morrisse
B+ compatible case and touchscreen
Mon Nov 24, 2014 9:13 pm
Hi, I am a senior in college and for my design project, my group is using a raspberry pi. I was wondering if there were any affordable options for a case and touch screen for the B+ model. Idealy the case would incorporate the screen, which I am thinking will be ~2.8" . Thanks for your input!!
BMS Doug
Re: B+ compatible case and touchscreen
Tue Nov 25, 2014 9:09 am
morrisse wrote:Hi, I am a senior in college and for my design project, my group is using a raspberry pi. I was wondering if there were any affordable options for a case and touch screen for the B+ model. Idealy the case would incorporate the screen, which I am thinking will be ~2.8" . Thanks for your input!!
depends on how you define affordable really
Doug.
Building Management Systems Engineer.
dozencrows
Tue Nov 25, 2014 3:50 pm
Depending on your budget, you could try one of the Pibow cases and an Adafruit 2.8 TFT resistive touch screen.
http://shop.pimoroni.com/collections/cu ... spberry-pi
There are a whole range of Pibow cases, and as they're made from laser cut acrylic layers, they can be customised. There is a version for the original Model B with the Adafruit TFT screen, for example.
A number of suppliers have the TFT screen available; worth shopping around. For example: http://shop.pimoroni.com/products/pitft ... tAodjRgAeA
Lob0426
Fri Jan 02, 2015 4:47 am
Adafruit has two different PiTFT touchscreens. One is resistive at $34.95 and the other is capacitive at $44.95. They have two different cases to house the Raspberry Pi and the PiTFT.
Adafruit PiTFT resistive touchscreen https://www.adafruit.com/products/1601
Adafruit PiTFT capacitive touchscreen https://www.adafruit.com/products/1983
Both of these cases are for the B Model not the B+. There is not a case with either screen for the B+ as of yet.
Adafruit PiTFT Pibow case https://www.adafruit.com/products/1723
Adafruit PiTFT enclosure https://www.adafruit.com/products/1892
512MB version 2.0 as WordPress Server
Motorola Lapdock with Pi2B
Modded Rev 1.0 with pin headers at USB
http://rich1.dyndns.tv/
(RS)Allied ships old stock to reward its Customers for long wait!
fhlipZero
Mon Jan 12, 2015 1:48 pm
the 2.8 pitft from adafruit is great but its very small and not all that useful from my experiments, i highly recommend the 5" hdmi touchscreen though, im in the middle of making a small pi tablet out of one right now! https://www.adafruit.com/products/2260
