cornpie
VNC sound
Sun Sep 14, 2014 8:57 pm
Is there anyway to get sound over vnc? I'd really like to use my ipad to play games on the pi but it would be preferable if they had sound.
Thanks in advance!
Re: VNC sound
Sun Sep 14, 2014 9:17 pm
cornpie wrote:Is there anyway to get sound over vnc? I'd really like to use my ipad to play games on the pi but it would be preferable if they had sound.
Thanks in advance!
VNC Ptocol does not support Sound ;)
RPi 4B 4GB (SSD Boot)..
cornpie
Re: VNC sound
Sun Sep 14, 2014 9:25 pm
Is there an alternative to vnc that I could use?
Re: VNC sound
Sun Sep 14, 2014 10:14 pm
cornpie wrote:Is there an alternative to vnc that I could use?
You will need to investigate VNC or RDP in conjunction with Pulse Audio, which is beyond my knowledge, .....
cornpie
Re: VNC sound
Sun Sep 14, 2014 10:45 pm
I assume you mean to stream audio from the raspberry pi to the device ( I use ios by the way ) which sounds like a good idea, but when I did some digging I couldn't find anything that really sounded like it would work ( I'm new so it might just be I don't understand it ) if you know of anyways to stream pi audio to the raspberry pi, preferably on startup that would be awesome.
Re: VNC sound
Sun Sep 14, 2014 10:57 pm
cornpie wrote:I assume you mean to stream audio from the raspberry pi to the device ( I use ios by the way ) which sounds like a good idea, but when I did some digging I couldn't find anything that really sounded like it would work ( I'm new so it might just be I don't understand it ) if you know of anyways to stream pi audio to the raspberry pi, preferably on startup that would be awesome.
Google for xrdp pulse audio sink and get confused, but a great way to learn :D
Re: VNC sound
Sun Sep 14, 2014 11:03 pm
Considering all the issues you have encountered here http://www.raspberrypi.org/forums/viewt ... 15#p610715
The DOSbox clone for iOS seems to be the only solution, which I did mention in the thread........ :shock:
cornpie
Re: VNC sound
Sun Sep 14, 2014 11:29 pm
I googled xrdp pulseaudio sink and it seems to be for another vnc-esque program. Would it translate over to vnc?
huisinro
Re: VNC sound
Mon Sep 15, 2014 6:15 am
You can use our rPlay to mirror iPad games to Pi, not sure if this is what you want.
Re: VNC sound
Mon Sep 15, 2014 7:34 am
cornpie wrote:I googled xrdp pulseaudio sink and it seems to be for another vnc-esque program. Would it translate over to vnc?
https://www.wikipedia.org
cornpie
Re: VNC sound
Mon Sep 15, 2014 8:38 pm
A big trend I am seeing in audio streaming from the raspberry pi is that it is often used for streaming specific files and not just the entire thing going through Wikipedia the page on xrdp didn't look all that helpful it looked mostly like a change log. Do you think I should set up an xrdp server on the raspberry pi and use an rdp app to connect via ipad? If so I might need some help connecting on the ipad and setting the pulseaudio server up on the pi. Also if it helps I have found an airplay reciever for ios on the emu4ios store. Thanks!
cornpie
Re: VNC sound
Tue Sep 16, 2014 12:57 am
I have a new idea. Could I possible plug headphones into the audio jack of the pi, while it is headless? I plan to use it with a mobile battery pack so it wouldn't be that bad. If this works I think it would be the best and simplest options. Unfortionally I don't have access to a working pair right now but there are some coming in the mail so if you don't know it I'll update one I get some. Keep in mind I'll be running x11vnc to.
cornpie
Re: VNC sound
Wed Sep 17, 2014 7:36 pm
It works but, just one question is there any volume control on the pi? It's incredibly loud
Re: VNC sound
Wed Sep 17, 2014 7:55 pm
At the command prompt type
alsamixer
this will pop up the Volume GUI, use the up down arrow keys to adjust volume
