I originally ordered a black enclosure for the B+ from RS with the Pi 2, but it wasn't delivered with the board and when I contacted them they said they had cancelled the order for the case as they had had reports that there was problems with the case fitting the new model and so have removed it from both my order and the website.
This *wasn't* the Pibow case, so I was surprised at this as I thought that the B+ cases should be fine for the new model, but reports that another case doesn't fit has me worried about ordering a case without knowing for sure that it will fit.
The case I ordered from RS was identical to this case, which doesn't look like it would be problematic but multiple reports to RS and similar reports to users at Reddit make the issue hard to ignore.
What cases are confirmed to be OK for the Pi 2? - Specifically one in the UK, under £10 and with enough clearance to allow the fitting of a Pi Hut heat-sink on the processor, availability on Amazon also a plus.
