DaveCummings
Getting a small screen to work on my pi
Fri Jul 11, 2014 8:00 am
I have bought one of these:
http://www.ebay.co.uk/itm/84x48-1-6-LCD ... _492wt_904
now I cannot get it to run I have soldered it as required and all the connections buzz out fine with a tester but it doesnt appear to be turning on. I have a Model B with 512mb ram, can anyone help me as to which pins i should be connecting the wires to as I keep finding oncflicting information on the internet?
DaveCummings
Re: Getting a small screen to work on my pi
Fri Jul 11, 2014 8:02 am
btw the pins are for the scvreen as as follows:
1-RST – Reset
2-CE – Chip Enable
3-DC – Data/Command
4-DIN – Serial Input
5-CLK – Clock Input
6-VCC – Power
7-BL – LED Backlight
8-GND – Ground
johndough
Fri Jul 11, 2014 8:27 am
DaveCummings wrote:btw the pins are for the scvreen as as follows:
1-RST – Reset
2-CE – Chip Enable
3-DC – Data/Command
5-CLK – Clock Input
6-VCC – Power
8-GND – Ground
Hiya
This looks similar
https://learn.adafruit.com/nokia-5110-3 ... chrome-lcd
and may help.
As you say there are several connection lists.
1 VCC Positive power supply Input Supply range is between 2.7V and 3.3V
2 GND Ground Input
3 SCE Chip select Input Active low
4 RST Reset Input Active low
5 D/C Mode select Input Select between command mode (low) and data mode (high).
6 DN(MOSI) Serial data in Input
7 SCLK Serial clock Input
8 LED LED backlight supply Input Maximum voltage supply is 3.3V.
klricks
Fri Jul 11, 2014 12:48 pm
DaveCummings wrote:I have bought one of these:
The link given in the ebay listing has connection information and driver / kernel installation instructions:
http://www.bartbania.com/raspberry_pi/r ... pberry-pi/
DaveCummings
Fri Jul 11, 2014 1:02 pm
Yes I have seen that but the pinouts are difficult to follow
klricks
Fri Jul 11, 2014 1:19 pm
DaveCummings wrote:Yes I have seen that but the pinouts are difficult to follow
From the link:
LCD --> RPi
RST --> pin 18 (GPIO24)
CE --> pin 24 (SPI_CE0)
DC --> pin 16 (GPIO23)
DIN --> pin 19 (SPI_MOSI)
CLK --> pin 23 (SPI_SCLK)
VCC --> pin 1 (3v3)
LED --> pin 12 (GPIO18) to allow varying the brightness
GND --> whichever GND pin is convenient
It does not get any easier than this. What are you having trouble with?
DaveCummings
Fri Jul 11, 2014 1:27 pm
I was seeing gpio23 thinking it was pin 23 (facepalm.)
dummy
Fri Sep 11, 2015 2:47 pm
Resurrecting this old thread...
Can maybe someone help me in connecting this display via software SPI, not hardware, like million tutorials online? The only info I got was from the official Adafruit page
https://learn.adafruit.com/nokia-5110-3 ... rary/usage
where this concept is documented in the source code:
# Raspberry Pi software SPI config:
# SCLK = 4
# DIN = 17
# DC = 23
# RST = 24
# CS = 8
Trouble is: I don't have the Adafruit version, but the "chinese one": VCC, GND, SCE, RST, D\C, DN(MODI), SCLK and LED. Well, i connected it anyway (let's say CS is SCE), but nothing shows up on i2cdetect. Has someone did this with my cheap display?
