Re: Touchscreens for Raspberry Pi
Thanks! Perfect.
Hi BAStumm,
could you please let me know your config.txt display settings for the dell E2014T monitor please? I'm having some overscan problems and I've followed the forum HDMI instructions but im still struggling!
Sak
Sak
Don't think I have anything special in my config... It just worked out the box. What is the problem you are seeing, perhaps I just haven't noticed the "issue" you describe. Here is my config.txt.
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
#disable_overscan=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
# for more options see http://elinux.org/RPi_config.txt
The Dell E2014T (19.5 inch HDMI/USB Touchscreen) is getting harder to locate. Anyone using a more readily available touchscreen that is plug and play, HDMI video and USB touch? Anything larger than 15" is OK but prefer 19 - 22".
@BAStumm: did you find your touchscreen? please share your experience...BAStumm wrote:The Dell E2014T (19.5 inch HDMI/USB Touchscreen) is getting harder to locate. Anyone using a more readily available touchscreen that is plug and play, HDMI video and USB touch? Anything larger than 15" is OK but prefer 19 - 22".
I have since switched to using the official touchscreen of the RPI foundation. Have not looked at other touchscreens in a long time. Sorry.
