lpinho
Punnet for B+
Sun Jul 20, 2014 1:38 am
I've just ordered the B+ and since I'm a big fan of DIY I would like to know if someone already did the schematics to adapt the punnet box to the new B+?
I would love to do something similar with thin plywood, since I don't have a cnc the design must be very simple.
If no one as done this I will do it as soon as I get the board.
Thanks everyone,
L. Pinho
Gary Littlemore
Re: Punnet for B+
Wed Jul 23, 2014 11:58 am
Hopefully my B+ will of been delivered today, so if I have some time tonight I'll have a go at creating a template. :-)
3b+, 2b, b+, b, Zero & Zero-W
lpinho
Re: Punnet for B+
Sat Jul 26, 2014 6:02 pm
Thanks for the reply (didn't get an e-mail warning about your reply), I'm still waiting for mine, it will take at least one more week.
Will you publish that template? Please let me know when you do.
Thank you so much,
L. Pinho
prune
Re: Punnet for B+
Sun Jul 27, 2014 11:07 am
Hi both,
Just joined as a brand newbie with my first b+ and am looking for a punnet template too. Did you happen to create or find one yet?
Thanks!
lpinho
Re: Punnet for B+
Sun Jul 27, 2014 5:17 pm
Hi Prune,
still haven't received my B+ :(
Hope to get it this week, but I'm not sure of that either...
Thanks for your interest, as soon as I do something, I'll post it here,
Thanks again,
L. Pinho
sbmiller87
Re: Punnet for B+
Tue Jul 29, 2014 12:40 pm
Hey, I have put together a simple design easily tweakable through Illustrator there is are .pdf and .jpegs in the .rar also, check it out.
http://fav.me/d7srezb
Enjoy any comments would be appreciated.
lpinho
Re: Punnet for B+
Tue Jul 29, 2014 1:41 pm
Hi sbmiller87,
as soon as I get my Pi I will try this out.
Thanks,
L. Pinho
sbmiller87
Re: Punnet for B+
Tue Jul 29, 2014 9:28 pm
I should note i designed this to print out on 2 regular 10x15cm photopaper, it's what i had lying around...
prune
Re: Punnet for B+
Tue Jul 29, 2014 9:51 pm
I've just made a punnet from your template, it fits the b+ pretty well. Thanks!
sbmiller87
Re: Punnet for B+
Tue Jul 29, 2014 10:27 pm
Cheers, I think the 4.5mm jack may be a little tight but its located ok, I think I'd add some support around the lid next time, allow it to close a little more securely.
Re: Punnet for B+
Tue Jul 29, 2014 11:01 pm
sbmiller87 wrote:Cheers, I think the 4.5mm jack may be a little tight but its located ok, I think I'd add some support around the lid next time, allow it to close a little more securely.
The 4.5mm jack is going to be a bit of a tight fit in a 3.5mm socket on your RPi. You may need to turn it down to size on your lathe.
This is a doctor free zone.
sbmiller87
Re: Punnet for B+
Wed Jul 30, 2014 12:46 am
oops, should have said it was 3.5mm, my bad.
quantumSequoia
Re: Punnet for B+
Wed Aug 06, 2014 1:25 am
I was bored so I took it upon myself to make one.
Here is the pdf: https://drive.google.com/file/d/0B4bby8 ... sp=sharing
Here is the CAD file used to make it: https://drive.google.com/file/d/0B4bby8 ... sp=sharing
The Ethernet and USB ports stick out in my version. The template is of the inside of the case, so you would fold everything up. When printing the PDF, be sure to select "actual size" from the print menu. If you leave the default "fit" option, your case will be too small.
Enjoy!
lpinho
Re: Punnet for B+
Wed Aug 06, 2014 8:33 am
I've received mine yesterday, I will print all your plans and make a trial run :)
Could you share what material you are using? Just plain paper? Or something harder?
Thanks for all the replies
quantumSequoia
Re: Punnet for B+
Wed Aug 06, 2014 9:07 am
I used a manila folder for mine
NeoStormer
Re: Punnet for B+
Fri Aug 15, 2014 11:28 pm
Could you mirror image the template, it would be nice to hide the lines.
quantumSequoia
Re: Punnet for B+
Mon Aug 18, 2014 11:49 pm
The lines ARE hidden in the template. you would fold inwards on the dashed lines and the lines would be on the inside of the case
NeoStormer
Re: Punnet for B+
Tue Aug 19, 2014 6:58 am
I think your printer settings are different because I had to flip the file to make it correctly.
Just look at the file and imagine folding it, it needs flipping.
