensitiv to voltage Spikes (thats why You should always work with ESC protection) so I guess the Output of the gertbots are dead, because they do not run when I connect them to the GUI. You think so as well or how I can make sure, that they are really dead?
I will connect an Oszilloskop to the Output of the Gertbot and perhaps I can see the Spikes.
As I am a bad programer, will You please tell me, how the command line You mentioned looks like in a c-program? Where do I have to place this line? After / before every move-declaration?
I am running always 5000 Hz PWM frequency.
Regards
Peter
Gert van Loo
Re: Gertbot
Tue May 01, 2018 7:38 am
This chip has built-in freewheel diodes which take care of the turn-off voltage spikes.
Otherwise it would die at the first use!
There is no reason to add any more protection from your side.
To switch the current-stop off you send the command once:
set_short(board,channel,GB_SHORT_NONE);
I have not yet figured out how your boards could have died.
Even if you blow-up the motor drivers, the CPU should keep working but you tell me
they do not. You still have a heartbeat?
Brunobaer
Re: Gertbot
Wed May 02, 2018 10:46 am
the built-in freewheel diode is mandatory to switch the directions. The spikes I am talking about are coming from the commutator on the rotor, which Switches the coils on the rotor of the brushed motor. Unfortunately I was not able to see them on the oscilloscope, because it is a very old analog one.
If it would be the very fast CPU that triggers the stop mode, the motor should run again after a new initialisation, but it doesn't.
During the tests (with the GUI, one motor) with the last channel available it happened, that one direction failed (Enable 1 was negated) so that I only can run one direction on this last channel. All others channels are dead as described.
Thanks for the set_short command. I will use it when the problem is solved for the next gertbot.
The heartbeat is still blinking.normal.
Regards
Peter
Return to “Gertboard classic”
Who is online
Users browsing this forum: No registered users and 2 guests
