kdakin wrote:How do you connect to the GPIO pins with this (and other) closed designs I wonder?
As rurwin says, I'm not really intending to play much with the GPIO pins at the moment. In the future this will (I hope) change. For example, when the camera module becomes available, I think it would be nice to sink the lens into the top layer of the case (not the most practical place, but aesthetically the kind of thing I'd enjoy). For that, though, I'm guessing I'd need greater depth. And with this design it's very straight forward just to add a couple more layers of ply to achieve that.
Montala wrote:No problem there so far as I am concerned... I will 'bookmark' this, and perhaps we can talk again in a couple of months time, and see what the position is then?
Hopefully you aren't going to vanish from the Forum altogether for all that time though?
That's great. I've a plan for another case I intend to make whilst away from home with hand tools (similar shape, different materials) so you may even be interested in that.
As for vanishing - definitely not. It's a very busy time at the moment and I've not had chance for PiPlay™, but as soon as I'm able, I'll no doubt be begging help from you all!
benedict3578 wrote:You could either drill a hole for the original RPi LED, or you could spilce an normal size LED into the power cable. The tiny voltage taken shouldent affect the Pi, but the extra light would be brighter. You could countersink it into the main case. Good luck.
Now that makes sense! Thank you
As always, thank you to you all for your kind comments.
