obarthelemy
Re: text mode Linux ?
Thu Sep 22, 2011 2:16 am
I'm trying to find out how good a computing experience we can get without using x11. That would save a lot of RAM and CPU for actual, productive work, and maybe let our Pi servers do a bit of double duty.
I haven't found any way to filter only text-mode apps in aptitude, nor really, a list of all (or good) text apps.
I found an old text-only distro called INX, with a list of its packages there: http://inx.maincontent.net/1.0.....ckage-list. Very sparse.
I'm surprised the subject is not more popular. Have I missed anything ? Especially, is there no suite of basic apps (file manager, editor, email, system config; maybe RSS, MP3...) with some sort of standard UI, like IBM's CUA before graphical shells became the rage ?
ukscone
Thu Sep 22, 2011 2:27 am
apart from the vm's for scratchbox2/qemu i don't ever use X11, Qt, gtk..... nearly everything i do is ncurses or framebuffer SDL/DirectFB and even in the vm i do everything in an xterm window.
i do remember recently hearing about a newish distro that was only text & framebuffer but at the moment the name escapes me but apparently it has a large package repository
obarthelemy
Thu Sep 22, 2011 2:32 am
best I found:
https://bbs.archlinux.org/viewtopic.php?id=61403
http://www.terminally-incohere.....without-x/
More terminal programs you should be using ... like a pro
Running rtorrent as a daemon
Best Lightweight Applications for Linux .
https://wiki.archlinux.org/index.php/Li ... e_Managers
tnelsond
Thu Sep 22, 2011 2:42 am
I find http://kmandla.wordpress.org interesting when dealing with text only Linux. You can get a pretty good user experience without x11, and if you get your framebuffer working right, you can watch movies and view pictures even.
Blars
Thu Sep 22, 2011 4:33 am
If you just want to avoid installing X and things that depend on it, you could create a package that conficts with selected other packages. Note that emacs requires a tiny peice of xorg even in its text version.
hsalonen
Thu Sep 22, 2011 6:44 am
AFAIK Ubuntu Server is running without a GUI.
You can just remove X from your startup scripts anyway, shouldn't be a huge problem..
obarthelemy
Thu Sep 22, 2011 9:56 am
It's not so much the "installing" part, as the "running" part of X I'd like to avoid ^^ It seems there is not that much non-X software with a relatively complete feature set, and friendly UI... I'll try out some of the stuff in the lists above.
ShiftPlusOne
Thu Sep 22, 2011 10:12 am
http://kmandla.wordpress.com/ has been mentioned several times, and rightfully so. He lists some good CLI applications and also has great tutorials for some of them.
Chris Tyler
Thu Sep 22, 2011 3:21 pm
Most packaging systems let you blacklist packages. If you blacklist the X server and some of the core graphics libs you won't inadvertently install GUI apps.
In Fedora-ARM, for example, you can use a yum configuration line such as:
exclude *qt* *gtk* Xorg*
kingneutron
Sun Jan 01, 2012 9:40 pm
--GRML is a pretty good text-based distro:
http://distrowatch.com/table.p.....ution=grml
kingneutron
Sun Jan 01, 2012 9:42 pm
--And BTW, Midnight Commander ( ' mc ' ) is the best text-filemanager evar
kme
Sun Jan 01, 2012 10:37 pm
It isn't that hard to avoid X and its libs. E.g. in Debian if you choose "expert install" (not much expert knowledge needed - just more questions) you can easily make a text-only install. Apt-get/aptitude will warn you before pulling X if you try to add a X dependent package. You should wonder why a slim little text editor takes 100+ MB in dependencies
SergeantFTC
Sun Jan 01, 2012 10:39 pm
I highly recommend Arch Linux as a text only distro. I know that you can install X, but it doesn't come by default. It will also be supported on the Pi right out of the box.
Benedict White
Sun Jan 01, 2012 11:09 pm
I would like to second SergeantFTC.
I use Arch extensively. on many many machines, and only 3 have X installed at all.
Those that do, do so because I want a mouse driven desktop OS and have RAM to spare. Mostly I use Arch as a server precisely because it does not install tons of rubbish by default, in fact, it's base install is still of the order of 100MB ish, and that's only because I can't be bothered to trim it.
Marlon
Wed Jan 11, 2012 12:00 pm
Debian in text-only Mode is very lightweight (htop shows me 10 MB Ram used with Lenny )
acrux
Wed Jan 11, 2012 5:28 pm
CRUX is antoher good candidate (i.e CRUX ARM project)
